Nitecore Tip: SEVERE Parasitic Drain in Lock-Out Mode !!
123 posts / 0 new
teacher
teacher's picture
hank wrote:
First they were bad, then they were good, and now … time will tell.
They never were ““bad”“ in the first place. That perception was just created by a few pi$$ed off people posting on the ‘interweb’…… And then others sharing it to spread the mis information. Wink
Time has already told…. they are & have been….. “good”.
Get you some if you don’t have a couple & feel the TIP Clip Luv……. Wink
teacher
teacher's picture
hIKARInoob wrote:
jon_slider wrote:
I agree that the first batch of Tips had a battery drain problem, only when on LOCKOUT
then they got a new batch that did not have the parasitic drain on LOCKOUT
so my question is, are the new batch with Parasitic Drain, doing it only while on LOCKOUT?
If I’m not mistaken, there is no lockout on the 2017 TIP (with clip).
That is correct….. TIP 2017 Does not have lockout. It does have a mode that turns it off after 30 seconds…. if accidentally turned on in a pocket or such. But can be easily overridden in use.
jon_slider
jon_slider's picture
Last seen: 2 hours 4 min ago
Here is the 2017 manual
http://flashlight.nitecore.com/pdf/TIP_TIP-CRI_UM_EN.pdf
it says:
Lockout/Unlock
Hold down both switches until the main led flashes once to enter lockout mode, the product will be rendered inoperative to prevent accidental activation. To unlock, hold down both switches again.
Note: The battery will last for 12 months in standby and lockout mode.
d_t_a wrote:
I have the Nitecore TIP CRI 2017 edition (Nichia). It doesn’t appear to have a lockout mode.
hmmm… yes lockout, no lockout.. I don’t know
MascaratumB
MascaratumB's picture
Last seen: 13 min 19 sec ago
I have a TIP 2017 (XP-G2), and it doesn’t have lockout (only the clip, that avoids accidental turn ON).
And it doesn’t seem to have parasitic drain as well. If I leave it unused for some days, it still blinks the number of times it did when I left it!
More than that, the 2017 version, when clicking both buttons changes the settings from “Daily mode” to “Constant ON mode” (and vice versa), as teacher mentioned above.
This is the User Manual from the 2017 (sorry, can’t take better pictures) Click on them to enlarge the image!
[REVIEWS] AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// ACEBEAM: H20 / TK16 /// BLITZWOLF: BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 / E10 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// KLARUS: XT1C /// LUMINTOP: Tool AA V2.0 + Tool 25 /// LIVARNOLUX: 314791 /// SKILHUNT: M150
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2 /// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
GIVEAWAY: 1
teacher
teacher's picture
Totally correct…… Beer
Thank you MascaratumB for clarifying what I had tried to say… I could not remember the names of the two modes & was not close to my user manual. Facepalm .. Smile
hIKARInoob
hIKARInoob's picture
Last seen: 1 min 50 sec ago
^^^ I just figured out this daily mode/constant on mode. So daily mode switches the light off after 30 seconds (in case it was an accidental activation). So basically daily mode functions sort of like a lock out mode.
teacher
teacher's picture
hIKARInoob…. that is a good way to put it I think. Thumbs Up . Beer
jon_slider
Ok, lets assume there is no parasitic drain of the type this thread was originally about.. related to lockout
but for whatever reason, d_t_a needs to replace a defective TIP, due to it not holding a charge…
d_t_a wrote:
how does one send a short meaningful video of a parasitic drain issue?)
they request a video as part of the return authorization script that they follow
it does not have to be a scientifically verified test, you can just show a video of the unit with dead batteries, and how it won’t turn on. You can speak during the video and tell them that you charged it however many days prior, and that now the light is prematurely drained. Post it on Youtube and send them the link.
it does not matter how good the video is, customer service just has to go through a checklist before giving you a refund or replacement.
