Several months ago i bought 3 Osram Flat black and now I decided to put in Convoy L2 with LD25 constant driver tuned to 5A
Driver hook up with XML2 for testing current purpose. Didn’t want to kill my Flatblack during testing.
Driver with 20mm brass ring adaptor
Beamshot at 8m with perfect focus. Thanks for the orginal centering ring and I didnt to do any focusing.
inside reflector
Took lux reading 8m and it gives 3850 lux. This equivalent to 246k candela.
I also did mod with convoy C8+ similar setting and it have slightly lower candela but not much. Considering the size for pocket I definitely think C8+ is perfect reflector size for this LED throw and it’s a winner
Wieselflinkpro, it’s the SupwildFire 7x shown in THIS post. I had to make an aluminum filler for the hollow head, changed the large MOSFET, bigger leads, spring bypasses, and of course the emitter swap. Will probably do individual copper DTP 16mm MCPCB’s as a final tweak. This has been another incremental mod light, recording each step along the way to see where the gains come in…
I made a flat white 1mm² in my convoy c8. The gaskets from int outdoor are for a 7mm reflector but i used it anyway. After turning the bezel a couple of times i got a pretty good beam. Uses a single mode nanjg driver with 3.04 amp. It gets pretty Hot after 60 seconds.
Top is the flat white and bottom a c8 with xpl hi and fet driver.
I used a lightmeter app on my phone.
utorch ut02 xhp 35 got 120k candela
convoy c8 xpl hi fet got 69k candela
convoy c8 flat white got 169k candela. Its at around 3amp so a little heigh meisurment i guess.
Since this is my very first 'essential' post here, I'll shortly indtroduce myself...
I've been AF (Anonymous Flashoholic) since the middle 2017. At least this is the date I've started to read BLF and even worse - started to buy ... THEM !
Yes..., I know I should not, but... I buy THEM because they are cheap, sexy and ... available . Someone, please help me to stop this...
Looks like, I'm especially in love with Convoys S2+ (well... basically it means - whenever price drops below 9$ I buy them, sometimes I manage not to do so). For this price man can buy only 'basic' 6x7135 XML2 Grays... and it's ok for an addict like myself (guilty me, once a month you have to take your dope)
Of course, last year it happened to buy some other stuff as well (2 Convoy's C8s and 1 C8 from Sofirn when they droped below 15$, and 2 SP33's lately on Christmas for the less then 20$ each) but you know what they say - the first love is the biggest one and for forever...
OK, now to the point - this about my first mod.
Let's call it "Quick and dirty 2S (2x18650) mod to 2S+ "
The background...
1) To many 'grey' S2+ on my shelf. To many to take everyone and each of them for a walk from time to time
2) Plenty of 18650's (many of them not so modern high drain models)
3) The curiosity - what the XHP family (or the other high output 6v Leds) can do inside my little beloved one ...
The obstacles...
1) Mainly there is one.
Why the heck they don't produce and sell extension tubes in a most common size (18650) for a most common flashlight (S2+) on the planet ?
You can easilly find them for L4's, C8's and many others but not for S2's !!!
The decision...
One of my sweethearts must die... to give the birth to something bigger...
The result...
Remove everything form inside the head of S2+ and cut it exactly in half (I did it with a dremel tool)
Now, you have a muff wich will hold and connect two original body tubes of S2+'s. The thread must be milled out 3-4mm deep from one side of new muff (one where was a cut made) for the best matching with the original tubes. Do a final polish to the sharp edge with some sand paper, and we are done with hard metal tooling...
About the LED...
I've choosen XHP50 (it has good output, it is efficient in low current, it has high Vf value which should ease a load on my 7135's and it was ridiculously cheep to get.
About the driver...
I've decided to keep the one what I have had form inside a donor light (costless solution).
I had no suitable electronical components for a 'Zaner mod' modification, so in my case the original Convoy's 6x7135 dirver board was used as a simple 'one mode' linear 2.1A current regulator.
To make it work:
1) Remove D1 from original driver board (the same element which you remove to place 200Ohm resistor in classic Zener Mod) - this will disconnect excessive (+8V) power voltage from the MCU (we may need it in the future...)
2) Connect VDD leg of any AMC7135 (one of them is enough because all AMC's are in parallel) to +Vin - this will open a full throttle of all 7135's (6x350mA)
For my current needs it suits good enough to have one "high" mode only. Latter (e.g.when I get a proper Zener diode) I may consider to restore MCU functions for this driver.
