wow what a monster… how many lumens 25k or more ? looks like a bigger version of the blf q8 the reflectors. Interesting concept, the big mass heatsinking looks good.
Me too.
I have enough big lights.BLF GT, Astrolux MF04 — MF04S ,Imalent DX80—R90C,Thrunite TN42—TN40S,Acebeam K70,Nitecore TM16GT.
So,I hope I don’t buy more.But looking at this new light,I don’t know if I keep my promise not to buy more.
You don’t think 7x Boost HX in the 120mm diameter head of a GT would out-throw the original XHP35 HI GT? You may be right. I certainly don’t know. But, care to elaborate?
EDIT: Roughly, each Boost HX would get a 40mm diameter reflector opening with very little overlap or a larger diameter with more overlap between them.
Both of these are kinda the same so I will reply together.
In my experience, a multi-emitter light will generally only have slightly less throw vs a single emitter in the same space assuming that the reflector cups are well made of course.
So… if that be the case, since the Boost HX has a MUCH better luminance than XHP35 HI, can it be true that 7x Boost HX would easily beat 1x XHP35 HI in throw?
