Help Me Choose a Weapon Light Gift
11 posts / 0 new
Knobby
Last seen: 8 months 3 weeks ago
Ok, my friend has asked me to get a Weapon Light (for a rifle) for his son, to use at Air Soft tournaments. His requirements are Single Mode only, Super Bright, 1 × 18650 Battery & Decent Pressure Pad. This is what I’ve considered so far:
1) Convoy C8, Nichia 219C, 7135 × 8, Biscotti Firmware, & Pressure Switch. Convoy Flashlight Store.
2) L2, 900 Lumen Single Mode P60 Drop-In, & Pressure Switch. Solarforce.
3) Thorfire VG10S
4) Other pre built suggestion’s welcome.
5) Custom Mod suggestion’s welcome (including parts list)
Note: Will need something fairly robust, he’s hard on his equipment.
Thanks …………. knobby
edit/add: I would like to keep this under $50
Cool
Edited by: Knobby on 03/28/2019 - 15:59
CREEXHP70LED
CREEXHP70LED's picture
Surefire WML. He didn’t specify a cost limit, and those are the only ones I have and use. Seriously I wish I knew cheaper option for Air Soft. I saw the Olight Warrior with a pressure switch, I do not know who would use it as a real weapon light that has real world experience shooting people, so maybe it would be good for Air Soft.
Deputy Dog
Deputy Dog's picture
Last seen: 2 weeks 4 days ago
That Olight set up actually works well on a rifle. I set the contact switch for my thumb.
CREEXHP70LED
I am with Mrgunsngear (Mike) on this one. He has a YouTube review on it. YMMV.
DOC1500
DOC1500's picture
Last seen: 10 months 1 week ago
Nitecore P10GT 900 Lumens Rifle Mountable Premium LED Tactical Flashlight Kit with LumenTac Picatinny Rail Mount and Strobe Ready Pressure Switch https://www.amazon.com/dp/B00OUBCB9S/ref=cm_sw_r_cp_apa_i_ErTFCbSBVP9SM
I have this on my AR-15 it really lights up the night.
A lie is a lie even if everybody believes it.. The truth is the truth even if nobody believes it.
John 3:16 --
2 Cor 5:17
jf_smm
Last seen: 12 hours 45 min ago
My son used to do airsoft and the big problem with weapon lights was they kept getting their lenses shot out. Whatever you pick should probably be something you can tear down and swap lenses without tools.
Hope he enjoys it!
Deputy Dog
And I’m not using an AR platform or the Warrior X. He has a different set up. But it should work well depending, for air-soft.
I have an older model set up (not magnetic).
Knobby
Thats a solid point jf_smm makes about the lenses getting shot out, I hadn’t thought of that. Maybe I should circle back to the Solarforce L2 with a dropin. They might not be cutting edge technology anymore, but there easy to breakdown and repair.
Question: Does anyone know if the Solarforce 830 Lumen XP-L V6 Module has (LVP) Low Voltage Protection. ?
panhead
Last seen: 1 week 4 days ago
    The JobSmart weapon light Tac 360 at Tractor Supply Co. might be an option.
    360 lumen 2600 mah lith batt  and a charger.  Both tail caps, pressure sw and
    click switch.  Not bad for $25.00    Don't know if available in BC thou.
I am the bump in the night
Jack Kellar
Jack Kellar's picture
Last seen: 6 hours 41 min ago
As for the lens getting shot, wouldn’t a TIR optic be more resistant? If you’re already looking at a Convoy, how about a tight-beam S2+? (Not sure if it accepts a pressure switch like the C8 though…)
Knobby
I just saw this Sofirn on Aliexpress. Sofirn C05 Tactical LED Flashlight Weapon Light. Looks interesting, but I can’t seem to find any reviews on it. Does anyone have any experience with this flashlight? …. Thanks
https://www.aliexpress.com/item/Sofirn-C05-Tactical-LED-Flashlight-Weapon-Light-Pistol-Gun-Flashlight-Lanterna-Cree-XPL-1000lm-with-remote/32995435789.html?spm=2114.search0104.3.2.57372f81PbVNar&ws_ab_test=searchweb0_0,searchweb201602_7_10065_10068_10130_10547_319_10059_10884_317_10548_10545_10887_10696_321_322_10084_453_10083_454_10103_10618_10307_537_536_10902,searchweb201603_70,ppcSwitch_0&algo_expid=ece108c4-4ea9-4857-bba7-e5a0ae1f92e7-0&algo_pvid=ece108c4-4ea9-4857-bba7-e5a0ae1f92e7&transAbTest=ae803_3
