+1 … :+1: . .
Well, just in case nobody recalls wotnahell I was referring to…
yes,in plan
So the quad Carclo optics will not fit in the 21700 S2+?
C8+ powered by a 35-40A 21700 modded with a FET and led4power spacer + 6x MCPCB gives some possibilities :smiling_imp:
Simon, have you contacted Toykeeper about a ramping UI for that S11? I’m sure she can help you
My ramping driver is in production now ,It is controlled by a mechanical switch. I will describe the UI in detail later.
If Toykeeper has suitable solution, I will also produce the corresponding driver for BLFers
and I might design another 21700 host to fit carclo optics
Personal preference - S11 in 26650, LH351D 5000k, OP, Narsil firmware. But that’s just me
Ordered placed. Thanks for all the feedback and effort.
Ordered. Many thanks.
Simon could you include 22 to 17 mm. driver adapter in the package?
Ryzbor:So the quad Carclo optics will not fit in the 21700 S2+?
I thought you said the S2+ 21700 will fit carclo quad optics? Oh well, I guess at least I can swap in my triple pills from my 18650 S2+ into the 21700 S2+ for longer runtime and better heat dissipation.
Convoylover:Simon, Great that the 21700 light is coming!
I have put a 21700 in the Convoy BD01 and that fits fine lengthwise, so I expect that this will be fitting in the S11 too.
I hope that you also will have Biscotti drivers for XML2, XPL LEDs for the S11 / S2+ 21700, similar to the 18650 S2. I don’t always want XHP LEDs.
And OP and SMO reflectors similar to the M1/M2 lights
i will launch another version - S11 with SST40 and ramping driver
I’m very impressed with my S2+ SST-20, are the specs on the SST-40 you would use in the S11 the same?
I would recommend trying to get the 5000K SST40 Simon
Currently no adapter,sorry
+1
Satan@103TFS:Simon could you include 22 to 17 mm. driver adapter in the package?
I was wondering the same thing. A 17mm Led4power driver + Luxeon Mz might be good match for this host. Give me a chance to use the MosDTP 4040 board (copper not aluminum)
Looking at the Ali Express pill picture of the S11, maybe the driver retaining ring could be flipped around. And it would create a smaller shelf you could solder the driver to. You would need to carefully cut slots on the inner diameter of the ring so you could tighten it down. What are the dimensions of the retaining ring? Looks larger than a 17mm opening but there are a few 17mm To 20mm Brass Adapter Rings on Ebay.
Thanks for any help.
Can´t wait to get the light
Insta-buy! 26650 version as well!
Cheers and thanks!
no problem ,i will get some 5000K
Simon Mao: Satan@103TFS:Simon could you include 22 to 17 mm. driver adapter in the package?
i will consider to produce some adapters if many guys need it
contactcr:I would recommend trying to get the 5000K SST40 Simon
Excellent!! :+1:
