Yes, the light i posted lost almost all the brass after the 1st year.
Thanks, will do!!! i’ll order the Q8
Thanks!!!
Thanks!!!
Go to this site.
https://m4dm4x.com
If you sign up you will have access to different coupon codes for flashlights.
oh, thanks!!!
(Now that I’m thinking about it)
The reason your current flashlight isn’t working may be because of the PCB erosion. The cells aren’t making good contact.
(If you have the tools)
One solution could be to try flowing some solder onto the battery contact ring. Try to build it up again. If it’s already broken it could be worth the try. Breaking it more wont hurt it.
Yes, i tried, but it seems that some electronic component is fried. I tried taking it apart, but i cannot do it (i do not want to damage it further).
I can remove the front bezel with the crystal, but the lens is glued. And from the battery/pcb side, there is no way to move it (only two very small holes, i can put pictures if you want).
Up to you.
Just a thought I had for a possible solution.
If the problem is something other than the battery contact I personally wouldn’t try fixing the driver.
You could post pictures. I might not be able to help you. But there are tremendously knowledgeable people on this forum. Perhaps the hive mind can help.
If you want more flood, make sure to stick with the BLF/Thorfire Q8, as the Sofirn Q8 is throwier, if I’m not mistaken.
Thanks! Yes, i’ll stick with the BLF Q8.
u shouldnt use protected batteries in the q8, just buy some 30q or something they dont cost much otherwise u dont get the highest lumens.
I don’t mind if i don’t get right know the highest lumens.
It’s impossible to find 30Q batteries here. When buying li-ion cells via air mail was cancelled due to regulations, it’s very impossible to buy them. That’s why i still stick to my old’s panasonics NCR18650.
okay that sucks, where do u live even ?
Yeah. Where do you live?
We can help you out.
I live in Buenos Aires, Argentina.
I’ve just found a place, they sell cells (3000mAh 30Q) for USD 16 each
So… i’ll start saving.
Well, they are flat top, so no good for the Q8.
Another place sells 30Q button top, but for USD21 each!
@ltcdata, what you want then is a Sofirn Q8:
https://www.aliexpress.com/item/Newest-Sofirn-Q8-4-XPL-HI-5000LM-Powerful-LED-Flashlight-18650-Multiple-Operation-Procedure-Super-Bright/32920587281.html
And ask them to include these 18650s:
https://www.aliexpress.com/store/product/Sofirn-3000MAh-18650-Rechargeable-Battery-Pre-charged-3-7V-Li-ion-Protection-18650-Batteries-for-LED/2933049_32926129538.html
They are button top, are capable of outputting 15A, and since they can be put inside of the flashlight, these are not only much cheaper, but also, they can actually be shipped
Aliexpress won’t ship the batteries, they treat that as 2 different products. I asked them (and many others) to please, ship the flashlight with the batteries inside and they denied to do that. This was a year ago.
Do you think they can do that know?
Yes, Sofirn has done that before, multiple times even for people who could not get good 18650s for acceptable prices.
The advantage Sofirn has over other sellers is that not only are they very friendly, but since they are the OEM for the lights, they can easily put in the cells inside of the Q8 before they ship.
I’ve asked them before about this, and they said that it was okay to ship inside of the light, but not separately.
Oh, nice! i’ll write to alibaba right now!
If the sofirn is a little throwier i don’t mind if i can buy the batteries with it (i prefer floodier)
You can put a small solder blob on the flat tops in a few seconds. Don’t need much to insure that they make contact with the brass ring.
In my opinion you can easily avoid buying new cells, and use those you have. you won’t notice a big difference, especially if you don’t have other cells to compare. It’s plenty bright even with 18650b. I have 30q’s and 18650B’s and use whatever cells are charged when I need them, can’t tell which ones I’m using. save some money and the trouble
