the code is in post 1 no to neals ?
Correct, didn’t realize it was the same. Thought that because the PM code for BG is the actual pre-order price and it’s the cheapest. That code isn’t listed anywhere and must be requested. Thought the neals one would be the same
I communicated w/FF and left a standing order for a clear ano w/blue switch and matching aux leds. Didn’t get a lot of positive vibes…butt I can dream!
hm explain ?
He wasn’t receptive to offering anything other than purple in the switch leds.
so using 40t cells isnt a good idea for the sst20 ? i have a pair of those on its way and vapcell 20A… i mean there arent lots of options for high drains, usually they are 35A or 20 or something ? seems weird the light can go bad if using a higher rating then 20 ? using 10A cells would that work for highest mode sst20 nw without early stepdowns because 10A only ?
i missed this info
If I can use an NCR20700A 30A on a PL47, then you can use a 40T 30A no problem on an E07.
Just being curious about the statement on Fireflies' website:
http://www.ff-light.com/index.php?route=product/product&product_id=55
"E07 New Second batch from 4th March!!!"
Any ideas/information what's been rectified with batch no. 2? Have all known issues been resolved such as...?
- too short 21700 battery tube
- too much of a solder "blob" as a result of the bypassed driver spring (causing dents in the 21700 positive pole)
- sharp edges on the cooling fins
- broken legs on the optic
- crushed screw heads (maybe by purpose to keep customers from opening their "sealed" lights?)
- uneven MCPCB, leading to uneven distribution of thermal compound
- too little thermal compound, later revisions with too much thermal compound
Is there still a coupon code? Banggood failed to actually send anything from my order, and apparently isn’t getting any more of what I ordered. So two months later I missed out on the codes because Banggood doesn’t know how to stock and display product. Definitely never shopping with them again.
order from Neals gadgets he has in stock and coupon is in first post. Yeah i had to cancel my order there too because they never seem to get this light in stock and dates just keeps pushing forward and forward :person_facepalming:
I finally got my order refunded through Paypal dispute today after trying for weeks to get a response from the seller.
Ordered from FF-light on Dec 18, and received a tracking number on Dec 25th that never updated past “International item has left originating country and is en route to Canada.”
I’m still down $5 because of USD/CAD exchange rates. I’ll be on the lookout for some other 21700 light, I’m not sure if I’m interested in the E07 anymore. Hopefully Emisar will make something.
new infos
Got my clear aluminium from Neal today, wow what a great looking light, its really gorgeous. The finish seems perfect, no sharp fins where the heatsinks are, feels great so far, need to charge my 40ts but tryied with a 18650 thanks to the included adapter works good so far. Pics dont do this light justice! This will be one of my fav lights so far great deal and fast shipping from Neal as always.
aux leds compared to d4s
got an answer per mail from Jack today:
Improved a few things.
1. Round fins edge
2. longer body, 1mm longer to fit battery better
I’m interested in one please HPL-Hi NW, Clear Aluminum
Freeme, I ordered from banggood with your code (Mar 01), but my order has been canceled (out of stock). I decided to buy on ff-light, but the coupon has expired. Could you refresh it?
hm the included lanyard clip is it supposed to fit in the hole on the back? i cant seem to get it fit in there, seems the hole is too small for the included or am i stupid ?
I don’t remember what came with mine. I can recommend these. I prefer them on all my small torches with the quick disconnect.
https://www.amazon.com/dp/B06X9JBKSC/ref=cm_sw_r_cp_api_i_AKpJCbBTJCN9Z
I have no idea why this link is running off the screen
Tip: feed lanyards through using a folded piece of dental floss, works every time.
That’s a good start. I never minded the battery tube length it works with my batteries.
I think we also need to add the dust and particles under the lens. That’s pretty common with his stuff. I like my E07 and sounds like the newer ones will be perfect. I hope in the future Jack does more R&D before releasing instead of afterward so that he can be successful.
would i be possible buy the newer body just from them or, the middle thing i mean not the tailcap ? so in future if buying other 21700 they can fit.
