300 watts!
That thing can dissipate 300 watts?
I don’t think so without the inevitable thermal throttling after about 2 mins<.
besides who would go swimming with a light like that. one would need a flotation device.
That light has been done before by Acebeam and Imalent, except they added a fans.
Yeah take my money but I want to be able to use the thing for more than 2 minutes at 20kl, or tell the costumers that max sustained output is really 12kl or whatever how much thousands less it can run passive until LVC.
BTW, Lumintop I believe makes some the best lights, I think they could pull off a cooler running solution to the GT4
what makes the gt4 different then acebeams x45 that does 18k lumens and has also 4 x xhp70.2 emitters? and on highest it can run like 3 min or so before stepdown ? but the gt4 has more massive heatsinks so it should run longer and handle the heat better. I dont think adding a fan is a good idea, its clumsy and doesnt really help much its better having a giant heatsink body instead.
lets just wait for lumintops runtimes after CNY and see how it will perform.
The GT4 will be like the GT and GT70, setup for easy mods down the road. Although CFT-90 will not be a factory option for sure, just far too complicated and costly to be practical.
I am positive that there will be custom mods with this though.
$15 per 70.2 vs $100 per cft-90. Also maybe $25.00 for 70.2 driver vs unknown amount, but I would estimate at least $100.00 for cft driver. Also, don’t forget that the 70.2 will have more output but lower luminance than the cft90 at max current. So most likely at least 400.00 more than asking price for base gt4 for a cft90 light would be what I would expect. If custom sourced it will be more.
Not as simple as that. The highest bin currently available to buy is around $116. Then you somehow have to cram at least a 400W driver in that head. Luminus claims a maximum current of 27A for the CFT-90. and it has been tested at over 40A but with active cooling. I think it’s better to just have one CFT-90 emitter and take advantage of the increase cooling of the GT4 head so the LED can be driven to its full potential, instead of having four under-driven LEDs. Even with one, it won’t be a long-sustained max output. But I think it would be far better with this as a host than the original GT.
R90C with coupon is about $280. I tested two of them with the TA tube with Maukka calibration. Turn on lumens was about 14k for one and 13k for the other. Newlumen tested his R90C at 16k lumens with the same calibration. The GT4 should make 20k+ lumens but throw might be a bit less than the R90C, unless the domes are shaved.
