So I received my E07 today (SST20 95 CRI, clear anno) directly from Fireflies. The head was not glued, as ordered. The optic’s leg was broken off like most of the others - probably the old batch. Screws are intact though.
My Samsung 30Ts I ordered from NKON seperately fit in there pretty good - I don’t have a giant solder blob on the front spring like most people seem to have - looks decent.
I can see through the holes of the PCBs that mine too has no thermal paste whatsoever beneath it. However, from what I can see, the MCPCB sits flush on the shelf of mine, heat transfer is also immediate. I will open it to attempt the emitter swap anyway - then I will see more.
One thing I immediately noticed though is, that the battery tube has a slightly different gloss than the head and the tailcap - it’s glossier while the head and tailcap are more milky - are they made from different materials?
One very interesting thing: Fireflies claimed earlier, that the SST20 would turn blue immediately with a Samsunug 30T no matter how good the connection between the MCPCB and the light would be. This is not true for my light. Mines didn’t turn blue even when I kept it on turbo and it started regulating itself after some time (battery fully charged of course).
Another thing I have seen people mentioning only briefly: My E07 has the shittiest pocket clip I have ever seen. It’s so stiff that it just pops off when you try to open it enough to clip it onto your jeans - the clip’s connection to the light is just much weaker than the force needed to open it enough to fit any material in between. It’s completely unusable on mine.
Other than that - it works as far as I can see. Aux lights works, main lights work. The switch feels cheap and mushy but for me not as catastrophic as many people seem to think it is. After using it a couple of times it feels pretty natural.
By pocket clip, you mean the anti roll device? I've been flexing mine and got it opened up enough to work pretty well.The clip no longer is in contact with the tube.
On a 40T pulling over 23 amps initially, I didn't notice any blue as well on the SST-20 4000K's.
I would definitely like a nickel or titanium finish.
Emitters: XPL HI 4000K (barely used so far, since the battery I received it with is already in low voltage).
Auxiliary: purple and red for low voltage.
Actually I live in Europe, so Walmart is just a concept for me. I was just trying to express that this shiny silver metal does not work with me because it is too fancy and does not necessarily go with quality in my mind, and I prefer the (perhaps more sober) matte materials.
Personally, I love the look and feel of the shiny E07.
However, if you really find it too shiny and want to dull it down, there are better options than taking a scotch bright to it. It’s shiny because there is a layer of clear anodizing on it protecting the aluminum and preventing it from oxidizing.
If you want a duller appearance, just remove the anodizing. The simplest way is to soak the light in something that removes anodizing. I use Greased Lightning from my local hardware store. But you could use drain cleaner. Even bleach might work, but could take forever.
The safest way to do this is to disassemble the light and soak the bare aluminum parts. However, for this light disassembly is quite an operation and would require careful soldering. For those not comfortable attempting that, the next option is to soak the light whole.
Before soaking, I recommend checking and lubricating all o-rings. The light is going to be immersed in liquid for quite some time and you don’t want corrosive stuff leaking inside. You may also want to tape off the the bezel or other parts that you don’t want to become damaged. I’m not sure if Greased Lightning will affect steel, but I don’t think I’d want to risk it. I use vinyl electroplating tape for masking.
For safety, I recommend against soaking the light with the battery inside. If you need more weight to make the empty light sink into your soaking solution, fill the battery compartment with a stack of coins.
After the anodizing is removed the light will be a dull raw aluminum color. This will naturally oxidize to a slightly whiter color over time.
Woo-hoo, DHL tracking FINALLY updated (this was the first actual scan and first actual log entry other than “awaiting item”) and my light is in Cali, should be here Tuesday!
Yeah… This style of pocket clip was going around a while ago, 2017 and 2018, from multiple brands. I’m not sure why that happened, but I don’t like it. Maybe it was a fad, maybe someone produced a huge amount and sold them cheap, I don’t know. I’d rather have almost any other style of clip though.
However, the rest of the E07 is quite nice. It’s definitely a light I make a point of using regularly, because I like it a lot.
That’s a fair point, absolutely possible that fireflies didn’t know. But, for someone operating in this space acquiring tens of thousands of emitters and thousand of drivers and components, i consider it unlikely to not know who to trust to purchase a cell or how to tell the difference.
Regardless, we’re all rolling the dice each time we buy a budget light, and I wouldn’t have cared a single bit if this light was twice the price, I think it’s awesome. The battery deal, and then no official response or offer of making it right is shady.
Not sure what point of the clip design you are referring to - do you mean the click-onto-the-tube-style? Because the D4 has one of these too but it just works perfectly on mine. It’s much longer, weaker tension and just holds perfectly onto the body. I had it clipped onto my belt for months and I head zero issues with the clip failing. My Klarus XT2CR lost the clip about twice a day or so. Really annoying. The E07 now loses the clip whenever I try to put it onto ANY fabric. I could try to bend it, but i won’t wear as a pocket light anyway - the head is too big for my taste to do that.
The entire thing. I don’t like the one Hank originally used on the D4 either. And Lumintop tried to get us to use one on the FW3A at one point, but the team unanimously rejected the idea:
Here’s the one originally used on the D4:
… and on the V11R Mirage:
… and the E07:
I haven’t liked this clip design on any light I’ve ever encountered.
I’d like to see an Olight-style clip instead, ideally with a full ring (like the FW3A, and the SolarForce L2 clip) instead of arms.
I also have clear ano with SST20’s and noticed the same thing. MCPCB seems to make full contact with the shelf and the head warms up really fast on turbo. Please report back your findings when you take yours apart because I’d really like to avoid messing with mine.
YES! The ring attachment will always beat the clip arms that scratch the light over time and can come off. I’m looking, but 21700 battery tube size is not near as common as 18650:(
Thank God. The ring-style clip is one of the main perks that I like about FW3A. It would be much less appealing to me otherwise.
I’ve had exactly the same experience, but I think I’ve fixed it just now.
Here’s what I’ve done:
Install the clip backwards so that it extends beyond the tailcap. Hold it in place with a thumb so that it doesn’t pop off and pull with an index finger to bend it slightly.
Tied it down with a braided fishing line using a trilene knot.
Yeah, it doesn’t look pretty (though it’s much less noticeable in person than the picture), but it seems to be very strong (for now).
Also, this is my first attempt and I have no experience with “fancy” knots, never had any interest in fishing, so I’m sure it could look better.
FYI: for those like me without knotting skills I’ve found that a simple double-X knot of Trilene can be made super-durable by applying a little super-glue gel to the knot.
Agreed, full-ring would be the way to go. I am very happy that the clip-on was rejected for the FW3A. And I am glad that I did get another clip for my D4, not the first one. I checked my XT2CR again, and the clip is, besides from the color and the holes in it, almost identical to the one of the E07.
Howdy, about ready to purchase an E07. I’ve read most of the thread, have seen the issues and the potential solutions. But some questions to sum up -
- where best to purchase? Fireflies or nealsgadgets or…?
- is there a discount path still valid anywhere?
- planning to get the 6500k emitter, anything I should know?
is the best battery option still a (genuine) Samsung 40T, or has something risen above it in testing?
Thanks for helping out!
(I also realize Fireflies is on vacation until 2/15.)
When you purchase, definitely pay for expedited dhl shipping. It’s so much faster. Buy your 40T from a reputable “battery dealer.” There is a thread on here with a discount code for all sellers, but you have to request banggoods code.
Does anyone know why the Nichia 219B variant of this light seems to have disappeared? It does not appear to be available from anyone any longer. Is this temporary, or has this version simply been permanently withdrawn?
Thanks
