LedLink:
LL01ED-ASAxxL06-P, LL01CT-APGxxL06-M2 are up to 26.5
LL01ED-ABXxxL06, LL01CR-BAYxxL06 are up to 24.2
This product is no longer available.
LedLink:
I intended to write about Fresnelized TIRs for a while…
A simple TIR lens guides light on 2 paths:
The light emitted forward is refracted as it enters the lens and again as it leaves it.
The light emitted sideways is refracted, TIR-reflected and refracted again.
It is possible to fold one or more surfaces to reduce height. Some call this TIR-R, some Fresnel-TIRs.
Here’s a one-time folded Kingbrite KB-H43-3-XP
Four-time folded Ilenstech ILENS508-COB90-10-H
You don’t have to fold the sides, you can fold the front instead like Ilenstech ILENS576-COB69-12-H
Or you can fold the back like Darkoo DK4304-XP-G
Here’s a good paper that generalizes the concept:
https://www.orafol.com/tl_files/EnergyUSA/papers/LED-Source-Modeling-for-Optical-Design-workbook_Davis_2004.pdf
And some more papers / articles:
Note that Ledil makes Fresnel TIRs too:
https://www.ledil.com/product-landing/single-lenses/OLIVIA/
I think I’ve seen some Led Lenser that had the outer front folded though I can’t find it now.
Thanks… that’ll work for one, though still liking for something for over 30mm dia. COB…
This one is up to 30 mm:
Yes, great… though I don’t have a need for 200 (MOQ)… trying to find a distributor stateside, hopefully…
You can contact them. Maybe they’ll sell fewer.
Louie, not sure if that’s interesting for you but there’s also Ledil Stella - a silicone lens family for 30 mm LES. Over 30 mm I also see only reflectors.
I dis find a seller on Alibaba that has 30mm glass COB TIRs and aluminum housing… Will check out those LEDIL lenses too…
Interesting diffuser in a small Verbatim bulb. This sits on a small Cree CXA COB. Old & inefficient (65lm/W), but it was only 1.40 so I bought it.
I’ll have to take pictures but it’s a very nice and even “beam”. Now if there’s a way to fit something like this on top of a 1” flashlight…
This is one of the biggest TIRs, 75mm
It’s only been tested with COBs up to 23mm but the LED opening seems much bigger than that.
Only problem is that when using a TIR with a large LES LED then the angle of incidence varies a lot, which may cause light leakage since total internal reflection only works at large incidence angles.
Auer makes a 110mm hybrid reflector but only takes max 9mm dia. COB.
I found a manufacturer on Alibaba that makes 100mm TIRs for COBs up to 30mm in 10, 15, and 30 deg. FWHM.
Khatod Cosmo is another family of lenses that employs Fresnel TIRs.
There’s one zoomie construction that I haven’t seen on a flashlight yet but found 3 lens makers that do it:
Moving lenslet array based.
Near the LED there’s a fixed TIR. The TIR has a lenslet array at the front face.
In front of the TIR there’s another lens. Its back is the exact negative of the TIR’s lenslet array; the front may be flat or refract the light in other ways.
When both lenses are very close (pretty much touching each other) - the lenslet array doesn’t do much, it’s almost like a regular TIR.
When they move out - the beam gets wider.
Pros:
Cons:
Makers:
Polymer Optics makes zoomable TIRs even a 7-up version….
Indeed. I was interested in it a lot some time ago but stopped caring because beam shape when zoomed out.
They have a really cool color mixing TIR with a spot beam…
As well as 7-up XHP50.2 lenses. Hint! Hint!
I said I didn’t expect good beam shape from multi-led Fresnel lenses.
Now I see that Khatod makes PL1172, a 90 mm 9-up:
http://www.khatod.com/EN/product-1010/Fresnel-Lenses-for-Power-LEDs—Autofocus-Lenses.html
Beam actually looks OK except that flood is not spotless it’s more like a reflector than like aspheric.
Here I see a reference to PL1175 - a 50 mm triple Fresnel but I fail to find anything more about it.
I can’t figure out how does this reflector work:
Where do I put the COB?
The description states PC with aluminum coating… I can only postulate that the center is not coated; helping to effect the large beam angle. And it’s a HUGE angle…
That said, out of curiosity I requested a sample…
