I finally dialed the potentiometers on mine down to the minimum level last night. It was an easily noticeable decrease in brightness when I adjusted it, although they’re still brighter than I’d like for sitting on a nightstand.
Since I keep mine in a drawer, that’s not really a problem though.
There is no explaining people. We are all very complex. I would not waste time trying to understand it.
Personally, I always add directly powered auxiliary lights to my flashlights. I’m not bothered by parasitic drain because I simply turn the battery tube or tail cap or click the rear switch when I’m not using the light. If people think that’s too hard or too complicated, etc… thats on them. I don’t waste my time analyzing why they feel that way.
The overwhelming majority seem to like the aux lights. It’s like that saying “You can’t please all the people all the time”.
I asked Jack to send me the light with the aux leds turned off. Today I removed the optics and turned all the potentiometers a little but the aux won’t get one. Which of the three needs to be turned?
About the only way to turn them off, as in no parasitic drain at all, is to not connect the wires. I would check that there is voltage going to the potentiometer. If so, then it should be simple to just turn all the pots until the leds start glowing.
See the + and the ground goes to the screw/flashlight body. When powered you should be close to battery voltage, 3 or 4 volts. If no voltage, the wire to the aux board is not connected.
Seems the wires are not connected. I asked Jack to turn them off not to disconnect totally rofl, lost in translation apparently and my fault for asking for changes.
What are the smaller and different looking blue and green wires? They seem to be looped up there for no apparent reason. I wonder if one of them is the power that goes to the aux board?
Yes, that is exactly what Ryzbor was showing. On request to turn off the aux LED board, Fireflies disconnected the aux LED board.
This was probably done because there is no other way to turn it off. Later models like the E07 switched to a 3-wire setup which allows the MCU to turn the board on and off, but on the ROT66, it’s wired directly to power.
Would it be possible for one of you to post a graphic illustrating where the potentiometers are and how to adjust them? I’d love to be able to ramp mine up a bit. I love the aux leds.
They are labeled POT_D1, POT_D2 and POT_LVP. There are 3 of them and they have the Philips head adjustor so you can turn them with a screwdriver. D1 looks to adjust the outer ring, D2 the middle ring and LVP adjusts the inner ring.
Look at the 1 o’clock, 2 o’clock + 7 o’clock position
after receiving the E07, I realized that my ROT66 somehow has different programming? I can’t get to turbo, only to the top of the ramp.
For example, it should to go the top of the ramp when I double click, then another 2x click to turbo. But on the ROT66, it goes to strobe when I do the 2nd double click, not turbo.
