Does it support protected 26650s/18650s?
Yes, it’s brass pill inside, It’s good for DIY
I really hope it’s a 21700 cell!
I will launch, S2+ 21700 later
It’s great to see new products from Convoy but I was hoping for something new in 21700 format, like a smaller single cell convoy L2 or a S2+ equivalent but with 21700 and brighter
What size is the driver on this S11? Is the switch forward or reverse?
22mm driver
125V 10A forward switch
yes ,it can run on protected lithium battery ,too
I will be buying one of these. This would be awesome in an S2+ size light even though it may not handle heat real well.
Convoy S11
Will there be thermal control and brightness stabilization? Honestly, I had hopes for the S3 size (18650) for XHP50, but no one seems to be planning to do this besides zebralight (Zebralight SC600Fс IV Plus XHP50).
Vg15s can be easily moded with 20-21mm boost driver and 6v led.
Convoy S11
it has thermal control but no ramping mode,
the driver uses PIC12F683
contactcr:What size is the driver on this S11? Is the switch forward or reverse?
22mm driver
Can you make reverse clicky as an option for it? I think if people used to S2+ using method it is better to use same switch. If you worry about current I have no problems with reverse clicky switches up to 13A.
Simon, Great that the 21700 light is coming!
I have put a 21700 in the Convoy BD01 and that fits fine lengthwise, so I expect that this will be fitting in the S11 too.
I hope that you also will have Biscotti drivers for XML2, XPL LEDs for the S11 / S2+ 21700, similar to the 18650 S2. I don’t always want XHP LEDs.
And OP and SMO reflectors similar to the M1/M2 lights
I like the look of that new S11, will definitely be purchasing one of those. 26650 and/or 21700 would be very nice. Either way, the plain cylinder shape is perfect.
2019/2/13
Convoy S11 with XHP50.2 ready for sale
Driver :0.1%moonlight-3%low-30%mid-100%high double click – strobe, max output 3A,
Where is the link?
It will be sold after chinese newyear.
Anthon:I really hope it’s a 21700 cell!
I’m VERY interested in this and I’m sure many others here will be too.
You speak well. S2+ with 21700 will be great !
Simon are you planning to make quad emitter versions of the S2+ 21700 or will it be compatible with quad carclo optics?
Simon Mao: contactcr:What size is the driver on this S11? Is the switch forward or reverse?
22mm driver
125V 10A forward switchCan you make reverse clicky as an option for it? I think if people used to S2+ using method it is better to use same switch. If you worry about current I have no problems with reverse clicky switches up to 13A.
sorry ,can not be changed this time ,
i will launch another version - S11 with SST40 and ramping driver
