Okay well, I am getting 2825 so I guess that’s right on par. I was just really not expecting it to be that low. Thanks for the data men!
Texas_Ace BLF Calibrated Lumen tube / Sphere No math skills needed - Several spheres still available
Maybe TA could change the name to the lumen heart breaker tube. I know it’s broke mine a few times. :confounded:
That’s about right… I have a l6 from skylumen… one single mode and it read 3100 lumen.
Those were exactly my thoughts when i took my reading, thought there was something wrong with my lumen tube. Thanks for sharing your result.
I should also point out that my tube is not a TA one. It’s one I made, which I think validates the idea that were all heading in about the same direction.
Is your result at turn on or 30 sec?
I get just above 2800 at turn on & 2770 after 30 sec
Yes. All my results are at 30 seconds unless otherwise stated
Hey Matt, have you used your new lumen tube to measure the gbx3590 GT you built? I think the led is rated for 3.6A (14,000 lumen), but the driver can only do 3.2A so it’s not being pushed hard. I’m curious what you measure. At least 10k lumen? Maybe 12k?
I did play around with it. IIRC it gave me right at 14k. This week and next I am doing a lot more serous testing that includes some descent climate control and as many other variables as I can squash so I will re-test that light as well in the batch.
Omg BLIPPI and his Harlem Shake video.
WTF does this have to do with the thread?
Hey everyone! First of all, big shout-out to Texas Ace for building me another tube. I took some measurements of my lights (I don’t have Maukka’s calibration lights yet) and figured I’d post my results here too in case anyone was curious.
[Light]——[Emitter]—[Lm Turn-on/ Lm @ 30sec]—(battery used)
Acebeam EC65 Nichia- 1200 / 1100 (OEM) - I find this one very interesting
Armytek Viking XHP50- 1550/ 1450 (VTC5A)
Astrolux S41S 219C- 2100/ 1800 (VTC5A) 1600/ 1300 (KP IMR18350)
Emisar D4Ti SST-20 4000k- 2900/750 (VTC5A) 2200/ 1300 (KP IMR18350)
Emisar D4 SST-20 5000K- 3800/ 1800 (VTC5A) 18350TBD 2600/ 2240 (KP IMR18350)
Fireflies E07 Nichia 219B- 3100 -> 1500 @ 15sec (50E) 235 @ 7135 x3
Lumintop Prince CU- 880/ 855 (KP NCRB)
Massdrop Tool BR 219B- 70/ 70 (Duracell NiMH)
Massdrop Tool Ti 219C-87/ 69 (Duracell NiMH)
Olight S1R II Cu- 1084 / 1035 (OEM)
Olight S1R II Ti Autumn- 1078/ 941 (OEM)
Reylight Pineapple BR- 448/ 390 (KP 800mah)
Skylumen C8Fvn LH351D 4000k- 1950/ 1750 (VTC6) (VTC5A briefly had 2100lm turn on)
Skylumen D25Cvn Oslon White 1- 710/ 550 (E-fest IMR16340)
Sofirn Q8- 4300/ 4000 (30Q) (*cells not fully charged)
You don’t really need Maukka’s lights since yout tube was already calibrated. I guess it doesn’t hurt to have them, though.
Hi, I would like also to purchase one, 3.5”, paypal, ship to 97236. Thanks!
Oh, a neighbor has joined BLF - welcome.
Thanks for the welcome and hello to everyone! I am new to this forum stuff
I am currently building one for someone else, the parts should be in tomorrow for it. I am not 100% sure if I will have enough diffusers left to build another 3.5” after that but I think I will have just enough. I will contact you when this one is finished and let you know what I have left.
I just don’t want to oversell before I know for sure I can fulfill the order.
I should have enough for a few 4.5” left worst case since they didn’t sell as well and I have more parts left over for them.
Welcome to BLF Jobane, enjoy your stay!! . .
I got his made and after going through all the extra parts I found a few that had minor mistakes from the laser cutter that I didn’t use the first time around but should work just fine if I mix and match them to make them fit.
So I have the parts to build 1 more 3.5”sphere and a few 4.5” spheres.
I also suppose I could cut the 4.5” parts down to 3.5” if desired as well.
Emisar D18 5000k SST-20 with freshly charged Samsung 30Q batteries. 13500 OTF at turn on 10700 at 30 seconds. Large step downs from there 3000 lumens at 3 minutes.
