Do i understand it right. The sideswitch on the H1 has no led behind it?
Why not?
To make the reflector cavity compatible to use TIR optics sound like a very good idea!
This would allow people to change it from throw to flood like they prefer.
And the use of a TIR would allow me to mod the H1 with a TIR backlight like i did with my H03.
Thanks for your explanation.
i will launch H2 H3 H4… in the future,
You made me understand the needs of the users. In terms of weight, I will design a headlight that is more suitable for the user.
The DUV is super high, which means this emitter will look very green . Hopefully Simon can source some hi cri emitters with low DUV like SST-20 with FA1, FA4, FD1, FD4 tint bins or Oslon Squares with below the BBL tints.
Probably, most people will be happy with emitters spot on black body line (duv +0.001 to –0.001). I think, reddishness (or rather rosiness) to duv –0.003 is acceptable (and helpful with recognizing blue and red details), below that I consider it a bit of special use.
In practice, while SST-20 LEDs are promised to be on black body line with tints FA2, FA3, FD2, FD3, they are a bit more yellowish, when used on lower currents. This is why SKV89 recommended to source the tints above (FA1, FA4…), because they can hit the black body line better (especially, when not just bare led is measured, but optics as well).
In practice, I found the FB4 tint of SST-20 very appealing for outside use, if it is driven around 2A, because the tint changes, so it is noticeably rosier, than if multiple same LEDs were driven at a much lower current each.
It is very difficult to source Nichia 219C with proper duv values, and this is more visible for emitters in the 2700K-4000K CCT range. But for me, even a slightly greenish (duv up to +0.003) 219C is fine, if they are in the 5000K-5700K CCT range.
To cover the ‘cool white’ range of CCTs with high CRI emitters, do you consider to get Samsung LH351D emitters (they have 90 CRI for both 5000K and 6000K CCT)?
Those emitters are a bit less throwy, than 219C, but overall, they have somewhat more output (also, it is safe to drive them far past 4A with good heatsinking) - and maybe a bit less green.
LH351D in 5000k with 90CRI is very nice - popped some in a Wowtac A2S and an Olight S Mini. Unsure about the lumen drop from the original emitters, but the A2S on turbo can still spit out a lot of light.
I personally like very low duv for warm white emitters after tons of comparisons. For example, I have a Tiara Pro with 4x E21A consisting of 2x2000k and 2x3000k for a 2500k mixed cct and a 4x E21A consisting of 1x2000k and 3x3000k for a 2750k mixed tint. However, the 2750k looks much warmer than the 2500k and everyone I asked thinks the same. The reason is because the 2500k has a very negative duv (rosy tint), whereas the 2750k is less rosy. I think the very negative duv allows our eyes to adapt to the tint much easier so whites appear whiter on the 2500k whereas on the 2750k, whites appear more yellowish tinted. But even the 2750k is probably at least -.003 duv since it is rosier than all of my SST-20 3000k. I’m guessing the 2500k is about –0.006 duv. The tint on the 2500k is absolutely gorgeous and pleasing to look at and use for ambient lighting.
To be clear, I’m not saying Convoy should use direct-drive FET drivers. They’re probably a bit overpowered for most of Simon’s customers. But a “moonlight special” 7+1 driver would be nice. Or something with similar capabilities.
Although high efficiency buck/boost driver would be ideal, I really like this idea of a Convoy headlamp with 7+1 moonlight special for a budget headlamp. Add in Anduril and this could sell like hotcakes.
I agree - a highly efficient driver (and LED that is efficient for its output/tint) would be ideal but I also really like this idea of a Convoy headlamp with 7+1 moonlight special for a budget headlamp. Add in Anduril and this could sell like hotcakes.
This gives a huge advantage because the tint will stay below the BBL, thus being pretty, at all levels, even on the low modes. Recently I’ve organised a group buy for a very-high-cri custom headlamp for some of my friend’s, not real flashoholics or tint snobs, more regular users. Four of them got the 4000K CRI9080+ version, the tint lands on the BBL at on the 300-700lm modes and becomes subtly rosy at 1200lm, so theoretically it should be perfect. Guess what, no one of likes it. They say a 300K warmer (and positive duv) light made the custom look green at any level, and so did the slightly rosy XPL-HI 5D of the D4. It also was noticeably green at the lower modes. And eg. I use my light 80% of the time on the low or medium levels.
Positive duv can be quit yellow at 3000-4000K CCT’s which makes the green colours look more intensive, while negative duv does not and can make wood look rosy which doesn’t look really natural.
The 219C at 5000K has a duv of about +0.003 and it’s horribly lime green, not natural at all.
I made the same observations. A rosy tint does make white look whiter than a positive duv equivalent at the same CCT.
