Emisar D18 introduction
960 posts / 0 new
Ryzbor
Ryzbor's picture
Last seen: 19 hours 17 min ago
We have a ROT66 killer over here. Without lightened switch, aux led, charging ports and other gimmicks.
3*18650 format is comfortable even for holding the light for long.
I hope you make a 21700 D4 or D4S once.
CCT mixing will result in a better tint, but figuring out how to do it in this light gives me a headache Silly
Does it have D4 UI V2, V3 or Anduril?
That’s a rather odd place for a lanyard hole since the hand will be placed over it. And it looks sharp.
@Hank, the 3000K and 4000K SST-20’s you have in stock are binned above the BBL thus the tint of them isn’t super appealing. The 3500K version BlueSwordM sells is binned below the BBL (GA3 tint bin). Can you make a D18 with them after sending these leds to you? Or maybe you are willing so source them. Or selling a D18 without leds and with an adequate lower price.
virence.com Nichia E21A 3000K + 4000K mix Wizard Pro ; Skilhunt H03 XP-E2 660nm Photo Red ; Wizard Pro E21A 2000K
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 2 days 11 hours ago
lightboks wrote:
Will this be a bit lighter than a BLF Q8? I hope so.. body is 4-6 mm thinner, this is good Smile
And will it be flat or button top?
For that size, there is no place for a battery carryer. Thant means 3P battery with contact-ring on the driver.
So you will need button-top Samsung batteries or flat-top batteries from other manufacturers.
From my experiemence Samsung has deepened flat tops, that means shrink tube is higher than the flat top. And that will not make contact to a driver contact ring.
The most other manufacturers has rised flat top, where the flat top is higher than shrink tube. And such batteries will make contact. E.g. Sony, LG, Sanyo, … will fit.
High current batteries only. I think 20A per battery is realistic. That means around 3A per Emitter.
The flashlight will drain 180-200W, as I have estimated.
ichoderso
ichoderso's picture
Last seen: 14 hours 2 min ago
Thumbs Up and please with USB-C charging port
-X3-
-X3-'s picture
Last seen: 1 day 9 hours ago
ichoderso wrote:
Thumbs Up
That’s not going to happen and it’s a shame IMO
My Olight X7R sees much more use that my X7 because of that.
Taking out multiple cells to charge them then put them back in the light is really a PITA compared to simply plug in a cable.
I mean, okay swapping batteries on a single battery flashlight like the D4 is natural because it eats them so fast… but on a multiple cells like the D18 it would be more practical.
Anyway, this is an unpopular flashaolic opinion and I’m going to put it in the appropriate thread.
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
trakcon
trakcon's picture
Last seen: 3 hours 23 min ago
Wow, Hank. That looks really good!
dotBLF
Last seen: 2 weeks 1 day ago
ToyKeeper wrote:
Or to make things look even nicer, it could use all four emitter tints: 3×3000K, 6×4000K, 6×5000K, 3×6500K
This would probably make a very nice-looking ~4700K beam with vivid color rendering, as long as the emitters have the same Vf.
Stop making me feel these feels. That looks like a PiTA to pull off, but damn would it be worth it…..
Pete7874
Pete7874's picture
Last seen: 53 min 4 sec ago
Wondering how quickly the thermal stepdown will kick in. Smile
Di_Joker
Di_Joker's picture
Last seen: 6 hours 38 min ago
It seems to me when the temperature of the environment is 25°C and the temperature control of 55°C the D18 will be thermostable at 1500Lm. For greater brightness without overheating in such the body D18, emitters are needed XHP.
Turbo mode (14000Lm) will be very short, about 80 seconds.
Sorry for my poor english.
SKY69
Last seen: 1 day 13 hours ago
I absolutely must must must have one!!!
gregor
gregor's picture
Last seen: 4 hours 53 min ago
We don’t know the price. Will you buy it for 400 USD? Wink
sp5it
sp5it's picture
Last seen: 3 hours 12 min ago
I predict 189$
Think of how stupid the average person is, and realize half of them are stupider than that. George Carlin
 Anyone offended by my signature please fill Complaint Form. Thank you.
Hank Wang
Last seen: 24 min 7 sec ago
Jay wrote:
Any details on the driver?
It uses a FET+13*7135+1*7135 driver
https://intl-outdoor.com, Noctigon, Emisar, flashlight components.
