Great shots. They make me miss the snow, for a minute.
I am interested in the xpl-hi version. Is someone able to add me? Thanks.
Maukka! Very nice beam shots and comparison! It’s really cool to open both pictures and click back and forth in full screen to compare….so cool to watch the minute differences in shadows etc. Looks as though the D4 beam is ever so slightly wider, which makes sense…but not much wider. Unless the angle of the lights was just a touch different when pics were taken (can see shadow of small twig on lower right in foreground move up and back just a bit…like the D4 was just an inch or 2 more forward than the FW….but again…probably just the wider beam of the D4).
I’m babbling…sorry…again…THANK YOU! Very nice shots and comparison.
I was joking lol, based on the discussion on what to call the Carclo and the glass pane in front of it… it was always planned to have a triple Carclo TIR optic and a glass window/lens in front for protection. So no, none of this discussion would drive the price up
Snow is proof that where you are is too darn cold!
That is a very good way to put it. Been there, done that.
I’m getting really hyped for this now! I have a couple of questions about the FW3A that I’m curious to know answers to. If anybody can chip in with their wisdom, it would be much appreciated!
1) If we were to compare the FW3A to a similarly sized flashlight known for efficiency, such as the Zebralight SC64, would the FW3A be roughly as efficient? One of the main reasons I’m hyped is because of the higher regulation on the FW3A vs an Emisar D4, but I’m not very well versed in how it all works so I’m trying to gauge efficiency by using examples of well known flashlight models in the community.
2) In ToyKeeper’s Emisar D4 review, she listed all of the ramping steps. These seem to be the same on the Emisar D4S and I was able to use them to configure my D4S’ stepped levels very specifically. Will these steps also be the same on the FW3A, as it is running Anduril? I’d like to be able to set my ramp ceiling right at the highest regulated mode for efficiency, and it is nice to know where that is exactly.
Many thanks to everyone on the FW3A team. What a fantastic device you have conceived!
Thanks folks, I remember reading the original specs quite some time ago, but can’t remember the specifics now. Unfortunately, I didn’t realise at the time there was a link to the specific carclo optic used, and I’m nowhere near technically proficient enough to know this stuff offhand. Thanks for the help.
As someone else mentioned, I’d be keen to buy a spare clear optic if this became an option. It does sound though from what Toykeeper, Jason and everyone is saying the original optic is the way to go.
1. The Zebralight would still be more efficient than buck/boost driver. LED efficiency would be better than a single 3V emitter light, but driver efficiency will not be as good.
2. It should be higher since it’s using a 1+7+FET driver, instead of 3+FET.
Looks like Iowa. Thank you.
Wow chadvone, looks like your in the middle of a ‘Deep Freeze’… Your whole state is below 0° for the whole day today…. :person_facepalming: … I imagine you are well aware of that tidbit of info though.
It is much warmer in most of Alaska than Iowa, as well as most of the Midwest USA today.
Turn those lights to TURBO & keep those hands warm….
Good luck & hope the pipes don’t freeze & burst.
Edit:…… “below 0° ” = Below Zero Degrees Fahrenheit ( 0° F ). As in —18, —11, —9, —17, and so on for their High temps today. Lows tonight will be in the negative (-) 20’s & 30’s F. .
It hurts me even thinking about that…. :person_facepalming:
^ Thanks teacher.
I really love the Eagle Eye X6 flashlight, have far too many of them… all in different configurations. I priced an AR coated Sapphire “Window” in 35mm at $195 each. Having a “window” could indeed drive the price WAY up!
Been watching this for a while now!
Please put me down for two, one of each.
I suppose going off topic in this thread is completely acceptable, or maybe the norm, so just out of curiosity, Dale, what is your brightest EE X6, and which is your current favorite? I ask because I have a couple I love as well.
Thanks for the explanation!
After seeing the awesome updates I am totally regretting canceling my second light.
Please go ahead and add me in for another light, bringing my total back up to 2 lights.
And thank you again!!
- If we were to compare the FW3A to a similarly sized flashlight known for efficiency, such as the Zebralight SC64, would the FW3A be roughly as efficient? One of the main reasons I’m hyped is because of the higher regulation on the FW3A vs an Emisar D4, but I’m not very well versed in how it all works so I’m trying to gauge efficiency by using examples of well known flashlight models in the community.
1) The Zebralight will be more efficient due mainly to their buck drivers, versus the linear regulators in the FW3A. Here’s some examples of measurements Maukka has done:
SC64C (90 CRI XP-L2): 140 lm/W on lower output, 106 lm/W on high.
I tested some non Easywhite binned 4000K XP-L2s a while back and found the CRI90 versions to be green/yellow in tint while the CRI70 versions were quite alright. Both suffered from the tint shift within the beam i.e. the Cree rainbow. The 2-step CRI90 XP-L2 in the Zebralight SC64c should guarantee a nice tint, but several reports from users have indicated otherwise. Fortunately a fellow flashlight enthusiast loaned me his SC64c for testing. He has already decided to return it as he was spoiled …
Emisar D4 (80 CRI 219C): 84 lm/W at regulated channel, ~67 lm/W on medium FET
After getting to know the new sphere a little better (adjusting baffle and auxiliary light, trying different input port diffusers etc) my numbers for the D4 got about 8% higher. Max output is as follows: VTC6: 3345 lm (480 lm at 30 sec) 18650GA: 2980 lm (895 lm at 30 sec) Aspire 18350: 2880 lm (1570 lm at 30 sec) Efest 18350: 2460 lm Enercig 18350: 2630 lm Here’s the new graphs [image] [image]
There is, of course, a ~2x difference in price, and you trade Anduril for a different UI (although one that is still well-liked by most users).
- Edit - Since Maukka now has numbers in his review, the FW3A with XP-L HI showed 93 lm/W at max 1x7135 channel, and 85 lm/W at max regulated level.
2) The default ramp ceiling for both smooth and discrete modes for the FW3A build of Anduril is the maximum regulated level.
If you want both channel boundaries, for the FW3A specifically, you can set the minimum ramp at level 1, the maximum at level 130, and 7 steps. This will result in mode 4 being the maximum 1x7135 channel, and mode 7 being the maximum 7x7135 channel.
It’s not really a fair comparison. XP-L2 is very efficient, 219C not as much.
LH351D right up there with XP-L2 in efficiency and the additional 7135’s add more efficiency to the medium modes.
This frosted lens will also be a few % worse too. In any case the Zebralight will still probably be more efficient but the FW3A will be closer and have a better range of efficient modes as well.
And half the price with a far superior UI and rear tail clicky.
