Looking forward to seeing some pictures.
I restore vintage Kawasaki motorcycles as a hobby. I've used electrolysis for rust removal for a few years. It works well, is environmentally benign, and inexpensive. It removes rust from inside gas tanks without harming paint.
For small parts I use a 5 gal. bucket lined on the inner side and bottom surfaces with chicken wire for complete "line of sight" surround current flow. I modified my original direct-wired setup with a 12v turn signal bulb as a current limiting resistor.
slmjim
Like a total idiot, I forgot to take big before pics of most of it (have a group shot) - took loads of the setup etc lol!
I did put an old knife half in thoughā¦ā¦ about 35 years ago like boys are, I was drawn to my Grandads gardening knife (who knows what it actually was) but he always used to make out it was his āArmy knifeā which got my attention lol, I used to love playing war in the fields, building dens etc. Anyway itās been sat around in the garden, and shed for all that time so itās pretty rusty. I remember mending the handle when I was a kid by sawing the top 5 inches off my nanās yard brush (she wasnāt happy) and splitting it, itās still on there now, just about - crude nails through it and remnants of Sellotape!
If it turns out anything like usable Iāll restore it totally, will make a nice sentimental project. Of course, Iād have to still do it with yard brush handles for authenticity!
Sounds like we have something in common.
Iāll let you guess what that is.
This was quite fun and safe to do so long as you are sensible, Iād say have a go yourself. I got pleasing results, going to have another go next week.
The parts have come up a treat. Thanks for the pics and write up.
So, do any of you guys do electroplating? I sure like me some copper acetate, and a copper plated nickel plated BeCu spring.
very cool, great info about the chicken wire, and that electrolysis does not harm paint
If I want a copper plated flashlight, can I just drop it in a bucket with some of this special Juice:
I was hoping this thread would lead me to a how to tutorial,
to produce a Copper plated Flashlight
Do you mean a brass copper plated light or an aluminium copper plated flashlight?
Both are doable quite easily, but an aluminium flashlight would have to be de-anodized first, and would have to use copper sulfate instead of copper acetate.
yes and thank you
aluminium host, plated with copper
those two novatacs are aluminium
I fantasize about a copper plated RRT-01, and Sofirn C01
some people would also want Titanium platingā¦
but, I dont mean to hijack this threadā¦
if there is a better place to lean about this, I welcome a link
Donāt worry about hijacking lol, itās all very interesting to me too!
After some workā¦
EASY AND SAFE COPPER ACETATE PLATING
Material needed :
- Adjustable DC-DC Power Supply to create copper acetate the copper solution
- 5V DC Power Supply if the above is not available
- 1,0V-3,3V DC Power Supply for electroplating. Closer to 1,0V for all parts, and closer to 3,3V for very large parts.
- Alligator clips (1 red and 1 black for positive and negative)
- Any source of copper. Scrap copper wire, or a copper sheet will work well.
- 5-8% acetic acid. Vinegar is a good substitute.
- 30% Hydrochloric acid(muriactic acid)
- High grit sand paper (500+)
- Liquid soap.
- Glass jar or beaker that fits your part
- Small glass or plastic tray.
- Heater or hotplate
PROTOCOL 1 (PREPARING THE ELECTRODES)
- Prepare the copper electrodes by cleaning them mechanically with 500+ grit sandpaper.
- Wash the copper electrodes under water with soap.
- Fill the small tray with hydrochloric acid, and the electrodes in it for 60 seconds to clean them completely. Rinse with water to get rid of the hydrochloric acid. Keep it for later.
- Repeat the first 3 steps for cleaning the positive electrode for electroplating.
PROTOCOL 2 (MAKING THE COPPER ACETATE SOLUTION)
- Fill the jar with vinegar or 5/8% acetic acid.
- Connect the alligator clips to the cleaned copper electrodes. Note the polarity of each.
- Put the copper electrodes in the acetic acid jar.
- Connect your 5V power supply to the AC receptable, or set your power supply to a voltage of 4,2-5V, 4,2V for slightly higher copper acetate concentration, 5V for faster creation.
- Check if there are any small bubbles forming on the negative electrode. If there are small bubbles forming, but not floating up, that means the setup is working.
- Let the setup run for 8-12 hours, preferably during the night.
