Just started….
$59 not bad
The S1 R II is $85, only 15% off. Not a compelling deal.
Summer and Autumn are at $59. The winter one that I was looking for is $85 which is a joke.
@ rcwiily…. Thanks for the link.
Yeah peg… I do not feel compelled at all in fact.
I’ll be honest, I felt a little compelled…
ThorFire CT01 $3.50
https://www.vipon.com/product/5895746-ThorFire-Mini-Zoomable-CT01-Super-Bright-Led-Light?ref=ss_5895746_2_title
ThorFire CT01 $3.50
I hate Zoomies… but I Had to get one :person_facepalming: …it’s cute….I like the clip….and it’s 14500 compatible, I’ll throw a Flat White in it…… :disappointed:
Edit: where is my manners… :person_facepalming: Thanks bikenber73 :+1:
Report back what the guts look like?
Thanks for the tip bikenber73. Picked up a few for the grand neices & nephews to play around with….
Yep, prolly a press fit fet/resistor driver, but hopefully it dosen’t have a the hollow pill, even then I can make a press fit aluminum or copper press fit slug for it… :+1:
Hope the switch is better than typical SK68's - ordered one to find out. Thanks
Ordered one for a gift. Thanks
Hope the switch is better than typical SK68’s - ordered one to find out. Thanks
From some random muggle review ~1yr ago:
I got two to play with. Thanks for the heads up bikenber73.
Y’all talking about the teslacom 12x SRK? I have one.
No, not the 12X. For the teslacom 2 cell light on discount, I was able to get the bezel off with a strap wrench, no glue, and got full access to the LED and drvier - got them out easy enough. I'd rate it as moddable for me, though the driver would have to be mounted/piggybacked somehow in there, but certainly doable.
No, not the 12X. For the teslacom 2 cell light on discount, I was able to get the bezel off with a strap wrench, no glue, and got full access to the LED and drvier - got them out easy enough. I’d rate it as moddable for me, though the driver would have to be mounted/piggybacked somehow in there, but certainly doable.
I took the xml out of mine and put an SST-40 in it. Didn’t appear to make a lot of difference visually. Have not tested output yet. May change it again. It is a 20mm mcpcb so it’s pretty easy to swap. May even try an xp-l hi to tighten up the beam.
ThorFire CT01 $3.50
It also has a stackable coupon fo 10% off bringing the price down to $2.80
