13626 posts / 0 new
ToyKeeper
ToyKeeper's picture
Last seen: 18 sec ago
hodor wrote:
Be careful with the SST-20s, I’ve tried all the currently available 3000K, 4000K and 5000K and they all have a green tint to them at low to medium levels.
I’ve noticed that on LH351D too — greenish at low levels. And low levels are about 95% of what I use. It’d be okay if the tint was significantly below BBL, so it’d be white at low levels and pinkish at higher levels… but those seem to be difficult to obtain. I’m really hoping Lumintop can follow through with a good tint bin.
However, I’ve been pretty happy with XP-L HI and Nichia 219B. And, with a frosted enough optic, also with any other Cree emitter in a neutral white “A” or “D” tint. They’re all pink-biased so they look okay at low levels.
mortuus
mortuus's picture
Last seen: 8 hours 28 min ago
i dont see any green on my d4s 3000k…
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
hodor
hodor's picture
Last seen: 9 hours 38 min ago
Same here, and it’s a shame because they look great on high and turbo.
I’ve been thinking about getting some LEE Zircon minus green filters. It’s either that or de-doming/slicing, which I hear can lower the tint but I’d be worried about screwing it up.
Funnily enough, all my XM-L and XP-L HI 4Cs (above BBL) are rosier than the majority of emitters I have which are meant to be below BBL, 219B excluded OFC!
hodor
hodor's picture
Well I’m either very unlucky in the tint lottery or I’m more sensitive to green tints.
JasonWW
JasonWW's picture
Last seen: 1 hour 53 min ago
offroadatnite wrote:
hi ,
Checking in, it appears there is a decision to be made.
my numbers are 739, 740, 889, 890. could you make it two of each emitter? thank you. Andy
hcanning wrote:
When do I need to specify which emitter I want? Never done a group buy before Smile
No decision to made yet. I think they are going to make half and half of each type (if I’m remembering TK correctly). So the list is just for the total number of lights you want.
JasonWW
JasonWW's picture
BlueSwordM wrote:
The magical line you see is, simply put, the black body line.
Black body locus or Planckian locus. Wikipedia if anyone wants to read about it.
tirelight86
Last seen: 1 year 4 months ago
Please put me done for another light. That will make 2 lights total. 1 of each emitter option.
Nev
Last seen: 1 year 1 month ago
I’ve tried the sst-20 in 6500k ,it only looks greenish if you shine it on a white wall next to XPLHI
bidas
Last seen: 9 hours 8 min ago
Yesterday i finally jumped to the LH351D bandwagon and modded my OTR U16 with one and i’m pleased with the result, i didn’t find any odd tint.
On the other hand i’m waiting for my sst-20(4000k 95cri)to arrive to replace a xp-g3 ~6000k green puke tint, hoping not to see also a green puke tint!
So for now i’m in for one LH351D in this flashlight, and i’m not forgetting that there is only other option, the XP-L HI
severide
teacher wrote:
severide wrote:
I haven’t checked these forums in a while. Just caught up with the update on the first post. Decent timing on my part lol. I’m satisfied with the emitter choices. Looking forward to seeing more after the prototypes are received. Thanks for keeping this going guys!
maukka has already received his & posted a ton of photos & info. Did you see it??
I have not seen that, actually. I’ll look through his posts to find it. Thanks! Smile
zak.wilson
Last seen: 7 hours 30 min ago
I think the minus green filters are a really good solution for anyone dealing with green tint on lower modes. You give up some output, but it’s reversible. I had great results on my Astrolux S43, which came with horribly green 219Cs.
Ceilingbounce – flashlight testing and runtime graphs for Android
JasonWW
JasonWW's picture
His post in this thread was hard to miss.
http://budgetlightforum.com/comment/1452331#comment-1452331
Marc E
Last seen: 16 hours 42 min ago
Not sure if it’s the same tint issue but reversing the lens on my S42 removed a sickly tint from the beam and made it very nice indeed. I actually find this for all lights with AR coated lenses, i reverse them all for a much more satisfying beam.
Could be worth a test.
maukka
maukka's picture
Last seen: 6 hours 1 min ago
Marc E wrote:
Not sure if it’s the same tint issue but reversing the lens on my S42 removed a sickly tint from the beam and made it very nice indeed. I actually find this for all lights with AR coated lenses, i reverse them all for a much more satisfying beam. Could be worth a test.
Reversing the AR coated lens on the S43 has no effect. Removing the lens, however, does drop the duv from 0.0045 to 0.0031 and increases the output about 5%.
Marc E
Fair enough, you’d know! What is duv?
maukka
maukka's picture
The distance from the black body line (neutral light). Positive numbers are above the BBL = greenish. Negative numbers are below = rosy/magenta.
Marc E
Got it, thanks Smile
Screwball69N
Where do I order the FW3A flashlight
zak.wilson
You can’t order it yet. You can say how many you want in this thread, and when they’re available, you’ll get a notification.
teacher
teacher's picture
@ severide….. Jason provided the link to the post in ‘this’ thread by maukka.
Here is the link to maukka’s review thread….. TLF/BLF/Lumintop FW3A review (18650, 3x XP-L HI cool white)
nbjly
Last seen: 3 days 6 hours ago
I would like to buy 2 please
Thanks!
jakeattack77
interested in one for sure, maybe 2 or 3 (friends)
Screwball69N
I am interested in one or two
JasonWW
JasonWW's picture
The link to his review is already there. That’s why I didn’t post both. No biggie, though.
JasonWW
JasonWW's picture
Switching from an AR coated lens to a plain one can reduce the yellow and vice versa. It’s an easy way to shift the tint a little bit. All the AR coated lens I’ve seen were coated on both sides so flipping it does nothing. Maybe your S42 lens is only coated on one side?
teacher
teacher's picture
Thumbs UpOK, your right, it is there.
Can’t have it in to many places though… makes it easy to find. Wink
JohnnyUtah
Just curious, to anyone getting just one of these which led will you be getting and why?
BlueSwordM
BlueSwordM's picture
Last seen: 6 days 16 hours ago
@JonnyUtah, I will be getting mine with the LH351D, for 3 reasons:
1. I like high CRI lights. They make every color pop.
2. I prefer 4000k-4500k for indoor use.
3. It’s cheaper than the XP-L HI, and since the LH351D 90CRI has about the same forward voltage as the SST-20, I’ll swap one LH351D for an SST-20 3000k, which will work fine and make the beam rosier.
richnpc
Last seen: 1 day 5 hours ago
I know this has been asked before, but can’t find the answer. When the light is in muggle mode, is there a memory function, or does it always ramp from its lowest setting?
ToyKeeper
ToyKeeper's picture
Clicking to turn it on goes to the last-ramped level. Holding to turn it on starts at the bottom of the ramp.
