BLF GT official support thread [FAQ updated 11 Jan 2018]
OK guys I will soldier I can’t find any dealer for button tops who ships to Bulgaria
https://www.batterijservice.nl/en/samsung-inr18650-30q-3000mah-unprotected-buttontop.html
Thank you so much will contact them!
Since Banggood don’t offer anymore GT70 NW,can you tell me is the CW version too blueish?What Kelvins are they?I am a NW variant fan,but they don’t have it in stock :frowning:
Post 4 of GT70 thread. I added the tint details myself.
Personally I don’t care for the CW version, it does have a blue tint. Although I will say this about any CW light pretty much.
Some like this though as it gives a “light saber effect”
My personal favorite is a 4000k 80CRI in the GT70.
Is it ’angry blue’…. NO, not to me. I prefer NW 5000K - 5500K, but the CW GT70 is not too bad… to me.
I received my GT in May. I have a couple of issues but just noticed one that is more critical (hardly used it yet):
1. Only one battery carrier works. I’ve been running 4 30Q’s and finally tried them in the other carrier. Doesn’t light.
2. Tail cap only spins with heavy force. I linked a fix to this somewhere when I was waiting for mine. I’ll dig that out.
3. I bought the lens cover with the package. Never received it. Moved a few months after getting the GT. Not sure where to turn anymore.
My big issue is the battery carrier. I’ll eventually get more batteries. Now that my attention is turned back to it I’d like to sort out the rest. Is there any kind soul that can provide some advice?
1. Are all the screws tight in the non-working carrier?
1.a. Are the batteries proper contact on the positive end??
2. O-ring is messed up/improperly installed. Disassemble tail cap & install properly
3. No idea
Check the voltage on the carrier. If all 4 batteries are making contact you’ll see 16+ volts. If you don’t see any volts, then maybe one of the batteries are not making contact.
Make sure the carrier is facing the correct direction.
The tail caps where the o-ring is pinched didn’t spin at all, IIRC. If yours spins, just put it in the correct position (in line with the other mount) and your good to go.
Otherwise you can take the sticker off and take the screws out to see what the problem is.
Did you buy the GT through Neal? If you added the cover, then he would usually fit it into the GT box with the light. I would contact Neal and let him know.
anyone know if the GT70 is glued?
This is the original GT thread. The GT70 thread is over here.
I have not heard of any GT70’s having glue added.
Hey guys
Who can I contact if I want to buy just the piece where the BLF GT label is printed on? I have a GT70 and don’t like that name, especially with the GT4 coming soon. I’d much rather replace the piece with one from a GT. Then my collection of GT mini < GT < GT4, makes sense :smiley:
You are talking about the light engine?
Sadly I don’t think that you can get this piece by itself but you could try contacting lumintop and see what they have on hand.
What font is used in the BLF GT logo? I am having a person’s name printed on the side and would like to use the same font.
The button led on my GT Micro is permanently off. How do I turn it back on?
This is the thread for the big GT light. The procedure is the same though. Here’s a video.
Thanks. Kind of tricky to get that timing just right.
Yeah, I’ve got a video that explains the blink system. https://youtu.be/xrwP3gG0I_A
You basically ignore the 2 fast blinks and then count the slower blinks. Then you only have about 2 seconds to do your first button press or else it moves on to the next setting. I recommend changing only one item at a time.
My BLF GT is not turning on.
I have tried to search these forums and also Google and Bing with no joy.
  • I purchased from original buy thread on these forums. Received around February 2018.
  • Batteries are fully charged
  • Button lights up and responds to presses properly (I think)
  • Going through the reset steps in the manual does seem to work as far as the flashes on the button are concerned but the LED just will not turn on.
  • Re-seated the end cap and head multiple times.
  • Battery Orientation is correct
  • Batteries are freshly charged and also close to brand new
  • Also tried different brand new batteries
  • NEVER dropped or physically mishandled
  • NEVER driven at full power for more than 2 to 3 minutes, typically 10-15 seconds at a time during dog walking.
Apologies if this has been addressed and I just suck at searching.
Thank you!
