Does anyone know of a way to get just an aux emitter board, of say, yellow/ red aux LEDs? Is that something Neal would be able to sell (since he seems to be the only person with alternate options, but I’m also sorta assuming that’s just all pre-stocked……
Does it still make the loud cracking sounds when the battery is removed? I have a mateminco that does that with the batteries removed after I have had it turned on for awhile.
That’s an oddly strong reaction. It still generally works fine, and several people have done extensive runtime testing on turbo with no issues, even with the air gap issue. It’s unlikely to actually have any functional issues, even if some of the insides may not be perfect.
I just don’t really understand putting something in the trash because of minor imperfections. Maybe it’s not 100, maybe it’s 90 or 95% instead… but that’s a long way from zero. Give it a 50E cell to make the air gap irrelevant, and enjoy the extra runtime.
That is actually possible, and in the first version I sent to Fireflies I tried to convince them to include that mode… but they thought it would be confusing and requested a version without the “low” mode instead. So it’s off/on/blinking only.
My XPL 6500k is still putting out 7000ish lumens but my ROT66 219B has dropped to 2700, I’ve put some more foam in the tailcap, like someone suggested, and it’s back up to 4500ish.
Oh it won’t go in the trash, just in the box where I keep all the kit that is either outdated, or that is useable but with an element of risk. I did use 50E’s with it after the late warning about using 30 and 40T’s. I think other people have expressed their disatisfaction with the product more eloquently than me in this thread. I shall just attempt to get a refund from BG. Its no biggie, its just the risk of buying new products from new companies at a reasonable discount
Hhmm, foam in the tailcap? Ohhh - to keep the carrier compressed and tight against the front end contact - makes sense from that perspective. I bypassed the driver spring, but you could also try some light coating of NO-OX-ID on the contact surfaces - spring and ground aluminum rings. The foam though works, sounds like, but the bypass and conductive grease helps also in the long term.
Concerning the mistake about the MCPCB, the E07 is a quite expensive model but it can be used in muggle mode which is fine. Worth the 6 clicks from OFF to test it :+1:
Thank you ToyKepper
NB : double clicks turn off the light, ceiling and floor are reasonably bright in their respective levels. Perfect for muggles, useful for flashlights aficionados.
Floor should be a tiiny bit lowwerrr.
Generally I aim for about 5 lm as the muggle mode floor. Any lower than that, and people start asking “is this thing on?”. However, on my E07 it looks like the muggle floor is about 9 lumens. So yeah, it should probably be a bit lower.
Following in the footsteps of others, I’ve swapped emitters to LH351D 5000K W6. This is easily one of my favorites now and have to agree that moonlight looks delicious!
(This is a little blown out, but a good representation of the wall of light the LH315D | 30T combo produces)
