Thorfire VG10S....opinion
43 posts / 0 new
Spartan
Last seen: 2 weeks 3 days ago
I have a bunch of 18650 doing nothing and the Thorfire VG10s is cheap.
Sooo…..I want to buy a few as all around flashlights to retire the old AA and AAA cell lights. Actually, at 1100 lumens, it’s more powerful then my old TK45’s that cost 120 bucks a piece. Progress…..
What is throw on this? I prefer spread in an all around light so if this is a thrower, it’s not going to serve me well.
Any reliability problems?
And……can I modify it? The probability of damaging it is pretty high but because of the cost, no problem.
Moses came from the mountaintop carrying a tablet. The Words were....WITH GREAT LUMENS COMES GREAT REPONSIBILITY.
Edited by: Spartan on 02/23/2019 - 16:27
toddcshoe
toddcshoe's picture
Last seen: 3 min 1 sec ago
It is a good mix of both. I think it’s one of the best bang for your buck lights around right now. Driver and emitter are easy to get to if need be. Just a great all around light. Good moonlight mode too. Not usually included in lights like this. I have more than a few of them in camping/fishing/hunting bags.
"Everywhere I go, there I am"
pennzy
pennzy's picture
Last seen: 2 min 31 sec ago
There was a kick arse Vipon deal the other day where you could get 2 for under $20 with stacked coupons. Maybe it will be back.
Spartan
Thanks T.
I bought one and it will be here in a few days.
If the beam is decent spread, I’ll buy a few more and use one to finally join the alcoholics flashoholics club by breaking modifying it. I read so much, might as well put it to destroy built something more crazy useful.
EDIT…..searching for any mods, seems nobody has done one. Maybe I will be the first to fit a CXB-3590. I’m about to be slapped silly in 3…2…1…
BlueSwordM
BlueSwordM's picture
Last seen: 19 min ago
How about a 4000k SST-20 mod?
Spartan
OK….why that? What will I gain? AND……are you prepared to walk me through the valley of the shadow of led death brilliance?
Ummmm….
https://www.youtube.com/watch?v=5swA3_OYAY0
BlueSwordM
1. Better tint.
2. Much much better color rendition.
3. Better throw.
Thorfire TK15/TK15S/VG15S/VG10S lights are very easy to modify.
To make it even easier, just buy the SST-20 reflowed already from there:
https://www.aliexpress.com/store/product/luminus-SST20-4000K-5000K-6500K...DTP-copper-board/330416_32975568763.html
Spartan
BlueSwordM wrote:
1. Better tint.
3. Better throw.
Hmmmm…..95 CRI? Wow.
Noticed the thick copper plate.
What does re-flowed head mean? Sorry for the really somewhat mostly dumb question.
BlueSwordM
It’s already been soldered down to the copper LED MCPCB.
That means you only need to:
1. Open the head.
2. Remove the XM-L2 MCPCB by desoldering the wires and unscrewing the screw.
3. Put it the new SST-20 4000k with the MCPCB.
4. Solder the wires back, with some thermal paste under the PCB.
5. Close the head back.
Done Smile
Spartan
1. Open the head.
Done Smile
Almost sounds like my sex life
I’m rummaging through the aliexpress. Are the XHP50.2 above the ability of the VG10 ability to handle it?
Or…..it doesn’t really matter because the current available is constant and limited to any LED. Another way of putting this, does the LED drive the demand or does the circuit make x amount available regardless of LED.
Again, sorry if it sounds like a dumb question.
EDIT….will pick it up later. I’m taking the Q8 and clubbing baby seals spying on the neighbors wife checking up on some properties in anticipation of tomorrows howling winds.
pennzy
pennzy's picture
The XPH 50.2 is a 6 volt emitter. Yours is a 3 volt.
robo819
robo819's picture
Last seen: 1 day 16 hours ago
Here is what 3 different VG10 with FET driver , look like with 3 different emitters if it helps any.
10 feet from White Garage door with each light
XM-L2 U4 1A (dedomed)
XP-L V6 1A (dedomed)
XP-L HI V3 3C
All 3 emitters side by side (on medium setting with FET driver)in order of ….Left – HI V3 3C / Middle – XM-L2 U4 / Right – XP-L V6
Here is the Stock VG10 vs the modded light with the Dedomed XP-L V6 1A to show the difference that it makes. (95yards to Gate) taken at different times , but good enough to see the better throw and slightly less spill area of the modded light and also the tint difference from the really cool white of the stock emitter.
Stock LIght
Modded Light
Click any link to see MY REVIEWS:
Maxtoch M24 Sniper / Maxtoch 2X Shooter (2016 factory dedomed) , 2X - XHP 70.2 / Maxtoch Xsword / M1 Archer *** ### ThruNite // Archer 2A V3 / Ti4T / TN4A HI / TH10 / TH20 / C2 Mini / TC12 V2 / T01 /  , neutron 2C V3 , TC20 / Catapult V6 / TC15 / TC15 CE *** ###  Olight // H2R Nova , S10R III / S30R III / H1 Nova / H1 R Nova / X7 Marauder , PL Mini ,  M2R warrior //// Orca T11 / Nitecore EC20 / BLF A6 / Custom Convoy C8 / Lixada Triple 3800LM / Lixada 1000LM / LuxStone X30 / Manker E02 / Manker E14 II /  ### Thorfire /// PF03PF04 , Upgraded PF04 , C8 , S-50 ,  VG-10 , VG25 , C8s , BL30 , TK4A  , S1 , VG15 S  , TK 18 //// ##WowTac// A4 , A1 (original) , A2 headlamp , A3 //// Acebeam L16 /// Massdrop (Lumintop) Brass EDC
Spartan
Thanks robo. Interesting how different the throws are with just a change of led.
