Yes, SST20 6500K, 5000K, and high CRI 4000K, 3000K options.
Should be before the end of this month.
What will the colors be available? What will the firmware be used and will it be possible to flash (as in d4s)? Will it have an aux leds?
Awesome, I want one!
Any details on pricing, or is that TBD?
Oh, it will never end. I thought I already had everything I wanted, and here’s another flashlight that I want. Why are so few companies doing 4500K high CRI ?. I really like this range.
Nice!
That looks so amazing!
You are planning to make a flashlight on the emitters of the XHP family? This will help fight the heat.
Any details on the driver?
Any option with other leds? Nichia 219c or XP-L?
What battery configuration is used?
Its gorgeous Hank.
looks like no aux leds? and how come 3*18650 and not 4 ? wouldnt 20700 or 21700 been better to use for better runtimes? looks like a fun sodacan light tho and nice design the sand color really looks cool Hank
RIP wallet.
This can’t be less than 100 bucks right?
I’m glad I don’t have to keep this to myself any more.
This light is really bright. Like, really really bright. I can’t even measure it properly, because it’s way more lumens than I have equipment for. It’s like a Noctigon Meteor M43 but a bit smaller, a lot brighter, and with a smooth/stepped ramping UI.
Just so I have an idea, how many BLF Q8s does it equate to?
almost 3 or so, since it does around 5500+ or something on high drain batteries.
A lot of recent high-CRI emitter don’t come in 4500K. I don’t know why. They go up to 4000K, and they go above 5000K, but they have nothing between. If I recall correctly, this is the case for SST-20, LH351D, and 219C. And if I recall correctly, SST-20 doesn’t even have high CRI above 4000K.
However, there are still ways to get 4500K. With so many emitters, it would be a great light for some tint mixing. Put in a mix of 4000K and 5000K emitters, and the tint should be a nicer color temperature which also has a slighly more pink bias.
It could be arranged like this, for example: 9x4000K, 9x5000K
Or to make things look even nicer, it could use all four emitter tints: 3x3000K, 6x4000K, 6x5000K, 3x6500K
This would probably make a very nice-looking ~4700K beam with vivid color rendering, as long as the emitters have the same Vf.
As for me, this is the optimal configuration:
3x18650
18xXP-L HI 3A
Without AUX led
Black
100 $ hmmm
I need to try it! I NEED TO TRY IT!
