[Optisolis/E17A/E21A] Jetbeam Jet-µ
E21A
E17A
Beam comparison. I shot under exposed (–2 stops) to show center beam better but that caused the tint over saturated
- Clemence
I consider myself an enthusiast but i’m starting to think clemence provides TOO much information about his products. Is that possible?
I think its great. All the added beamshots and tint comparisons make it alot easier to select preferred LED both for his products and any custom builds you chose to do on your own.
I have a few lights with e21a at this point with 4000k and 4500k and they are by far the best tinted and colour rendering lights I own!
but that ruins the surprise when you order from a no name company and they describe the tint as “yellow-white” or something
Those are the pictures I promised from my earlier post. This is BLF, people value research, data, and test results. unlike the other forum out there.
Do you prefer I don’t share any information instead? I think I have a problem being an enthusiast and a seller at the same time. Can’t decide which one should I be.
- Clemence
Of course I think more information is better. I’m only joking
However, it does just drive me deeper into this rabbit hole digesting all of this new information
Yes and no. I really like having the data to evaluate. However, it’s also possible to get the audiophile disease where you get lost in evaluating, and forget the real goal is to use and enjoy the product (it’s only a small percentage of audiophiles, of course, but they’re the ones who get noticed).
I’m currently thinking what I should do personally is just order each of the different emitters that potentially interests me on MCPCB’s, try them out on my work bench, and decide from that what my dream light is.
Exactly what Ive been doing. Have already tried most combinations of e21a, and just ordered a number of optisolis to combine and see.
For now it is e21a at 3000k and optisolis 5000, but looks like I’ll end up at higher cct with optisolis
I will put E21A and Optisolis modules for DIY-ers to experiment themselves but take note:
- Jetusolis and JetuE21A lens holders are NOT interchangeable. I modified the lens holder of JetuE21A so much that you can’t use Optisolis with it. There’s a potential one could easily crush the Optisolis put in the JetuE21A.
  • You can use E21A/E17A LED modules in Jetusolis but the beam will be about 50% narrower and you’ll lose ~20% output.
- Clemence
Updated some pictures and measurements in the product pages using final TIR optics selection.
Warning: big pictures, click to enlarge
- Clemence
Thank You Clemence.
How to change the optics in JetuE17A/JetuE21A can be found in AppNote 190131
- Clemence
My first review on BLF.
JetuE21A - VERY High CRI AAA EDC - REVIEW
https://budgetlightforum.com/t/-/55442
I went back to look at this picture again, because it’s really cool to see the phosphors glowing under UV light, and I noticed something I missed before:
The E17A’s are all glowing, except what I assume is a blue one.
So I looked up the datasheets to see the spectrum graphs, and sure enough, they aren’t narrow monochromatic peaks, but relatively wide peaks. These are phosphor-converted color LED’s (except the blue).
I’m guessing the appearance is not the intense, highly saturated look we’re accustomed to with color LED’s, but more like a filtered incandescent? I’ve never quite liked LED Christmas lights as much as filtered incandescents, so I think that could be a good thing.
You’re right. Although these colored LED aren’t as bright as normal colored LEDs, they have much wider spectrum coverage. I was surprised too how well I can see under the Red, Green, and Amber E17As. Unlike Blue which has very specific uses. Amber E17A renders color better than LPS and one could mistaken it from 1800K warm white if the object shone don’t contain too much colors. I also prefer PC Red for retaining night vision, because I can still somewhat see different colors better than with true single spectrum red color. Green although very relatively harsh to the eyes, brings out details extremely good and has the best color recognition among the other colored E17A. I can’t use the blue for too long, it hurts my eyes. Blue E17A, just like many failed dedomed LEDs in my collection, very useful for illuminating anything that normally glows under UV.
- Clemence
Indeed, they are very surprising.
For each color, the datasheet has spectrum info at the page 10 (I mention 20% to 100% to 20% intensity of spectrum)
Blue (430nm - 447nm - 465nm)
Green (488nm - 521nm - 583nm) (slight deep blue, no near-IR)
Amber (543nm - 608nm - 691nm) (slight deep blue, very slight near-IR)
Red (598nm - 647nm - 735nm) (no deep blue /but figure doesn't contains range 400-450nm, slight near-IR)
Based on this, probably I need to take a red for sure in my next order
Received a jetusolis 6500°k and 5000°k today (ordered on janv 24 (3 weeks ago)). Thank you clemence !
I usually don’t like cool white then each time i turn on the 6.5k, i need time to get used to it.
Once adapted, i have zero problem to consider it as one reference for colors rendition for myself. I will use it amply for inspections in the next days.
I really appreciate, at least, being able to check colors with a beam without a neutral or warm tint.
I can stand cool white…i’m cured !! :partying_face:
Thank you for your work, tests and dedication to high cri.
Is there an E21A and optisolis, both 6.5k beamshot somewhere ?
What to expect of a triple E21A 6.5k in the FW3A ?
Is it too much to hope for a tir lens combined to your Wizard/Tiara E21A module that would fit the FW3A ?
EDIT : blue tones with the jetusolis 6500°k look real good :+1:
If the Wizard/Tiara quad E21A module fit the FW3A, I’m going to buy a bunch of them! :smiley:
I only have Cree XPE2 Green from my Armytek Dobermann to compare with. You can see the difference between Cree XPE2 pure green LED and phosphor converted green E17A. The much wider spectrum coverage makes for better color rendering other than green itself. Depending on the applications, this could be a bad or good thing.
Note: you can clearly see which is Red, Blue, or Yellow under PC Green E17A. It’s impossible to check colors under Green XPE2 (except for the false orange bottle cap which actually pink under white light)
I can’t stand low CRI cool white, it’s too harsh with no real benefit. With very high CRI cool white, the harshness pays off. Truest whites, clean colorful objects. Here’s the beamshot, taken from the product page:
If someone can give me a detailed technical drawing of FW3A MCPCB, I can do that. What I learnt: E21A only benefit from nano-ceramic MCPCB in tightly packed setup. For conventional wide spaced triple or quad, we only gain 300mA extra peak current which already very inefficient. My early test with heavily cooled direct thermal path confirmed that too. Below OEM rated current (1400mA), E21A is very tolerant to any MCPCB types. Looks like it’s time to make another triple and quad E17A/E21A MCPCB!
- Clemence
I remember reading the FW3A will be using the Noctigon 20mm triple mcpcb and will be compatible with Carclo optic. Are you planning to make a traditional quad for the E21A/E17A to fit Carclo optics?
