Nice work! But I like warm leds.
Nice chunk of copper you got there, good job!
Thanks Mike
It gave some work to make it fit well (specially in height), but ended up working!
BTW, I found out that working with copper is harder than working with brass.
Drilling and filing brass in another similar mod gave me less work
Thanks again :+1:
They won’t tell you, but copper is actually a dense form of peanutbutter
Yep, cold pressed UV (Über Virgin).
Yeah, “extremely” dense form then I wouldn’t like to heat that kind of butter, the teeth would go “nuts”
Working on with a hacksaw, some thin drills and a file was a fine challenge!
Wish I had better tools and I would certainly do some more stuff with thicker rods! (like a pill for my Amutorch VG10, to make it a quad :smiling_imp: )
Add in that slim little percentage of Tellurium to the Copper and once it again it machines like brass. Well worth it if you ask me…
On another note, but some machining still involved… I managed to trade my son a newer light for his Jacob A60 then coaxed 227.5Kcd from the old pencil beam thrower.
Good job on the A60 Dale. I still take its stock 55 kcd (with XR-E led) as my reference point for throwers that I make, to feel good about how much flashlights have improved
What led does it have now?
I machined the emitter shelf to accept a 20mm Noctigon with a White Flat. Using an FET+1 A6 style (that I built) and limiting power through cell choice, currently running a Panasonic PF that gives 6.01A at 4.19V freshly charged. Yeah yeah, I know, I have an LED4Power LD-A4 on the way that I will set to a little lower current to optimize the emitter so improper cell choice won’t kill it should I forget (and I will!).
When the LD-A4 arrives I plan to make a copper “retaining ring” that will hold the smaller 17mm driver, just replace the very thick aluminum retaining ring with one made from copper that has a shelf for the driver then solder the driver in after installing. (or if I take a notion I’ll make a retaining ring to fit within the retaining ring to hold the driver. Depends on the variables…
Convoy S2+ Triple XP-E Photo Red 670nm, Carclo 10508 - 8x7135 Convoy driver (Biscotti) - 18350 - Rv Clicky Sw.
Nitecore TIP CRI Nichia 219B - SD - ES Sw - Potted - 290lm.
Installed a green locator LED, boosted output slightly, fully potted internals and some GITD on the switches.
Turbo - 220lm to 290lm
High - 92lm to 160lm
Med - 23lm to 40 lm
Low - 1lm - 1lm
CRX, is that a noctigon on the triple? Or did you put something red thing below the lens! Nice effect
It is a Noctigon MCPCB.
I usually colour the bottom of the three support posts with black but did red this time as I thought it went better.
I modified the CRX Rotary with a 3K carbon fibre jacket and swapped the XP-L HD 3D emitter for an XP-L HI 3A 5000K as I found the XP-L HD 3D tint to be a little too green on the lower modes so now it's a much nicer creamy white to my eyes.
Copper, Titanium & Carbon Fibre construction
Cree XP-L HI v2 3A 5000K emitter
GITD O-ring & LED surround
20mm Copper DTP MCPCB
19mm x 8mm solid copper heatsink
20mm x 12mm SMO Reflector
22mm x 2mm dual coated ARC glass
Lighted Rotary six mode tail switch & Momentary button
Dual colour Tritium indicators
Lockout-able
Diffuser/ protective carry case
Magnetic cell contacts
18350 cell compatible
Removable USB charging unit
Length – 94mm
Width – 27mm
Weight – 192g (with 18350 cell)
New Modes, Operation & Light output:
Pressing the momentary button or turning the rotary tail switch clockwise gives these approximate outputs:
Mo Sw - 1330 lm
Mode - 1 - 1200 lm
Mode - 2 - 392 lm
Mode - 3 - 174 lm
Mode - 4 - 45 lm
Mode - 5 - 3 lm
Mode - 6 - FF
Max cd - 15000
Max Throw - 245m
Modding the UF-C1 (P60) and the Revtronic PT20, to both I added the light cap. The PT20 has already been modified by replacing the reflector with a 120° TIR; I use it only in the house and so is very handy
And some carbon fibre on the CRX CSLNM1.TG Copper & Titanium Zoomie :)
Carbon fibre spare cell carriers?
Carbon fiber spare cell carriers?
Yes please, I’ll take 3!
My friend sent me a Lumintop Tool AA/14500 Ver. 2.0 that arrived yesterday. It had an XP-L HD in it but that didn’t last long, I pulled the pill out, filed off the raised outer edges and filed down a 16mm Noctigon to fit squarely on top of the aluminum pill, then placed a White Flat on the Noctigon. Left the driver alone so it can run AA or 14500 either one. The White Flat makes 538 lumens on a Red Efest 14500 not fully charged and the hot spot is more concentrated with less spill. Works for me!
You could be in luck
I made some custom prototype carbon fibre spare cell carriers, the idea being a nice way to carry a spare cell in your pocket etc. Made from various sizes of CF 3K tube, there are magnets in the top of each unit keeping the cells in place. A sharp tap gets them out. Takes a couple of hours to make each one by hand. Obviously not waterproof as these are meant for pocket or bag carry. These can have an open end, magnetic closed cap, two piece fully enclosed, split ring attachment or bare bone…
Convoy S11 with XHP50.2 80 CRI 4000K and 6V 4.8A boost driver. Modes: 0.1A, 0.4A, 2.3A, 5A. On max mode it takes almost 10A from the battery, however that is too much for the switch and the driver warns about low voltage.
