Thanks Firelight2! That helped me a lot on deciding between the two.
Yes for mé the same
Nah, use the light outside and you’ll see why higher CRI is always better.
Also, don’t forget the SST-20s high CRI have a lower forward voltage than the XP-L HIs, so more current is consumed.
And it’s also going to last longer on regulated modes because of this too.
it is nice outside but I prefer the XPLHI.
I disagree. Vf has nothing to do with battery power consumption on regulated modes. The battery voltage appears across both the current regulator and the diode. If the regulator is working, the current through the regulator is fixed. Battery power is simply battery voltage times regulator current. If the diode Vf is higher, more dissipation in the diode, less in the regulator. If the Vf is lower, less dissipation in the diode, more in the regulator. I would argue the diode can handle the dissipation better then the regulator. If Vf went to zero or very low, one would burn up those little regulator chips pretty quick, as they have no real heat sink.
Here are some factors in how useful and pleasant I find an LED’s output to be, in order of importance (in my opinion):
- Output - measured in lumens. The purpose of a flashlight is to illuminate something. Shear output matters a lot. A light with 100 lumens just doesn’t have as much punch as one with 500. What’s the point of having a light with fantastic color temp, tint and CRI if it’s not bright enough to illuminate what you want it to?
- Intensity - measured in lux. or lumens per fixed unit of surface area. An LED with higher intensity has better throw. Important for some applications.
- Color Temperature - warm, neutral or cool white. Different people have different preferences. I find 4200-4300K to be ideal, but will accept anything 4000K-5200K.
- Tint - above or below the black body line. Tints above the black body line tend to look greenish, those below look rosy. Most people, myself included, find rosy tints to be better.
- CRI - how well the light represents color at the given color temperature and tint. Most neutral tint LEDs are 70-80 CRI. High CRI LEDS tend to be 90+. I can immediately tell the difference between a 65 CRI and 90 CRI, but when it comes to neutral tints I find that I can only tell the difference between 80 CRI and 95 CRI if I hold the two lights side-by-side and compare beams. Because, CRI is so subtle I find it to be by far the least important of the 5 factors when it comes to picking a light. I’d much rather have 80 CRI with beautiful tint, than 95 CRI with horrible green tint. I find CRI without good tint to be pointless.
Thanks for the feedback, I was considering trying out the SST20 in my D4. Might still some time, but not in nearly the hurry now.
High CRI always comes at the cost of efficiency. So your findings are true and they were predictable.
If cri is not important for you the lower cri SST20 LEDs would have been a much better candidate as they are way more efficient while rivaling the XP-L HI in output and beating them in throw.
I personally prefer High CRI but dislike the green in the SST20 4000k variety.
Running some very rough numbers with lots of assumptions gets me this:
- D4 SST-20 6500K, spec’ed at intl-outdoor at 4200lm. That is 1050lm/led, so about 1280lm for the bare led, which is at 86% of max and they run at about 4.5A per led.
- D4 XP-L Hi, spec’ed at intl-outdoor at 4300 lumen, that is 1075lm/led, so about 1310 bare led lumen, which is at 62% of max, and they run at about 4A per led.
So the XP-L Hi version runs 2A less in my calculation while putting out a bit more light. The experiences above suggest a larger current difference though, so something is off, perhaps int-outdoor’s specs or my numbers
Regardless of CRI I find the SST20 to be much worse. In my D4, the SST20 is noticeably inferior for my needs in the most basic test: output.
- The SST20 D4 ramps down much faster than my D4. I like burst modes, but in the D4, the SST20 starts out with a slightly brighter hotspot, but within 10 seconds of turn-on it is already much dimmer than a D4 with XPL HI.
- SST20 might be more efficient, but what’s the point if I’m not able to take advantage of that efficiency and see results in-use because of the higher heat generated.
- I hate greenish tinted lights. I find tint of the SST20 at anything less than max turbo to be unacceptable.
My modded D4 looks pretty, but has the worst possible configuration for heat management. It is more susceptible to rampdown from overheating than probably any other D4:
- Polished Bare aluminum head (not as good as copper at transmitting heat and can’t hold as much as copper. Shiny bare aluminum has lower emissivity than dark anodized aluminum).
- Titanium body tube and bezel (not as good at transferring heat from the head as aluminum.
It is possible that a stock aluminum D4 wouldn’t see such an extreme difference in results.
yes, of course. Sans the tint these are direct results of the High CRI variant being considerably less efficient.
Your reasoning that these are not a good choice for your needs is sound.
I was merely saying that this outcome could be expected and people should only choose high cri if they appreciate the better cri so much, that they are willing to accept the impact in virtually any other area of LED performance.
Agreed.
For those who absolutely must have high-CRI in their flashlight and who don’t care about other factors, the SST-20 is a good choice. It offers considerably higher output at high-CRI than most other LEDs on the market.
It might also be a great choice of emitter for small single-cell throwers like the D1 or D1s. With only one emitter, plus more thermal mass, those lights are much more likely to be run at max power. And max power before rampdown is where the SST-20 truly shines.
I had gotten the high CRI SST-20’s in my E07 due in part to no additional cost and planned on replacing them anyway. I got a Manker E14 today with 2 ruined Nichia emitters and so I replaced the Nichias with 4 of these 20’s.
At low output the green is excessive. At higher power level it clears up quite nicely. On a VTC5A it pulls around 50A at the tail. Pretty big draw on these small emitters! Not that Luminus emitters are known gor high efficiency…
Definitely a tighter beam that part is welcome, lower modes are virtually useless for me though.
I wouldn’t say excessive.
It’s extremely hard to find emitters that have good rosy tints below 350mA for LEDs* due to how photon emission at different wavelengths work, but it depends on the tech used in the LED and the tint bin.
Basically, the tint shifts to green at low currents in LED emitters since the blue light emitted from the die can be more efficiently converted to green compared to red colors.
It gets better for high CRI LEDs and lower CCT LEDs, but the problem still presents itself. The closer you are to perfect color reproduction(akin to the sun), the less this issue arises at lower levels.
That’s why at the same color temp and same tint curve deviation, an SST-20 4000k 95CRI can look better in the tint department compared to an LH351D 90CRI.
*That only works for LEDs. For HIDs, and incandescents, it’s the complete opposite. The LES gets rosier as the power draw gets lower.
I notice a little green in my SST-20 4000k 95CRI when next to my 5000k XP-L Hello.
On its own I don’t notice any. My mind could be blocking it, like a bad experience.
But I DID use the word excessive because I do NOT like what I shine a light on to look green. Not our brownish cream colored floor tiles, not our beige carpet, not my son or anything else I look at. Green is an absolute no go for me, period and end of that story. So this E14 that just came today will get the emitters swapped again ASAP tomorrow.
All 7 of the SST-20’s that I removed from my E07 will be in the trash probably less than 12 hours from now. (as it’s bedtime here and I have something that I have to take care of first thing in the morning)
Edit: For reference I ordered my E07 with 5000K NW SST-20’s
I think our eyes are just different, or perhaps the tints of certain LEDs are just worse than others even in the same tint bin.
Don’t forget, I’m a photographer and I deal with processing colors correctly in a very big way. Thousands of pictures at a time from a full frame Canon sensor on a professional Dell monitor that’s color corrected. Proper color is very important to me, it’s a way of life.
Green is a no go for me also.
My 4000k don’t make my kids look green
