Thanks MascaratumB, good read on the 18350’s . I believe because of physical reverse polarity protection, RTT-01 needs button tops . I know sometimes certain cells won’t fit in these smaller lights and I wondered if anyone had encountered fitment issues.
I have correlated some voltages to lumen levels
a CR123 cell below 2.9v, cannot achieve 100 lumens maximum
a CR123 cell, below 3.1v cannot achieve 200 lumens maximum
and the IMR, above 3.9v, can achieve over 400 lumens maximum
visual data
note that for the IMR, I had to switch the scale on the light meter by 10x (yellow arrows), so the 43.7 corresponds to 437 lumens. In all cases, the rotary dial is at Maximum.
This is with an N219b 4500k 9080 LED mod in my RRT-01. My light meter is calibrated to my 200 lumen HDS.
Conclusion, when my RRT-01 w IMR battery drops to 25% of initial brightness, it is not yet overdischarged, and still safe to recharge.[/QUOTE]
[QUOTE=TIP AND RING;5280363]i have been using the unprotected Aspire/Vapcell 18350 cells and have been really happy with the performance of these cells. After any use, I charge them and test voltages. As a very simple rule of thumb I treat voltage readings as follows for li-on.
I haven’t had any issues with battery fitment as of yet. Purple Efest, Red Efest, and AW are the ones I have that fit fine. I had to solder blob the flat tops but other than that I haven’t had any issues. They are all unprotected. I don’t check voltage at all really. If it gets heavy use during a day I will recharge the cell, or once every few weeks otherwise. Haven’t found any 16340’s that wont fit. I have a ton of button top protected cells and a bunch of those cells with the charging port built into them. All of them fit fine though, I don’t use them. The 16340 format has outlived it’s usefulness to me.
ah, sorry, did not realize I gave you a link for a backordered item
worth waiting for…
my justifications on using unprotected IMR:
IF my RRT-01 gets noticeably dim between recharges, I take it as a low battery warning. Ive tested that behavior with a voltmeter and it has never been below 3.4v by the time I notice.
I can see the light is about half as bright, and I can tell Im having to turn the dial twice as far to get the expected brightness, when the battery is about half empty.
I feel reasonably safe using unprotected IMR chemistry. I have not had any overdischarge situations, have not left the light on and fallen asleep. I also test my battery voltage regularly, so Ive learned how much typical usage I can get, before needing to recharge.
I love having the 1200mAh cell in the RRT-01… double the capacity of my protected 16340 cells…
a couple more observations of 18350 IMR vs 16340 ICR in my RRT-01
The IMR will give me a maximum lumen output that is double the output I get with an ICR
I also just observed that the IMR flickers on maximum, when the cell is at 3.6v, I can tell the light is trying to go to a higher but the discharge level of the battery cannot maintain the brightness it could with a full charge.
What’s the current best (cheapest, most reliable) place to order the 2019 RT01? I checked out HKEquipment but their eBay store is often out of stock or don’t list it. Battery Junction has it but for $80 and I see people mentioning buying it closer to $70. Any tips would be appreciated. Thank you.
Battery Junction has it. Shoot them an email or phone call and see what they can do for you. I have had success getting a decent discount in the past. Mention BLF as well.
same here, no muggles w my IMR
and fwiw, the max lumens w my Keepower 18350 IMR is double what I get w ICR 16340
as a rough estimate, when my IMR is about half empty, at about 3.6v, its output is similar in lumens on maximum, to a fully charged 16340, at about 4.1v
I ordered mine from Battery Junction after this thread brought it to my attention. They showed it not available yet, I ordered it anyway. Ordered on the 1-28 and arrived at my door 2-5. So maybe yours will show up a little early too.
Once you own a rotary light it’s hard to go back to anything else.
The 2019 RRT-01 appears to be really large compared to the original. Does anyone have both? I’ve got a Niteye Eye-12 ” AA ” battery tube heading my way, seller says it has a bad switch. Hopefully I’ll be able to repair /replace the switch and increase my 01’s battery compatibility.
I don’t have the original but I have seen pics of the original and the new one does look to be bigger. I will say this is one hefty chunk of a flashlight. It’s not a feather weight or a disappear in your pocket type light. That being said it has a really quality feel to it. It looks and feels like it could survive a serious beating. I don’t know how much it weighs and I don’t really care to weigh it. It rides in my pocket just fine. The ring on mine works perfectly and the stated output seems about right, again I don’t really care to measure it but to my eye it looks plenty bright. I swapped the emitter in mine so it’s now to my liking.
The XPL that was in it was too cold white for me. I don’t use 16340’s so I use 18350’s in mine and the run times are just fine for my purpose. If it had a 14500 tube for it I doubt I would get it or use it. I got one for my V11R and it just made it too long so I gave it away. I have an abundance of 18350’s so running out of power for the light isn’t a concern of mine. I also if needed, have entirely way too many 16340’s if I get super desperate.
It’s a good light. If you are a variable ring fan, you will like it. I don’t use my lights to hunt walls, art, food, or anything else. They get used as tools because, well, that is what they are. I don’t think you will be disappointed.
I agree, the pic shows the new one is fatter. I only have the original
My Original RRT-01 Weight: 49 grams w pocket clip, empty
the weight with battery, depends what kind of battery I use, my 18350 is 25 grams, so my carry weight for the old model is 74 grams including battery.
this review 404 您访问的页面找不到了_腾讯网
says the new RRT-01 weights 75 grams empty
that tells me that the new model weighs 26 grams more than the old model.
I like to use my tools to hunt white walls, and I weigh them
I do not plan to buy the new RRT-01 because I am fortunate to have the original.
the new model is
fatter
heavier, (empty weight is 53% heavier)
the ball track has hash marks, it is not smooth like the Original model
but, the old model is NLA
so, I think the new version gives those less fortunate, an opportunity to enjoy a magnetic rotary UI and 18350 power, which I think is really cool!
