JasonWW
(JasonWW)
January 31, 2019, 7:08am
6780
Searching around on Google I found the below angles (not official):
The 10511 is called a narrow spot. 22°
The 10508 is called a medium spot. 27°
The 10509 is called a wide spot. 40°
All of the above are frosted.
The 10507 is the non-frosted, clear version with a narrow spot. 18°
I think it’s fair to say that the angles might vary a little based on which emitter is under them. So I would view the above angles as a loose reference guide.
maukka
(maukka)
January 31, 2019, 6:42am
6781
JasonWW:
Since I measured 28° (FWHM) on mine, it’s probably the 10508 in the sample.
edit: Carclo doesn’t specify the angle for the XP-L HI, but the 40° would be too wide a beam for it to come down to 28°
DrHook59
(DrHook59)
January 31, 2019, 9:48am
6782
Yourrid:
For me, it’s about output first and foremost. If we could pack 30,000+ lumens into a package the size of an Emisar D4 with a 18350 tube that (somehow) doesn’t get hot SUPER quick, that’s what I’d like to see.
- you forgot to add that it needs a runtime of 8 hours at turbo, too
- and have the ability to make hot chocolate from snowdrifts
- and must be able to use the full 30K lumens in a strobe rhythm that will bring down UFO’s and send grizzlies back to the mountains bawling their eyes out
- if it could also find its way home when lost, that would cool, too
lightboks
(lightboks)
January 31, 2019, 11:37am
6784
Hi. I was in for one in post 1630.
I take another one. So one of each tint please.
Tex_Tbone
(Tex_Tbone)
January 31, 2019, 3:12pm
6785
Please put me down for two.
pennzy
(pennzy)
January 31, 2019, 3:41pm
6786
As I suspected, a little positive reinforcement and the orders are rolling in.
mortuus
(mortuus)
January 31, 2019, 3:43pm
6787
can someone make a short video of it perhaps just too see ?
asciiphil
(asciiphil)
January 31, 2019, 3:58pm
6788
I don’t see any vias for flashing firmware in maukka’s pics, so I’m guessing we’ll have to disassemble the head for that. Is that right?
SIGShooter
(SIGShooter)
January 31, 2019, 4:46pm
6789
Please put me down for one with the XP-L’s.
Thanks
m0nk33
(m0nk33)
January 31, 2019, 5:00pm
6790
Interested! Please put me down for two!
joechina
(joechina)
January 31, 2019, 5:35pm
6792
Yes.
Vias for flashing are a quite new concept for the BLF lights and this light is nearly two years in the making
nvanlaar
(nvanlaar)
January 31, 2019, 7:40pm
6795
JasonWW:
I don’t know the beam angles, but the hot spot diameter is what changes. The wider the spot, the less throw distance.
They should be very easy to swap out.
For people in the USA, all these are available from MTN E
I’ve actually found LEDsupply to be cheaper. They have free shipping on all orders. Even on a single optic. And it is fairly quick, ~3-4 days to my mailbox.
teacher
(teacher)
January 31, 2019, 7:54pm
6796
Thanks for the tip about LED SUPPLY nvanlaar!! Cheaper & Free Shipping seals that deal…. :+1:
teacher
(teacher)
January 31, 2019, 8:17pm
6797
@ DB Custom…. What is the advantage of the Sapphire “Window” & why is it so expensive??
I did a search for Flashlight Windows and came up with nothing.
I did a search for Flashlight Lens and came up with Flashlightlens.com ….
But unless I missed it, there was no info on a Sapphire “Window”.
Just curious about it’s advantage & high cost.
cabfrank
(cabfrank)
January 31, 2019, 8:40pm
6799
It should be highly scratch resistant, for one thing, but it is also more prone to breakage than mineral glass.