We’re going a bit on the wrong direction in what I like for an all around light. I prefer a large hot spot, soft spread with more light in the spill. The range of use will be about 200 feet.
On your bottom two pictures, I prefer the stock to the mod.
I have a cheap coast light with adjustable lens. I like the full spread light when doing chores or taking outside. A 500 lumen version of that would be interesting.
If I can’t get what I want, who cares, 10 buck light. I’ll still fool around and maybe do what you did.
Thanks for posting the pics.
robo819
robo819's picture
NO problems…….Just a change to a better LED would probably be the thing for what you are saying. Something like the XP-L V6 3D with the dome left on it would give a pretty good neutral tint (around 5000K) and the kind of coverage you see in the “Stock Light” picture.
If you went with a more powerful driver like the FET , then you would also gain a lot in the lumens along with the better tint.
Spartan
“more powerful driver like the FET
Whoosh….over my head….I’m playing tennis with a ping pong paddle.
I’m getting the light in a few days. Then I’m going to take it apart and you guys can torture me while I ask stupid questions. Actually, buy a few more so i could do comparisons.
BTW…when you say the XP-L V6 3D is a better led. How? Three criteria matter…ay least in what o consider criteria….lumens, CRI and efficiency. Does that the XP-L best the OEM led?
Thanks robo.
BlueSwordM
Send me one too lol.
I’ll replace the LED for an SST-20 3500k and some much better springs.
The only problem is that I don’t have a 16mm MCPCB.
Spartan
Where in “Canada” are you. I’m in the GTA, aka, Center of the Universe. (Only a canuck would get that.)
BlueSwordM
Oh boy that’s too far, unless you want to pay 15$CA for shipping Facepalm
robo819
robo819's picture
Thanks robo.
The XP-L2 emitters tend to make the olive color in the corona area , as do many of the emitters that have the phosphor all the way to the edges of the substrate. The XP-L V6 in the VG10 should give you a much better (smoother) overall tint in my opinion , the lumens probably wont differ that much between the 2 emitters , especially if you stay with a stock driver. I am not sure how the efficiency stacks up between the 2 though as I don’t usually leave the XP-L2 emitters in anything because I hate that olive color around the edges.
EDIT: The stock driver is probably making around 3 amps? With a FET and XP-L V6 you should get on up around 5.5 to 6 amps , but then there goes the efficiency in the high and or turbo mode. You would have the power there if you wanted it , but if you used the “Standard” firmware with either 5 or 6 modes , then you could run in a lower mode (3rd or 4th level) and get close to the 3 amps of the original driver. The FET would be one like THIS or THIS
Also your preference of tint would come into play…..in the XP-L V6 the 1A for cool (6500K to 7000K) and for the more neutral tint the 3D (4750K to 5000K).
Spartan
I’m going to see if I can do a mechanical adjustment. I’m guessing that a small change in the reflector to led position will make a big difference.
Sheesh….all this chatter for a cheap light. Must be some kind of addiction… Sick
robo819
robo819's picture
Many Many cheap and also expensive lights have become monster lights from the people in this forum though….lol
Serlite
Last seen: 1 day 1 hour ago
I wonder if using DC-Fix could bring the stock light closer to your ideal characteristics. Would lessen the coloured corona, and trade some of the beam’s throw for flood.
sigh, now I want to grab a couple more of these myself…
Satan@103TFS
Last seen: 5 hours 14 min ago
Where to get this for 10$?
Spartan
Amazon.ca
With exchange, they landed up as a bit more then 10 USD
BTW…I think they were on sale on Amazon.com a couple of weeks ago.
Spartan
DC-Fix.
Now I have to send it to the DC political swamp? Or stick it up a politician’s….
What is a DC-Fix?
robo819
robo819's picture
DC Fix is diffusion film that spreads out , or diffuses the light (sticks on the lens). The thing with it (if you are after the best output) is that you do lose some lumens when using any kind of film or filter.
Spartan
I got this afternoon and my first impressions are….
The hot spot is narrower then I like in an all around light, in actual use, it’s not bothersome.
Love the comparison with my TK45. It’s about the same output with no comparison in size. It’s like the old brick phones to a smart phone.
It’s a bit toward the warm yellow range, but not too much that it tints everything. In practice, it’s not noticable.
No knurling and it feels a bit slippery. Might have to put a couple of oring on the tail cap.
All in all, a heck of a bargain for what it can do.
DavidEF
DavidEF's picture
Last seen: 21 hours 48 min ago
I totally missed this thread until now. Nothing left to say, I guess, except if you’re interested, HERE is your DC-Fix.
- The YKK Philosophy
Spartan
What happens when you shorten the reflector?
More spread beam? Narrower? Or junk?
robo819
robo819's picture
Probably end up ruining the reflector because the coating inside is very delicate and will chip , scratch and flake very easily. I have enlarged the hole in the bottom of the reflectors a few times , but it must be done slowly and carefully even then.
Knobby
Last seen: 1 week 6 days ago
Airsoft Rifle Light ?
a) Would this Thorfire VG10S make a good mounted light.
b) How easy would it be to Mod to single mode only.
c) Would a Convoy C8 (or other) pressure switch fit.
Just kicking around a few economical idea’s………. Thanks