Hank Wang
sp5it wrote:
I predict 189$
Lower than $100.
thisnameisvalid
thisnameisvalid's picture
Hank Wang wrote:
sp5it wrote:
I predict 189$
Lower than $100.
That’s fantastic! This is a definite buy.
Hank Wang
I’m surprised to see that nobody asks about what optics the D18 use.
Ok, I can not wait to tell you, that in order to maintain a smaller head, and as pocket-able as possible,
we use 18 pcs single optics, and squeeze every tiny room in the head. Not a easy work for the assembly, the production speed is slow.
dotBLF
Hank Wang wrote:
sp5it wrote:
I predict 189$
Lower than $100.
raucous applause erupts from the internet
Thumbs Up
komeko
komeko's picture
Last seen: 13 hours 22 min ago
I have some questions Smile
1) Will there be XP-l HI 3A version and if it will be more expensive?
2) Is it possible to order a black frame in the front in the black version?
3) Will the batteries be replaced by unscrewing the tail cap, or do you have to unscrew the whole tube?
Click on:        ANSI WHITE
Click on:        MY COLLECTION
Click on:        Q8, D4, D4S, D18, K1, FW3A, SDmini, Mini AAA, TIP, M43, H1, H03, TC20, TN40S, TN42, V6, H600Fw, SC600w, SC64w
BlueSwordM
BlueSwordM's picture
Last seen: 11 hours 43 min ago
@Hank, how much work does that require?
That looks insane.
Pavlo
Last seen: 12 hours 56 min ago
Very nice work Hank!
Curious to see a side by side with the Meteor m43.
Hank Wang
1. 18 pcs XP-L HI 3A LED will be very expensive.
2. It is black mask on all the D18.
3. You will need to unscrew the whole tube to change the batteries, just like the Meteor M43.
nick779
nick779's picture
Last seen: 11 hours 19 min ago
ToyKeeper wrote:
I’m glad I don’t have to keep this to myself any more. Smile
This light is really bright. Like, really really bright. I can’t even measure it properly, because it’s way more lumens than I have equipment for. It’s like a Noctigon Meteor M43 but a bit smaller, a lot brighter, and with a smooth/stepped ramping UI.
With a “normal” driver and the best firmware around. Glad to see you got your hands in this one TK, I remember you aching when you couldnt do anything with the Meteor FW.
PS: This has a bit of a DBCustom vibe coming from it haha.
CrashOne
Last seen: 13 hours 41 min ago
Looking very good!
I presume this needs button top cells? Might order 30Q button tops before the D18 goes on sale Smile
twisted raven
Will this dethrone my ROT66? No stainless steel tailcap, aux leds on button and head are turndowns compared to the ROT66, but the sheer turbo burst output and the possibility of more efficient lower runtimes make me salivate. If 9 emitters in an ROT66 can run without heat at around 1400 lumens, I’m assuming double the emitters can get up to like 2-2500 lumens without heat issues? Maybe, but it is a small host.
komeko
komeko's picture
Hank Wang][quote=komeko wrote:
I have some questions Smile 1. 18 pcs XP-L HI 3A LED will be very expensive.
I am aware that XP-L will be expensive, but I prefer this option anyway. Will you still give this opportunity?
Agro
Agro's picture
Last seen: 4 hours 52 min ago
we use 18 pcs single optics, and squeeze every tiny room in the head. Not a easy work for the assembly, the production speed is slow.!https://intl-outdoor.com/images/20190314214330.png!
So swapping the lenses should be doable. Smile
But there’s like 500 lm loss because you need to put a glass in front of them Silly
What is the diameter of a single lens?
Have you considered adding a 19th lens in the middle and moving electrical connections to the side?
BTW:
I’m very happy to learn about the price. I’d really like to get one as soon as my budget permits it. Smile
komeko
komeko's picture
And one more question. Will the LED system be aligned with the switch? I had this problem with M43 and I had to correct the alignment myself.
twisted raven
Seems like XPL wouldn’t fit under this tiny optics.
redsuns
Last seen: 3 weeks 6 days ago
Thank you Hank for another facinating light! I’m so thankful for your work and look forward to this in my hands! You are very creative!
Hank Wang
Yes, please,
contactcr
Last seen: 6 hours 8 min ago
Beam angle?
Can the black mask on top be removed or does it help keep optics in place?
Will it be possible for advanced user to replace LEDs? No glue, etc?
