I recently purchased the Sofirn SF14V2.0 for $12.99 through Amazon via the Sofirn Facebook deals page. It was shipped free (Prime-eligible) from a US warehouse, and arrived in about 3 or 4 days.
I too was looking for a simple light, as a gift for a non-enthusiast who appreciates high performance. This one seems to fill the bill. It has three modes (low, medium, high), no blinkies, and no memory. Just click to turn on (always starts in low), and half-press to cycle through the brightness levels. Click again to turn off. That’s it. I think the levels are very well-spaced … all three are useful, and differentiated from one another.
On high, it’s blindingly bright for a AA light. I compared it side-by-side with my Zebralight SC-52W using a pair of identical IMR14500 batteries, and the Sofirn is brighter. So the factory claim of 650 lumens might not be that far off. It does light up my entire backyard.
It includes a lanyard, a decent pocket clip, and spare O-ring.
May I ask you a question? Tell me the stepdown from high mode to the average after 3 minutes works both for 14500 lithium battery and for Nimh battery, or for 14500 lithium battery only?
The Convoy T2 still uses noticable PWM, but there has been worse. It is about 800 Hz and I have seen 100 and 200 before. For people who are not specifically sensitive to PWM, the T2 is fine.
Direct access to Moonlight (single click)
Direct access to last used mode (press & hold)
Direct access to Turbo (double click)
Direct access to Strobe (3 clicks)
Lock-out mode!
It is on the Neutral White side, has hotspot but is also floody! Takes AA, NiMH and 14500 Li-Ion!
EDIT: There is a also the Jaxman E3, a robust AA light that has only 3 modes and Nichia LEDs inside!!
As far as I remember, it was mainly the UI that was different on the 1st models of the SP10A (no turbo, no electronic lock out) and B (turbo, lock-out).
Then the SP10A and B become the same, only the external colours differed (A = black host, B = red and blue hosts).
Ah thanks. was about to ask about the v2.0 version. For under 11€ euros on aliexpress with an UI like this, this is a steal. 5200-5700k is not my favourite, but alright.
I also liked the SF14,because it is even simpler and has a tailclick.
Sofirn really should rethink their model-naming…
sf14 and sp10 are AA… then SP31 a rechargeable 18650, sp33 is 26700, SP36 is a 3x18650 lumen monster… Hard to remember which model is which…
Remember that side switches tend to activate easily in your pants or pack. So I would either lock it out by unscrewing, or better go for the tool AA. Never fun to find your flashlight depleted when you rely on it. I travel a lot and tried a lot of side clickies. Now a no-go for me.
But I like the sideswitch on my wuben e05. That one is pretty firm. I have it in my jeans pocket since a week now and it never accidentally turned on. Also a nice light. I bought the version from TLF,which has no strobe but a shortcut to low instead. I like it, but kinda pricey. The Sofirn Sp10 seems to work similar and is a lot cheaper.
My copper tool AAA accidentally turns on a lot more often with tailswitch.
Ok, good you thought it over! I evolved from twist- to side- to tailclicky for my EDC light.
I hate fiddling around to find the switch, too.
But if side switched lights improve, I just might reconsidder it in the future.
