13507 posts / 0 new
Firelight2
Firelight2's picture
Last seen: 7 min 47 sec ago
Looks great!
Tjohn
Tjohn's picture
Last seen: 15 hours 55 min ago
The D4S is much larger in the photo, but the shadows on the sides of the FW3A give a false illusion of being even slimmer.
Copy the photo, reduce the contrast, increase the exposure illumination and see the difference.
dealgrabber2002
Last seen: 1 hour 14 min ago
Is there a video on how to polish a frosted optic?
hodor
hodor's picture
Last seen: 2 hours 5 min ago
The link in Joe’s post seems to suggest you can just rub it Wink Big Smile
dealgrabber2002
I know I’ll find a way to mess it up w/o visual instructions. LOL.. I am special.
joechina
Last seen: 2 days 6 hours ago
Pro tip: Buy spare optics Smile
teacher
teacher's picture
Yep, that picture certainly does make the D4 look huge.
EDIT: It is huge compared to the FW3A after all. The picture is of a D4S…. a 26650 light. See POST BELOW by iamlucky13 for explanation.
Except for length the FW3A is closest to the size Convoy S2+ no doubt.
And without the bezel & head of the D4 it probably would be closest.
That picture is a huge optical illusion.
D4
Bezel diameter: 28.0 mm / 1.102 inch
Head diameter: 30.0 mm (widest point) / 1.181 inch
Body diameter: 23.9 mm / 0.941 inch
18650 length: 93.7 mm / 3.689 inch
28.0 × 30.0 × 23.9 × 93.7 mm
FW3A
25.5 mm x 92.5 mm
1.004 × 3.642 inches
S2+
24.13 mm x 121.92 mm
0.95 × 4.8 inches
Tixx
Last seen: 4 hours 42 min ago
hodor wrote:
junkyardbiker wrote:
Is it only coming with the frosted optics? I remember seeing a few posts about Carclo options for this so I may just order a different for it at some point.
I believe so. If I remember correctly, the normal un-polished version produces an ugly beam but is throwier. A frosted one looks nicer and can be polished to give a bit more throw while still maintaining a pretty beam.
I have so many triples without frosted optics. Is there something about this flashlight that distorts the beam that much more than a D4, Oveready Boss, my modded triple Eagletac D25C, or other random triple mods?
iamlucky13
Last seen: 43 min 51 sec ago
^ Those dimensions are for the D4 (18650 powered). The picture shows the larger D4S (26650 powered).
For a comparison with the D4, see the photos of the 2nd prototype on page 1 of this discussion.
teacher
teacher's picture
OK…. that explains the picture then. Thanks for the heads up on that… Thumbs Up
I do not have any of the D4’s, so nice to know the picture was not that much of an optical illusion after all.
idleprocess
idleprocess's picture
Last seen: 2 hours 8 min ago
Commodity LED optics being relatively inexpensive, this is wise.
DavidEF
DavidEF's picture
Last seen: 23 hours 41 min ago
That’s a very nice, elegant light! Crown Thumbs Up
- The YKK Philosophy
teacher
teacher's picture
Thanks again… this looks more like it. Wink Below is the picture iamlucky13 is referring to.
JasonWW
JasonWW's picture
Last seen: 7 hours 48 min ago
I would assume some rubbing compound, like for automotive paint/plastics, and a rag would be sufficient to make the optics clear. Even tooth paste might work.
Is the frosting on the lens so deep that you actually need to sand it with sandpaper? That’s more extreme than what I was thinking.
Texas Ace Lumen Tube calibrated with Maukka lights
Click this to go to signature links.
teacher
teacher's picture
With 1000 to 7000 grit Wet-Dry paper… you are not removing much. Mainly polishing once you get to about 3000 – 4000.
Geese
Last seen: 3 weeks 3 days ago
Please put me down for one more. This will be for a total of 3.
Thanks!
ToyKeeper
ToyKeeper's picture
Last seen: 17 min 31 sec ago
If I recall correctly, it’s primarily a matter of polishing, not sanding. It may be sufficient to rub it against denim or newspaper or something along those lines.
iamlucky13
Toothpaste or a paste of baking soda and water are both common recommendations for removing the haze on automobile headlight lenses that develops over the course of multiple years of sunlight aging and/or driving through the gritty spray kicked up by other cars when it is raining out. I suspect they would also work for Carclo optics.
Firelight2
Last time I polished one of these optics (which was several years ago), I mounted a triple star onto a bit and then put the bit in a hand drill. I then put the drill pointing upwards in a wood vise.
I then placed the optic into the star. To polish I used one hand to hold the drill button down and the other to place the cloth against the optic.
For the actual polishing I used jewelers rouge on terrycloth.
marcuswong
Please put me in for one in XPL HI
Thanks!
youmansk
Add me too. Xpl hi cw
Deca
Last seen: 1 month 5 days ago
Please put me on the list for one with LH351D. Thanks!
Ryzbor
Ryzbor's picture
Last seen: 7 hours 20 min ago
Will this light be mod friendly?
virence.com rosy 3500K R9080 Wizard Pro
JasonWW
JasonWW's picture
Only in the sense of changing leds, optics and maybe reflashing a new UI. The driver will be unique and not easy to replace.
Doddsy
Please put me down for one XPL HI
thanks
Ryzbor
Ryzbor's picture
Good, changing the leds will make the sub 4000K folks happy.
Cobra502
I would like to make sure I’m down for 2 lights, one of each. I’m currently on the list at 737.
Thanks
woodlandSerenade
Last seen: 23 hours 21 min ago
Please add me to the list for one with the LH351D. Thank you!
JasonWW
JasonWW's picture
Thanks
How odd, you used to be at #497 and #732. Now I only see the single listing at #737.
The main thing is that you said in the thread that you want 2 units. The list is created based on this thread. So don’t worry about it. Once the list is updated you should see your name on there twice.
Cobra502
Great thanks for the quick response.