Since basic Zener mod destroys the proper low battery protection then you may try to restore it by modifing the board (cut of the trace with the original R1/R2 voltage divider and build a new one which would be powered by +Vin). An example was given - e.g.look for "The IMR Enhanced Zener Mod to run the MT-G2".
So how does it looks like ?
Pros:
1) Twice as much 'floody' lumens comparing to original design (for 2.1A XHP50 gets 1560 lumens vs 800 lumens for XML2). You can really see the difference in the dark.
2) Does not need expensive high drain accus (like when you power up XHP from a single 18650 cell) or some fancy low capacity and high price 2x18350. It comfortably sucks 2.1A from every low cost 18650 I have in my drawer.
3) It gives similar running time to original S2+ with more light
4) It is still very convenient in every day use. It's size is just 43mm (1.7inch) more then C8. Fits well your pocket since it is as thick as an orignal design. And feels good in your hand.
5) It was planned to be "zero" cost mod. And in fact it is (almost). I had to "sacrifice" one of my Grey's (cut off the head) but it was worth it. I bought XHP50 on a 17mm copper mcb some months ago for 2.5$ on AliExp (4.5$ including delivery! minus 2$ coupon)
6) And it's still "my precious..." S2++
Cons:
1) Of course, it is not so cute and handy as a original S2+ beauty, but still close to my liking.
2) Get's a bit more heat in 'high' mode.
This should not be a big issue since the original design has some redundancy and is pretty safe with 8x7135 and XML2 pill (power used by XML2: 2.8Ax3.4V=9.5W plus power lost on 7135 regulators 2.8Ax(4.3V-3.4V)=2.5W makes 12W loss in total) and mine has 6x7135 and XHP50 LED (power used by XHP50: 2.1Ax6.3V=13W plus power lost on 7135 regulators 2.1Ax(8.4V-6.3V)=4.4W makes 17.4W loss in total).
Not a big difference (5W more), but the body of moded S2 is now longer so the heat dissipation should be also a little bit better.
This post has been written by a beginner (myself) and for beginners, so all experts and advanced users please be gentle or just skip it...
That is a very clever mod btbw!, and welcome to BLF. Since I do not know electronics very well I can not judge what you did to the driver, but it works so you did the right thing , am I correct that the voltage on the 7135 chips is outside the specs? (but who cares if it works?).
Yes that’s correct. He could minimize the risk by adding a 1000ohm/900ohm voltage divider in the input pin to drop VIN to 4v (well within spec). They’d still be regulating out of spec but the input signal would be below their max. Should prolong their life a bit.
This old EA41 has hosted my pukelight a while now but it’s not actually very useful as a flashlight. Not wanting to take it apart and bulld the host into a more serviceable flashlight I just let it sit on the shelf for the last 4 years. Sentimental reasons I guess, it’s the first one I built and I went through all the heatsink I had machined so I couldn’t ever make another…
Well I scribbled out a circuit drawing last night that I thought might work and sure enough it did! I now have 2 triple channel drivers and their very different from each other UI’s working together! I got it to work by using the PL drivers 6x7135 channel for white as the Nx7135 channel on the TA driver, diodes keep the output signals from each MCU from reaching the other MCU pin and from conflicting should they accidentally get switched on at the same time. Conveniently PL can be controlled from a single button (it was originally 2 button since the EA41 has 2 buttons) so switch could be available for each driver and the anduril driver got control of the switch LED.
Even though it was a working light with a working driver I still built a fresh one because reasons.
Darn I forgot to take pictures of the cross-talk prevention diode placement, talk about surgery!
“Pukelight” was a multi colored strobe / flashlight I built and marketed to LEO & security companies (they sold pretty well) back when I was doing flashlights professionally.
The concept is legit, randomized color and flash patterns of light help disorient. The military uses it, its so effective travel companies sometimes even use them for customers to find out if they get seasick before booking a cruise. It’s not actually designed to make you vomit or anything like that, just disorient.
As a handheld unit it’s pretty much outdated tech now cause pocket size flashlights with 3000+ lumens exist and with that much shear power white light is just as effective at disorienting…
I think running on AA’s was it’s best selling point, I would include a couple sets of L91’s and I know a lot of guys were already running NiMH too so they didn’t have to deal with Li cells.
Note it is now my second NiMH powered anduril light!
