Anyone who has expressed an interest in a lantern should verify that their BLF user name is correct in the Interest list by user names link. When the lanterns are ready for purchase the pmās will be automatically generated based upon the user name in that file so if your name is incorrect then you wonāt be getting a pm
This is a one time only check so if your name is correct now then it will be correct going forward. In other words you only need to check once. Note that embedded spaces are valid characters so for example a name having one embedded space is not the same as a name having 2 embedded spaces.
Different letter cases in the user name doesnāt matter. Eg. Userxxx is the same as uSERXXX for the purposes of the pmās.
If a name needs to be corrected send me a pm and donāt just post it in this thread because it could very well be missed.
DO NOT send me a pm saying that your name is fine.
I like this one for the
BOSE SOUNDLINK REVOLVE BLUETOOTH SPEAKER
15,2 cm x 8,2 cm x 8,2 cm (HxBxT)
Has a little extra space for the charger. Is even tapered, but I donāt know if it fits. (probably a bit to wide)
US $12 New PU Travel Case For Bose Soundlink Revolve Case EVA Carry Protective Speaker Box Pouch Cover Extra Space For Plug & Cables https://m.aliexpress.com/item/32853843814.html
There is a V1 in the works, thatās for sure
We can have ideas and wishes for a V2, but it is up to Sofirn to think it feasable enough to actually make it, so it could happen but I would not bet on it at this point.
I found myself on the list, #672, but I think Iām miss understanding the name check. Itās definitely correct, but I canāt click my name and go to my profile.
The name check is just to verify that itās correct in my database as I donāt have any way to join my tables to SBās server. When the lanterns are ready for purchase I will create the pm lists on my end that SB will execute on his end to send out the actual pmās. If the name is incorrect in my table then that person wonāt receive a pm.
Clicking on your name on the list wonāt take you anywhere and is solely intended as a visual check. Itās a one-time only verification so since you saw that itās right then you donāt have to do it again.
Btw the Entry number on my lists do not necessarily correspond to the oneās that DBSAR show for minor technical reasons (although 99% are the same). But the order they were loaded into his and mine are exactly the same for anyone who is curious or worried about that.