I suggest you get a refund.. After that buy another one as a separate transaction.. this will work faster than asking them to send you a replacement..
sorry you got a defective unit, let us know that it was an isolated incident, that you got a refund, and that your new one works fine Smile
hIKARInoob
Cheerio Mr. teacher! Nice seeing you again! Cool Beer
teacher
teacher's picture
Yep… you can do this OR… just do what I have done three times.
Take a couple of pictures, nicely tell them you have no way to take a video, tell them briefly & concisely what is wrong. Tell them your proposed solution to the problem…(make it fair… but easy on you) For instance a replacement in this case.
Be calm, clear, concise, & short in what you write. Stick to you ‘guns’ & accept nothing less.
Has worked like a charm for me….. all three times. Wink
teacher
teacher's picture
You too my friend!!! I hope you are doing well!!! Wink
MERRY CHRISTMAS or (Happy Whatever.. Wink ) ….. take care. . Thumbs Up . Beer
d_t_a
Last seen: 1 hour 28 min ago
Thanks for the suggestions. Will follow through them.
Have been a bit busy lately so haven’t contacted Gearbest yet. I’ll test it one more time just to triple-check. Just fully charged it again awhile ago, will see if by tomorrow morning (24 hours), it gets fully discharged again without any usage.
Clicking both switches does change from “Daily” mode to “Constant on” mode and vice versa (1 flash or 2 flash mode change indicator), that confirms I have the 2017 version.
I seem to be getting poor quality-control items the past days (defective UTorch UT01, now faulty NiteCore TIP CRI 2017, both from Gearbest). Also just received a Convoy BD04 (not from Gearbest but from Convoy official store) that product description says has ‘new’ firmware (I assume that implies Biscotti, the main reason I bought that flashlight), but in actual just has the old firmware Low-Med-High-Strobe-SoS, which I don’t like…
xevious
xevious's picture
Last seen: 10 hours 10 min ago
Dammit… I did not know about this lockout problem.
My TIP CRI was bought in December 2018 from Andrew & Amanda. Color is black, and no other color options were available (only the standard TIP was offered in colors). It did not come with a clip and did not say 2017 on the package. So it must be OLD STOCK.
1st TIP CRI – It would charge, but no light. I sent it back for a replacement.
2nd TIP CRI – Worked fine.
Mine does not behave according to the manual on the Nitecore site. I do not have a “Daily” mode. If I lock it out, it’s off. No single button presses do anything. But if I press and hold both buttons again for 1 full second, the light turns on. This is actually how I prefer it. I don’t like this “Daily” concept they documented.
Anyway, after a couple weeks, I noticed a peculiar behavior happen. After coming out of lockout, light would be on brightest setting. I’d turn it off, and then… nothing. Would not turn back on. Mind you, I had checked the battery level and got 3 red flashes (means above 50%) just prior to this happening. So battery was NOT dead… unless, the indicator was giving me a false reading. I had NOT been using the light extensively, just a few moments here and there for a few tasks. Anyway, I plugged it into the USB port and within a few moments, the light was working again. Somehow the plug-in reset it. Power level? 3 red flashes.
So… this happened once again about a week later. Same procedure. Worked again.
TODAY… different story. Took it out of lockout, was on bright, pressed mode to step down and OFF. DEAD. Would not come back on, even after plugging it in. Let it charge for 30 mins, then unplugged. Still NOTHING.
teacher
teacher's picture
I ‘think’ they fixed the “lockout problem” a long time ago, this is an old thread.
Not sure what is going on with yours though.
xevious
xevious's picture
It seems that I got an old stock version. I went to Nitecore’s site and sure enough… I see they’ve expanded it and even included a clip. Mine did not come with a clip. So, mine must be from an earlier, problematic release. I created a video to demonstrate the issue and forwarded to Nitecore. I’m hoping that if they have any semblance of good customer service, they will send me a Nitecore 2017 replacement. I will not accept another V1… this is my 2nd one in a row with problems.
teacher
teacher's picture
Could very well be. Where did you get it, if I might ask?
