I'm currently on the list at 950 for one. I've decided I'd like two total, one of each emitter. (I will probably mod the one with emitters I like less!)
Nice Quick work Maukka, well done!
Nice looking light, no doubt about it…
What about wait 10 minutes til your eyes do the automatic white balance thing?
wow great info, looks like this will be a very nice light for very little money.
Hm, to me this is not very Lidl money.
I would rather call it: ……………. a relatively modest amount of money.
[/quote]
As far as I am concerned… Neutral ’should’ be “Pure White”, as close as possible; without adding warm or cool tints.
[/quote]
My definition of pure white would be like a white piece of paper but I know the definition may vary.
Great pics, cogs turning
No snapped optic legs here…
So, did Lumintop tell you when the light will be revealed/be able to buy?
I’ll be buying one the second it goes online.
Also, could you check with a magnet if they are steel springs or not?
They look exactly like the BeCu spring from the GT Mini.
What a lovely looking little light. Can’t wait to get mine.
When I put my name down for one, I didn’t choose the emitter. Do I need to say what I want now, or do I get given the choice once the group buy activates?
Wow…. very nice!!
Thank you for the detailed report & great pictures maukka. .
Very nice! Noob question: what does the “1” in “1+6+FET” represent?
1x7135+6x7135+FET driver.
It’s a triple channel driver.
You can get very low moonlights with 1x7135 mode.
You can get an efficient 1000 lumen with 6x7135.
You can get max power with direct drive over the FET with 3000+ lumens of output.
Ah gotcha, thanks!
I am on the list for 1. Can you update that to 3 with the LH351D.
TK corrected me and said it’s actually 1+7+FET. Two chips on the other side.
2 Questions for anyone able and willing:
- Please forgive if this an ignorant question……but as far as “modes” or “brightness levels”, does this go up to the 800 lumen range Maukka noticed and then it’s only the full on TURBO after that? Or is there ramping from the regulated 7x7135 mode up to the Turbo (ie. can we go up to say, 1400 lumens-ish or 2000 lumens-ish and stop there, without going all the way to turbo?) ?
In reading on Anduril on the OP page…it appears infinite variable brightness….but just wanted to make sure I wasn’t misunderstanding.
2. The optics. It appears there are several easy swapouts (some mentioned to be sold by MTN on a previous page here). Is it as easy as screwing off the bezel and swapping? Or is there glue or other tools involved?
TIA!