- Check the jar for any copper deposits. If there are any solid deposits on the bottom, filter out the solution via gravity filtering, or just empty the jar slowly into another container without the copper deposits transfering in the other container. Clean the jar. Put the solution back in the original container.
- Clean the parts/materials youāve used during the copper acetate solution creation.
PROTOCOL 3 (ELECTROPLATING THE PART)
- Prepare the part by cleaning it mechanically with 500+ grit sandpaper.
- Wash the part with soapy water.
- Put in the part in the hydrochloric acid bath for 1 minute, then clean it in water.
- Connect the positive copper electrode previously cleaned to the positive alligator clip. Put it in the jar.
- Connect the negative alligator clip to the part you want to plate. Put it in the jar as far away from the positive electrode as practical.
- Plug the alligator clips to the preferably 1,2V adjustable power supply, or 3,3V power supply.
- Leave the setup running for 2 hours at 3,3V, and 4 hours at 1,0-1,2V for optimal results.
- Unplug or deactivate the power supply.
- Get the part out of the copper acetate solution.
- Clean it with water, and let it dry. You should have the copper plated part.
- Polish it with steel wool.
- Put the copper acetate jar somewhere safe, and label it as Copper Acetate Solution.
Final note : The jar can be placed on a temperature adjustable hotplate to 50C for faster and more durable plating due to the lower resistance solution and less hydrogen formation.
The 1,0V-1,2V setup will get thinner, but more much durable plating for small parts, while 3,3V will plate faster, but is not recommended to use on small parts like springs and connectors.
If you have any questions, just ask BTW.
I also have a copper chloride solution that works better, and a copper sulfate solution, but both are toxic.
Copper acetate is toxic, but not as much, and can be flushed down to the toilet with a full flush, or 2 flushes if needed to dilute it.
After some workā¦
Wow
that is an awesome write up
I think there may be people that would want your servicesā¦
would you consider doing a Novatac?
This is a great thread. I was afraid it was about removing unwanted hair so I was a little hesitant to open it. Donāt usually want to see before and after pictures of that sort.
@jon_slider, not yet.
Youād first need to de-anodize the light, or start with a bare light, like the BLF A6.
Youād then need to nickel plate the light, since the copper solutions we have access to, even copper sulfate, canāt make a good coat directly on aluminium. But nickel can.
We could then copper plate the light with a copper sulfate/copper chloride solution for highest plating durability and thickness. Copper acetate will work, but isnāt optimal due to the higher than optimal pH of the solution.
HOWEVER, it is doable, and Iām waiting for some pure nickel, and a BLF A6 non-anodized to test it out, since Iāve bought hydrochloric acid today to make a copper chloride solution.
UPDATE
Iāve got some 30% hydrochloric acid on hand for some more advanced plating
Iām also in the process of making sulfuric acid using epsom salts, and lead acid battery separators(bought on Alibaba).
@jon_slider, I also need some zincate to process the aluminium.
After that however, I just need to copper plate the part, and be done.
Itās going to be expensive starting it out if I only make 1 light.
Used to do a lot of electroplating at a previous shop, now we work with cadmium and Nitrided surfaces, some times beryllium copper coatings and even machining BeCu parts which means a tyvex suit and respirator. I see you advertise BeCu spring BlueSwordM so Im sure you are familier with the side effects from that nasty material. Been trying to get a de-anodized A6 to be Cadmium coated but no luck so far haha. Might be able to sneak it through on the Nitriding rack though one day.
Yeah. I will never sand a BeCu spring in my entire life unless I want to end up with lung cancer.
Have you tried a zincate solution? Thatās the only thing blocking me from plating aluminium, since nitric acid is even more expensive, so Iām not going to touch it.
Iāve done copper acetate, and copper chloride. That last one is super easy to get a thick durable coating quickly at low power levels, but hard to get a thick coating(50um) over time since the cathode/part tends to get coated in a copper crystal rough formation.
Copper sulfate is the one Iām looking for, but since copper sulfate is super expensive here(30$ for 2lbs!), Iāve decided to get myself some sulfuric acidā¦
Until I found it was even harder to acquire clean sulfuric acid. Or stupid expensive shipping, especially for a small quantity.
Iām currently working on the process of making a galvanic cell with a fiberglass separator to make large quantities of concentrated 98% sulfuric acid. Itās going to be amazing, and cheap to make.
I might sell leftover fiberglass separators to see if there is any interest.
