Yes.
Vias for flashing are a quite new concept for the BLF lights and this light is nearly two years in the making
I would like to buy one.
I would like to buy one!
The 10511 is called a narrow spot.
The 10508 is called a medium spot.
The 10509 is called a wide spot.
All of the above are frosted.The 10507 is the non-frosted, clear version with a narrow spot.
I don’t know the beam angles, but the hot spot diameter is what changes. The wider the spot, the less throw distance.
They should be very easy to swap out.
For people in the USA, all these are available from MTN E
I’ve actually found LEDsupply to be cheaper. They have free shipping on all orders. Even on a single optic. And it is fairly quick, ~3-4 days to my mailbox.
JasonWW:The 10511 is called a narrow spot.
Thanks for the tip about LED SUPPLY nvanlaar!! Cheaper & Free Shipping seals that deal…. :+1:
……. _(snip) ……. I priced an AR coated Sapphire “Window” in 35mm at $195 each. Having a “window” could indeed drive the price WAY up!
@ DB Custom…. What is the advantage of the Sapphire “Window” & why is it so expensive??
I did a search for Flashlight Windows and came up with nothing.
I did a search for Flashlight Lens and came up with Flashlightlens.com ….
But unless I missed it, there was no info on a Sapphire “Window”.
Just curious about it’s advantage & high cost.
Bullet proof?
It should be highly scratch resistant, for one thing, but it is also more prone to breakage than mineral glass.
At the rate flashlight technology is advancing, it won’t be long until someone installs Windows on their driver…
That’s probably true Klayking……
Exactly, quite the opposite of bulletproof actually.
I can see it now. You’re exploring a cave and decide to turn off the flashlight for a moment to appreciate the total darkness. When you try to turn it back on, Windows catches you with the ol’ “Please wait, installing update 1 of 24…”
Or a wall of blue light from a BSOD
Ain’t that the truth…… :person_facepalming:
Or when you try to turn it off it hits you with the “Do not turn your machine off, downloading updates…… ” .
BSOD…… :+1: … :person_facepalming: …
DB Custom:……. _(snip) ……. I priced an AR coated Sapphire “Window” in 35mm at $195 each. Having a “window” could indeed drive the price WAY up!
But unless I missed it, there was no info on a Sapphire “Window”.Just curious about it’s advantage & high cost.
Sapphire watch glass should bring some better results
And so it did joechina!! Thank you for the tip…. :+1:
I see now why it is good & pretty expensive too.
Everything You Wanted To Know About Sapphire Glass, But Were Afraid To Ask [Q&A]
Sapphire glass is a synthetically produced crystal second only to diamond in its hardness, making it extremely durable. It is typically grown in cylindrical sticks called boules, and is slow, expensive and energy-intensive to produce.
Put me down for two please!
teacher:I did a search for Flashlight Windows and came up with nothing.
Windows? That is just asking for trouble. Your flashlight will just crash without reason. You will have to call Geek Squad to remove spyware and malware from your flashlight. Or you will get an email telling you to send bitcoins to someone that is holding your flashlight software hostage. Some 12 year old kid halfway around the world will be turning on your flashlight remotely in the middle of the night.
Just a quick gif to show something cool the button does…
(apologies for the large file size, slow loading, and shaky camera)
(edit: moved to imgur for faster downloads)
I’ve actually found “LEDsupply”:Triple - Carclo LED Optics to be cheaper. They have free shipping on all orders. Even on a single optic. And it is fairly quick, ~3-4 days to my mailbox.
Thanks for this tip nvanlaar!
At Mountain Electronics there is an XP-L mod option that can be added when purchasing a Carclo 10507:
Anyone know what this option is about? Thanks.
