[/quote]
As far as I am concerned⊠Neutral âshouldâ be âPure Whiteâ, as close as possible; without adding warm or cool tints.
[/quote]
My definition of pure white would be like a white piece of paper but I know the definition may vary.
[/quote]
[/quote]
Great pics, cogs turning
No snapped optic legs hereâŠ
So, did Lumintop tell you when the light will be revealed/be able to buy?
Iâll be buying one the second it goes online.
Also, could you check with a magnet if they are steel springs or not?
They look exactly like the BeCu spring from the GT Mini.
What a lovely looking little light. Canât wait to get mine.
When I put my name down for one, I didnât choose the emitter. Do I need to say what I want now, or do I get given the choice once the group buy activates?
WowâŠ. very nice!!
Thank you for the detailed report & great pictures maukka. .
Very nice! Noob question: what does the â1â in â1+6+FETâ represent?
1x7135+6x7135+FET driver.
Itâs a triple channel driver.
You can get very low moonlights with 1x7135 mode.
You can get an efficient 1000 lumen with 6x7135.
You can get max power with direct drive over the FET with 3000+ lumens of output.
Ah gotcha, thanks!
I am on the list for 1. Can you update that to 3 with the LH351D.
TK corrected me and said itâs actually 1+7+FET. Two chips on the other side.
2 Questions for anyone able and willing:
In reading on Anduril on the OP pageâŠit appears infinite variable brightnessâŠ.but just wanted to make sure I wasnât misunderstanding.
2. The optics. It appears there are several easy swapouts (some mentioned to be sold by MTN on a previous page here). Is it as easy as screwing off the bezel and swapping? Or is there glue or other tools involved?
TIA!
1. All of that is configurable. Itâs just that the default stepped ramp mode goes up to the 800 lumens and to turbo from there with a double click.
2. Easy to swap MCPCB and LEDs or optics (Carclo), no glue.
Maukka, thanks for the analysis, and the good hard work you have contributed to this project!
I plan to purchase this version of the FW3A, but would like increase the throw. I get about 12000 cd from my current EDC Thorfire TG06S and would like to at least duplicate it with my new FW3A.
Approximately how much throw would be gained by going to a clear lens? Are there any other easy mods that would further increase the throw? Thanks!
Shouldnât turbo be closer to 3000lm though?
The lowest mode is approximately how low?
I hope the muggle mode goes up to the 7*7135 level.
Is the build quality of the D4 better?
Iâm down for one.
Please count me in for one of each:
I havenât tested different optics with the XP-L HI yet, but will post numbers later with the 10507. Youâll probably gain about 20-40% more candela.