xevious
xevious's picture
I bought it from Andrew & Amanda. First one was DOA… charge indication lights worked, but it would not turn on or show battery charge level. I had to send it back at my own cost to get a replacement. And that worked for a few weeks until now. I double-checked their site and they’ve got plenty of Nitecore stuff there, but it seems all the TIP lights are pre-2017. I’ve notified them and asked for a refund. I do not want to get a 3rd light and go through this crap again. I’ve also contacted Nitecore. Now, if they’ll authorize a 2017 replacement, I’d be OK with that, except I do not want to be obligated to pay shipping — that’s just not right. I’ve already wasted too much time on this situation…
teacher
teacher's picture
Thanks for the info, hope it works out in your favor. Thumbs Up
mmalive
Last seen: 6 months 3 weeks ago
Have you tried removing battery from light? Carry alone and put battery back in when needed. That would help drain. I remove batteries and only put them in when ready for use.
Pete7874
Pete7874's picture
Last seen: 1 hour 1 min ago
The battery in TIP is non removable. Or at least not easily removable.
hank
hank's picture
Last seen: 2 hours 52 min ago
A’n‘A has long had quite a presence here at BLF. Surely they’ll make good on this.
https://www.google.com/search?client=firefox-b-1-d&q=site%3Abudgetlightf...
mmalive
WOW!!! Surprised of the Engineering for this light. How do you repair or service if you can not take apart light? Come on Nitecore !!!!
teacher
teacher's picture
It can be taken apart mmalive. 4 screws does it. It would just not be practical to take it apart & remove the battery daily, as you suggested somewhere above. Wink
mmalive
Cool, thanks teacher. I do not own light. I am giving background from engineering stand point for OP. True NOT practical and you wear out screws attaching/removing on constant basis.
teacher
teacher's picture
/\……… My pleasure my friend!! . Thumbs Up
xevious
xevious's picture
To follow-up, Nitecore “piddled” with me… sent me a photo of their “samples” and really didn’t say much of anything.
Their samples actually look better. They didn’t say if they felt a sharp edge or not… fail. But this all pales in comparison with the complete and utter functional failure of my light. A&A is taking my light back, but they claimed the behavior is because of the documented parasitic drain. But that’s just flat out wrong. I took a video showing the light fully charged, I take it off the charger, and the light will not come on. No way, no how. Tried all the documented button press commands.
So I’m mailing it back… AGAIN. And again, out of my own pocket. So now, I’m $8 in the hole from this and no flashlight. $8 “rent” for 3 weeks of use, I guess. That’s expensive.
While the TIP is a budget light, it’s still not their cheapest model. Should receive adequate customer support. Maybe it varies depending upon the person. I just received another email and they’re saying “well see what we can do—send your proof of purchase.” So I did… hopefully I’ll get some satisfaction.
Pete7874
Pete7874's picture
What’s the deal with sharp edges? I don’t recall you mentioned anything about this before. Sorry if I missed it.
Mine isn’t exactly smooth either.
xevious
xevious's picture
Because this light has a 2-piece body with a lateral seam, there’s a challenge in designing it so that they fit together seamlessly. Nitecore compromised with a kind of “lip” that slightly overhangs the front. However, there appears to be enough variation in part production such that in some cases, a top half doesn’t match up well with the bottom half. In my case, it’s exaggerated enough that I can feel the edge when I hold the light. At the corners, it’s actually a little sharp… not enough to cut, but enough to scrape skin.
I can see in their photo, the two pieces line up better, so it probably doesn’t have a roughness/sharpness to it.
Pete7874
Pete7874's picture
Thanks. Yeah, that looks like a poor fit.
For comparison, this is my TIP Winter Edition. The fit seems slightly better than yours, or at least I don’t feel any sharp edges.
xevious
xevious's picture
^ Yes, that’s exactly how it should look. I think there’s some variance in the machine stamping of the parts. When that happens, it means that another step in assembly is involved, where parts have to be matched based on size before assembly. Otherwise, you can end up with some units where the greatest variances (smallest and largest) parts are put together, resulting in what happened with mine. QC may be spotty, so some sneak through.
