+1 X3 style
It looks boring, but still better then the other designs and seems practical.
+1 X3 style
Simon,
Not sure if anyone asked you already this question but as you are already working on new S2 host maybe its a good time to ask.
Would you be able to produce a 18350 style headlamp with the head and reflector in the middle?
something like this (TN-20)
or this (EHL0628)
or even like this (S3 “eebowler”)
any chance on codes for 580 lumen convoy s9?
I need 12 asap
To: sochi111
following one will be available in one week
max output 2500mA
0.1%moonlight-3%low-30%mid-100%high ,strobe(double-click the switch); if the flashlight is turned off ,press the side switch,flashlight can enter into moonlight mode directly.
what about S9 2500mA version 900-100lm
@Simon, that headlamp looks amazing!
Would it be possible to order with SST-20 4000k?
If so, it would be awesome!
What’s the UI on this? Long press for off, or single click? Will this be available with the 219C?
Maybe, though these are intended for regular non flashlight geeks…
So I am concerned about heat…and cost to an extent…
Last time around I think I managed $16 or something (i’d have to look that up) Best I see is $18
Simon Mao: justanotherguy:any chance on codes for 580 lumen convoy s9?
I need 12 asap
So I am concerned about heat…and cost to an extent…Last time around I think I managed $16 or something (i’d have to look that up) Best I see is $18
$17.69 including 15%off
Simon Mao:To: sochi111
max output 2500mA
0.1%moonlight-3%low-30%mid-100%high ,strobe(double-click the switch); if the flashlight is turned off ,press the side switch,flashlight can enter into moonlight mode directly.What’s the UI on this? Long press for off, or single click? Will this be available with the 219C?
yes,long press for off,and single click to change mode
only CREE XML2 version currently
and i plan to produce charging version soon,
SST20 can be adding in plan
Still, thank you a lot!
I’ve been waiting for a Convoy headlamp for such a long time.
I love your lights’ user interface, build quality, and easy modification.
Is it easy to open for modification?
Thank you again.
I would love an 18350 tube for that headlamp, instant buy.
Looks like a screw-down bezel on that headlamp? Should be easy to swap emitter/MCPCB right?
Is the driver easily accessible for modding as well?
justanotherguy: Simon Mao: justanotherguy:any chance on codes for 580 lumen convoy s9?
I need 12 asap
I’ll take them. whats the specific ordering instructions
1400ma, correct?
Looks Good, Simon. I’ll be buying a headlamp and an S11 as soon as available!
I was going to suggest that instead of using a hateful little reflector, standard 20mm TIR lenses would be ideal.
They can be swapped easily from narrow-angle to wide-angle in a minute or less, and would blend colors so much better to eliminate tint-shift and “fried egg” beams (yellow center hotspot, blue-white outside spill).
The 4C that’s commonly used in the S2+ has a fried-egg beam. White spill, yellow hotspot. After substituting a TIR lens for the reflector, the beam was perfect, like warm sunlight.
To: sochi111
max output 2500mA
Nice light but it look similar to h03 skilhunt
Anychance you selling host? I’m Looking to use different drivers and led.
Simon why do you hate my wallet so much D:
Very sexy, hopefully easy to swap emitters! Agreed with the TIR sentiment; I still need to buy the 5pack to find the one I like the best.
To: sochi111
max output 2500mA
Wow Simon,
I know I was asking for too much for a centered headlight Maybe later
But that is an awesome light.
