TLF/BLF/Lumintop FW3A review (18650, 3x XP-L HI cool white)
284 posts / 0 new
joechina
Last seen: 2 days 9 hours ago
Great review! Smile
Thank you so much for your work.
One little thing
Quote:
The spring is non-metallic (BeCu?),
Do you mean non-magnetic ?
Edit: I should read first the whole thread, it’s already mentioned
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 10 hours 22 min ago
Kiitos suuresta työstä, maukka! Thumbs Up Smile
joechina
Klayking wrote:
In case we do end up with the slightly older version of the firmware (not that it sounds like a big deal), the FW3A has accupuncture style flashing holes, right? At least, I think that’s what I heard but I don’t have time to check at the moment. I’ll search some posts later when I get time, assuming nobody has already answered by then. Reflashing should be somewhat easy if this is the case though.
The Emisar D4S is flashable like that.
Noir
Noir's picture
Last seen: 10 hours 23 min ago
Thanks for your review maukka, looking forward to your beamshots/test data with the correct optic (10511) installed.
maukka
maukka's picture
Last seen: 1 hour 47 min ago
Happy to report that the beam is very pretty with the 10511 optics. No discoloration in the middle of the beam. Just some radial artifacts at the edge of the beam, which are not even visible on a white wall unless you rotate the light.
ToyKeeper
ToyKeeper's picture
Last seen: 6 hours 59 min ago
maukka wrote:
The FW3A on turbo with a 30Q heats up to about 50°C when the thermal limit is set to 55°C. It stabilizes at around 46-48°C.
Sounds about right. It uses a window of 10 C as its target zone. If it can get the temperature anywhere in that window, it stops trying to adjust the output. So with a limit of 55 C, the window would be from 45 C to 55 C.
JasonWW
JasonWW's picture
Last seen: 1 hour 3 min ago
If you happen to have some other optics like 10507 or 10509 it would be nice to have some pictures, all from the same distance, to see what they look like. Assuming your not too busy.
Click this to go to signature links.
hodor
hodor's picture
Last seen: 4 hours 25 min ago
!https://i.imgur.com/zpIdvyA.jpg!
That’s more like what I was expecting, thanks for checking and getting your findings up so quickly Thumbs Up
ToyKeeper
ToyKeeper's picture
A quick note about lumen numbers:
Maukka uses proper ANSI lumens, but a lot of the flashlight industry uses a different scale which has more impressive-looking numbers. I call this second one the “cpfselfbuilt scale” because he was the one who really perfected it. He did this by measuring a lot of lights, trusting that the manufacturer’s values were correct, and fitting a curve to the average. So it does a pretty good job representing a lot of brands which were popular at the time, even if it’s not really accurate. Anyway, the difference between the two is roughly 30% or 40%, so 100 ANSI lumens would be about 130 or 140 cpfselfbuilt lumens.
My measurements, so far, have used a super low-tech “integrating milk carton” which I calibrated to match cpfselfbuilt’s numbers as closely as possible. One of these days I’ll buy some reference lights from maukka so I can get more accurate numbers, and perhaps build a proper integrating sphere… but that hasn’t happened yet.
When I measured my FW3A production sample, I got the following results:
  • 1×7135 level: 155.8 lm
  • 8×7135 level: 1163.8 lm
… and maukka’s numbers for these same levels are:
  • 1×7135: 119 lm
  • 8×7135: 888 lm
So in this case, the difference is 31%. That is, assuming the two lights actually produce the same amount of light, which is questionable because the emitters are different tints with unknown bins.
Maukka also measured 2800 lm at 0s on turbo. Using the same 31% correction factor, this works out to about 3666 lm on the scale I’ve been using. That number is probably more directly comparable to the ~4300 lm I got with an Emisar D4.
All the FET / turbo stuff is going to be incredibly approximate though, not precise at all. The actual values are highly dependent on analog factors like the battery condition, the cleanliness of the contacts, etc. But mostly I wanted to let people know that 2800 ANSI lumens is not a disappointing result. It’ll probably look almost as bright as a D4. Unless they’re side-by-side, it would be hard to tell the difference.
