Please put me down for one more. This will be for a total of 3.
Thanks!
Thanks!
If I recall correctly, it’s primarily a matter of polishing, not sanding. It may be sufficient to rub it against denim or newspaper or something along those lines.
Toothpaste or a paste of baking soda and water are both common recommendations for removing the haze on automobile headlight lenses that develops over the course of multiple years of sunlight aging and/or driving through the gritty spray kicked up by other cars when it is raining out. I suspect they would also work for Carclo optics.
Last time I polished one of these optics (which was several years ago), I mounted a triple star onto a bit and then put the bit in a hand drill. I then put the drill pointing upwards in a wood vise.
I then placed the optic into the star. To polish I used one hand to hold the drill button down and the other to place the cloth against the optic.
For the actual polishing I used jewelers rouge on terrycloth.
Please put me in for one in XPL HI
Thanks!
Add me too. Xpl hi cw
Please put me on the list for one with LH351D. Thanks!
Will this light be mod friendly?
Only in the sense of changing leds, optics and maybe reflashing a new UI. The driver will be unique and not easy to replace.
Please put me down for one XPL HI
thanks
Good, changing the leds will make the sub 4000K folks happy.
I would like to make sure I’m down for 2 lights, one of each. I’m currently on the list at 737.
Thanks
Please add me to the list for one with the LH351D. Thank you!
How odd, you used to be at #497 and #732. Now I only see the single listing at #737.
The main thing is that you said in the thread that you want 2 units. The list is created based on this thread. So don’t worry about it. Once the list is updated you should see your name on there twice.
Great thanks for the quick response.
Same here. I’d love to get one of each options available so 2 lights in total.
Hey Jason, sorry to bother, I submitted a comment a while back for one of each, but don’t see my name on the list, maybe I did not format the comment correctly for the script?
In either case, I would love two, one of each emitter!
Thank you!
@ dotBLF …. You made your request HERE … you’ll be added next time the list is updated. Check back to see after the update is posted here.
teacher,
Thank you! I interpreted other comments to mean that the list was auto updated. I eagerly await any and all updates. Thank you FW3A team for all your work, excited to see this come to life!!!
Can you put me in the list? 1 x LH351D please.
