Although I became to like and have more 16340 size lights in the past few months (On the Road M1, M3 Pro and i3) I use a Rovyvon Aurora flashlight in my keychain!
It is super lightweight and if you don’t use it for extended periods of time (due to battery runtime) I would tell you to get one of those!
If you want a 16340, the new Fenix lights seem nice, and you have the Olights as well! Also, if you don’t need long runtimes, check the new Folomov with 10440, reviewed here by jon_slider and zeroair !!
Trustfire Mini-02 is a CR123A light, but very nice stainless steel keychain light. The body is fairly thick, which is unusual for stainless steel flashlights these days. I don’t know if 16340 is “supported”, but it does work. This light has been around a very long time. But it’s still being sold at least on Alibaba and on eBay and one listing on Amazon.
Enogear used to have something like this Lumintop and even one bullet shaped that would be nice as keychain lights.
However their site has been off for a while
Thanks for all of the recommendations - the Lumintop from fastech looks like almost exactly what I have in mind. I’m gonna read over a couple reviews and probably pick one up.
The Rovyvon Aurora is a bit different, but now I’m tempted to get one of those too
If you like moonlight, high CRI and some extras on the side (UV light + RED light + White light), and if you don’t like Strobes, I’d recommend the RovyVon Aurora A8! :+1:
Unno, for a keychain light, bouncing around in a pocket with other crap that can press in random places, I’d prefer a twisty to try to prevent accidental activation. So for me, a Jet-II would be about perfect for a 16340 light.
Some of the Wuben E-series come in 16340s as well as 14500s, so czech ’em out, too.
Funny(?), but every time I see your handle, I read it as “Mr Steal Your Organs”. Visions of waking up in a bathtub filled with ice are rather disturbing, I gotta admit.
Are you referring to the RovyVon?
So far they have been “pocket activation proof”:
Press&Hold for momentary Turbo
Double click for moonlight (and clicks to advance modes)
Triple click & 4 clicks to activate the side LEDs
I’ve been using it for a while and it didn’t lit up a single time. I can’t say the same for my Nitefox K3 (twisty) and even the Olight i3T EOS (Forward clicky switch).
Unless if locked (electronically or physically), the Wubens will have more probability to turn ON in a pocket as they use single click to turn ON in the last used mode!
Tank 007 E18
I have a few of these. Three mode twisty. Turns on in the the same mode you turned it off in.(at least mine does) Unfortunately one mode is strobe but it has less weight that a stainless light and is pretty well made for the money.
Ahah, sorry, thought you were talking about the possibilities of having a side switch button turning on in the pocket
Ahh, those!! They seem nicely built and very reliable. I was tempted to get one a while ago in a groupbuy from _ the _but never went through. Would be a nice choice, though!
not sure if they are the same now, mine was 3-4 year ago, looks the same though, mine even has a great neutral white color light and a nice pattern
really!
How about a sliding or rotating cover to protect the power button?
Like the threaded ring that Zanflare uses to cover its USB port.
Make it so closing the cover turns the light off ……
The lock out method works just fine. The only twisty I ever really carried was the Jetbeam AA light. Jet something, I always get them mixed up. It came on more than a few times loose in my pocket and just a few times clipped on my pocket. Not that big of a deal really. I noticed it before it was able to drain the cell down too terribly. Then I started carrying mostly tail clicky lights and now I’m back to carrying mostly side switch lights. Nicely recessed switches so I have never had one of those come on. I have had a Tip and a Tini that come on way too easy in my pocket on a keychain. Love them both, but they are always dead.