Klayking
Klayking's picture
Last seen: 2 weeks 5 days ago
Re: Flashing vias – Ah okay, I must have been thinking of a different flashlight then. I know the D4S has them, and I think there was a rather premium keychain light project that was going to have them too. That might have been what I was thinking of.
delusional
delusional's picture
Last seen: 20 hours 25 min ago
The fifty shades of grey anodizing is looking really nice. It’s silvery reflections can fool you depending on the lighting condition. Looking at the short angled area of the body near the clip… In one pic it’s the brightest area of the body, but in another pic this area of is turned away from the camera, and it’s so dark that at first glance I thought “Why is there an extra O-ring there?” It’s even better because something that could have been a major drawback of the light turns out to be a superior point.
It’s not as good as the naked prototype, but it’s as good as it possibly could be.
Woke up to this one day…
Good morning OCF&BD,
I’ve created a new disorder for you. OCF&BD
Obsessive Compulsive Flashlight & Battery Disorder – and of course, there is no known cure, because you keep recharging yourself.
maukka
maukka's picture
For comparison, here’s some lights so you can get an idea of the shade of grey of the FW3A
maukka
maukka's picture
Beamshot comparison with different optics. The difference between 10508 and 10509 in the photos is very small, but measurably significant. It is possible though, that the optic installed in the light was 10509, since I don’t have a 10508 to compare it to.
GIF
Individual beamshots
JasonWW
JasonWW's picture
Nice. Thanks
d_t_a
Last seen: 11 hours 34 min ago
Very nice review for a very nice flashlight!
Question regarding updating the firmware, since there are no flashing vias, how does one update the firmware if that’s possible?
JasonWW
JasonWW's picture
You’ll have to pull the driver out and attach the clip to the MCU (like normal).
d_t_a
Is that glued or soldered? Any idea how difficult it might be to remove and to reassemble back?
maukka
maukka's picture
The driver is held by a retaining ring. There’s no glue, but it sits quite tightly in its recess so some gentle prying will be necessary.
tocirahl
Last seen: 2 weeks 1 day ago
Can one of you measure the physical dimensions (including weight) of the final light please? Thank you!
headburger
From page 1 of the review:
Measured dimensions and weight
Length: 92.5 mm
Head width: 25.5 mm
Handle width: 21.5-25.5 mm
Weight: 52 grams plus 47 grams for an 18650 battery
david compston
tocirahl
Length: 92.5 mm
Head width: 25.5 mm
Thank you. Sorry I’m an idiot Sad
lumenzilla
lumenzilla's picture
Last seen: 1 day 12 hours ago
I’m still wondering why they put lens over the optic other than to “protect” it.
Does the bezel hole slightly larger than the optic’s diameter?
ToyKeeper
ToyKeeper's picture
lumenzilla wrote:
I’m still wondering why they put lens over the optic other than to “protect” it. Does the bezel hole slightly larger than the optic’s diameter?
There are two purposes:
  • To protect the optic
  • To avoid blocking light from the edges of the optic
Most triples partially obscure the outer edge of the optic, which also blocks some of the light which would come out the front. The FW3A doesn’t do that.
For example, the FW3A (left, 10508 optic) next to a Rey Triple Ti (right, 10511 optic):
… and a Rey Dawn (left) next to a FW3A (right), both with 10507 optics:
The entire optic is exposed, which is a nice change from the usual.
lumenzilla
Thanks TK, well explained.
timbo114
timbo114's picture
Last seen: 1 day 22 hours ago
I like the 10507 optic beam.
ToyKeeper
ToyKeeper's picture
Have you tried one in person, with XP-L HI? It generally has a yellow center, almost no spill, and a bunch of fairly visible artifacts around the edges. It’s still quite popular, but I generally replace mine with other optics to get a nicer beam at the cost of some throw.
timbo114
timbo114's picture
I have not.
I just liked the beam shape in the photo.
Would it act the same with the LH351D emitter?
ToyKeeper
ToyKeeper's picture
timbo114 wrote:
I have not.
XP-L HI in 10507 makes a nice photo, though the yellow center is still slightly visible.
LH351D in 10507 looks totally different. It makes a big wide circle with pretty much no spill and no artifacts, aside from some coloration at the very edge. It’s a lot like a zoomie on wide mode. Here’s a LH351D 5000K in a 10507 optic, on the right, next to a ROT66-219B on the left. White balance is set to “daylight” 5000K.
timbo114
timbo114's picture
Ah.
Thanks for the comparison.
nick779
nick779's picture
Last seen: 1 month 1 week ago
Very nice review Maukka!
