Where can the XPL HI V3 3A NW 5000K version be had? It’s listed in some of the descriptions but there’s no option to select it.
interested in BG group buy code — thanks FreeMe!
I’m in Clear anodizing confirmation
BG group buy code still available? Thanks @ freeme.
Got my grey e07 from neal. It flickers on moonlight. No matter which battery i use. Anyone else experience this?
Apparently it’s a known issue (I believe I read about it in the FW3A thread that all 3 FF lights do that).
My clear E07 didn’t do it with the stock SST’s but all you should have to do is set the ramp floor a little higher (try one step at a time).
just curious, are u calling moonlight the bottom of the ramp?
Is there an ETA for shipment for the next version that addresses the thermal paste and TIR positioning issues? Thanks.
With Anduril, the bottom of the ramp is moon. It doesn’t have a separate moon level like NarsilM does.
About the flickering, it seems to vary per 7135 chip. Some do it, some don’t. I think I may have found a workaround though, and it’s included in recent builds.
thanks ToyKeeper -
can you please give me a BG coupon code?
Correct. The lowest setting. As far as i see, its the only light that does it out of all my ff lights.
Which one is the CORRECT output for SST-20 5000K?
Neal’s website has:7x SST20 5000K NW 3500lm
Fireflies website have: 7x SST20 5000K NW 4800 lumens Turbo brightness
Yeah, that’s what makes the issue tricky. I don’t have any lights with the flickering issue, so I’ve had to take guesses about how to deal with it, send files to other people, and hope they’ll be willing to test it for me. I think I finally found something which works though.
@wolfdog, it’s the 2nd one.
The 3500 lumens is for the 4000k version and below.
Anyone have the answer to my questions? Where can the XPL HI V3 3A NW 5000K version be had? It’s listed in some of the descriptions but there’s no option to select it.
I just ordered two from Banggood with your code, TYVM! Can’t wait to add em to the rotation.
Hi, I would be interested in the banggood code for the e07
BG order placed. Thank you @ Freeme.
