[Sale] Buck drivers 20, 21, 22, 24, 30mm L6, MF01, MF02/04(S), TN40S/42, BLF GT, Acebeam X45/65
I did some testing today
with the usual 12V XHP70.2 driver setup I can drop the input voltage on the driver down to 13.6V before we drop output below 6A to the LED
Where can I buy driver for my astrolux mf02 ?
Please where can I buy a driver for my astrolux mf02 .link pleaseee?
I’d like 2 of the BLF GT Oslon drivers…
You are at the right place. Lexel makes them himself. He will contact you in the next day or so. Maybe today.
Ok thanks
Any buck driver for the D4S?
not possible for that light, the driver cavity is too shallow and there is no high current buck atm
V2 MF01 prepped for Buck driver
Hi Lexel,
ich würde gerne einen Black Flat Treiber für die BLF GT kaufen.
Merci
I have a report of a DOA delivered driver
It was within Germany and he sent me the whole light
The driver was fine, just the new thermal enhance design does not allow a bad soldering job on the LED+ terminal
here clearly can be seen that the wire solder blob also touches the ground viases that are about 0.75-1mm next to the pad, the buck chip detects short and stops output
best is to solder the wire straight up or 180° rotated pointing to the capacitor so the ground plane is clearly visible and no short risk
Any idea how deep driver cavity is? I think there are some good coils that are 3-3,5 mm height.
you can not pass 12-15A through a 3mm high coil
I know that coil characteristics degrades while heat increase so there must have some addition over threshold, but how about Coilcraft XAL7030 series? Are those still to weak?
Definitely interested in the BLF Q8 XHP 35 driver. May need 2 or 3 of those. Where do I get the MCPCB for that?
The stock MCPCB is fine. Your problem is converting the light from 4P to 4S. Not simple when they dont use carriers.
How is that even possible without carriers? Lexel how did you get that to work?
You have a driver with 4 pads that make contact with each battery separately. Then you permanently fix the battery tube into place so the battery ends line up with the driver pads. Then you modify the pcb in the tail cap. This will supply 12 volts to the driver, but you have to load the batteries through the tail by removing the PCB each time. It’s a pain to swap batteries, but it works.
[/quote]
[/quote]
you can also build a rotating tail board with 2 pins that uses a bolt to hold to the tail cap
I’ll try to fix the qoutes.
