Banggood sells real 30Qs.
There are many things better than you may believe. Finding stuff which doesn't makes justice to that does not make them impossible.
The problem here is that MECO is a swindler brand. That's about it. Don't buy it and spread the word if you feel like that.
Cheers
General rule of thumb is to buy name brand cells and if forum members here say they are legit, then that is very much true. Issue here is BG sells fraudulent cells along with real cells, where as sellers like liionwholesale do not.
Banggood sells abroad worldwide, product judgment free. Judgment free like the subconscious mind. If you don't like something from their catalog just don't buy it. There's people who buys those “bad” products because they know no better, and they hold responsible from the way they believe and the lessons which to them that entails. So, of course, there is reason.
After seeing this I just went and tried and my order went through. We’ll see if they actually ship them…
That being said, I ordered 2x 26650 from FT a couple months back, the order went through and they shipped, but now, none will.
Oh…and while I am here. Anyone have a place that will deliver the Shockli 26650 to Canada?
Shockli has an aliexpress store, did you try there?
I did. They won’t ship here even though a lot of others will…
My order has been shipped.
Wow, that’s surprising. I’m tempted to order some more cells that I don’t really need right now.
You can’t. That lasted just one day but who knows, it may happen again.
Yeah, the cells are probably going to get blocked at customs.
I received a cell order from BG in May 2018. There is hope.
Please keep in mind there are only a few actual manufacturers of lithium batteries. I have used high drain IMR/INR batteries for vaping for the better part of a decade. If a cell is not sold as Sony, Sanyo, Panasonic, LG… It was most likely made by one of them and did not pass QC and sold off to be re-wrapped with usually grossly exaggerated specs. How would you like to buy a car with exaggerated specs? Would you feel safe if you knew the car didn’t pass the manufacturers QC?
As a vaper you should know these battery manufacturers are trying to distance themselves from vaping. Probably due to liability. In any case you shouldn’t be surprised that cells will be sold under all sorts of names since they do not intend to sell directly to consumers. What you said may exist but it’s far from the truth if you are shopping at the sites we mention. Look at the batteries Eneloop makes without their name on it…
I’ve got plenty of cells from Banggood in the past, and they do seem genuine and test that way too. But, yeah, you could be right that they are not grade A or B cells, and failed inspection for some reason not related to performance.
I’ve bought from Illumn more recently, hoping to get a better guarantee of good quality cells. But, since the manufacturers don’t sell to consumers, I suppose there’s no guarantee of quality from US retailers either.
As consumers, we’re stuck taking the risk ourselves.
This thread should be renamed to how NOT to get batteries to Canada.
Why exactly?
I’m going to take back my Banggood recommendation for batteries, at least for their button-top 30Q’s.
I’ve bought a total of 9 of those buttop-top Samsung 30Q cells from Banggood, and now I’ve had 3 of them go bad. Suddenly, their self-discharge will start rising to unacceptable levels. I’ll get noticeable voltage drop every day (up to 50mV) from 3 of the cells, without using them. At best this makes them unusable in multi-cell lights (for a series config). At worst, this might indicate an internal short and make them dangerous.
Flat-top cells I’ve bought from Banggood appear to be fine. It just seems to be an issue with the 30Q’s that have an after-market button added. I’m not sure if they’re getting fakes, or it’s a bad grade of cells. But whatever the reason, make sure to check your button-top 30Qs.
