Interested.
yes they rushed it a bit to counter the new Emisar light
Also they contacted me and then decided to change Aux board to my design
Hope the prototypes come out well, sure some minor tweaks have to be done
Size?
Probably much bigger than D18?
Anyway: freeme, I can’t buy it but I would be glad to learn the price once the buy starts. Would you mind putting me on the list?
Interested
Interested
They made prototypes in black and 7 other colors, so lets see what in the end will be available on sale, sure they have to limit the color count
Count me in
Interested depending on price.
I’m interested
Interested, depending on price.
Interested
I’ve also talked to TA a few months back about the light using very high performance dual BeCu springs.
This light should be a treat to behold.
Interested!
It is slightly longer then the first MF01 but otherwise very similar in external size.
I have not seen a final prototype to see what they ended up using but they said they could be using BeCu springs, just not sure on the specs yet. I passed on the specs you gave me and they did not mention issues at the time but these things have a way of changing so not sure what will end up in the final light yet. I expect BeCu springs, just not sure on the specs. They melted some early prototype springs though, so I think they get the picture that the springs need to be beefy.
Yep. Did you receive a prototype too?
I’d love to see a beam of this thing with SST-20s.
need one (or two…?)
please with USB-C charging port and 5000k SST20
You got a prototype?
I have a “1st gen prototype”, basically the old body with the new guts I used for testing the driver and LED’s.
The SST-20’s look amazing in it, it is my most used light since I got it working. I am also on the hunt for better bin SST-20’s and narrowing in.
Yeah right.
As if I would have a prototype.
No charging on this light, it would take FOREVER to charge 4 cells in this light and charging them in series is risky under the best of circumstances. I thought it best to not push luck there.
I really wish 5000k SST-20 was possible, sadly the 95cri versions are limited to 4000k.
I am having them look into the 70cri 5000k SST-20 though.
