Can you make reverse clicky as an option for it? I think if people used to S2+ using method it is better to use same switch. If you worry about current I have no problems with reverse clicky switches up to 13A.
I like the look of that new S11, will definitely be purchasing one of those. 26650 and/or 21700 would be very nice. Either way, the plain cylinder shape is perfect.
I love the design and obvious Convoy quality of this S11, just wish it was an e-switch. This light is a no-go for me without one.
I'd also love the see the quality, low cost, and clean design of the S2+ or S3 lights as e-switches. Guess part of the problem is to many makers, the e-switch upgrade also implies USB charging, which it doesn't have to. There's also a lot of aspects to implementing a good e-switch:
consistent action and feel
placement
not too stiff but protected and stiff enough to not accidentally turn on
must be easy to locate by feel
The S9 is close but I don't like the style,no ano color options, and think the switch could use improvements. I do though need to re-visit the S9. I bought one way back when they came out, but it's sat on the shelf since. The switch design - feel and action were probably the biggest issues I had with it.
On the other hand, I love the reverse clicky mechanical switch of the S2+ and hope to see it back on one of the 21700 flashlights. And the bright colors of anodization too
I’m very anxious to see the SST-40 and ramping driver, but SST40 is only cool white. I wish for warm tints. Hopefully it has a few useful mid-range currents (500, 800 mA) and not only fancy turbo.
Probably the ramping driver is suited for XML too, but more efficient than a 7135 Biscotti driver (Simon?). Then I can select the tints I like
S2+ 21700 quad: I’m in for it, should be a great fet host, however knurling of any kind would be welcome, it’s a flashlight, not a dildo. Plus diamond knurling sells simply because it has a sexy premium look and feel.
E-switches are the future. USB charging is a gimmick that unnecessary rises the production cost. But as Tom E stated it’s difficult to make a good e-switch. Emisar and Zebralight are examples of (very) good e-switches. Fireflies however is an example how it went horribly wrong. The switch on their lights is so small and so mushy it’s almost impossible to use the light wearing winter gloves.
It’s a shame no producer yet has made a e-switch, ramping, single emitter non-hotrod light, with boost/buck driver as premium option.
Maybe the e-switch part, mechanical switches are of course a thing.
But look what happened to the immensely popular H03 which costed only 25-30$. It seems as if they don’t produce it any more in favour of the magnetic charging version which cost a whopping 45$, that’s a 15$ extra for inbuild charging while a decent budget charger cost maybe 3$ and a DIY lipo charging module 50 cents.
