Emisar D18 introduction
  1. 18 pcs XP-L HI 3A LED will be very expensive.
  2. It is black mask on all the D18.
  3. You will need to unscrew the whole tube to change the batteries, just like the Meteor M43.
With a “normal” driver and the best firmware around. Glad to see you got your hands in this one TK, I remember you aching when you couldnt do anything with the Meteor FW.
PS: This has a bit of a DBCustom vibe coming from it haha.
Looking very good!
I presume this needs button top cells? Might order 30Q button tops before the D18 goes on sale :slight_smile:
Will this dethrone my ROT66? No stainless steel tailcap, aux leds on button and head are turndowns compared to the ROT66, but the sheer turbo burst output and the possibility of more efficient lower runtimes make me salivate. If 9 emitters in an ROT66 can run without heat at around 1400 lumens, I’m assuming double the emitters can get up to like 2-2500 lumens without heat issues? Maybe, but it is a small host.
[quote=Hank Wang]
I am aware that XP-L will be expensive, but I prefer this option anyway. Will you still give this opportunity?
So swapping the lenses should be doable. :slight_smile:
But there’s like 500 lm loss because you need to put a glass in front of them :stuck_out_tongue:
What is the diameter of a single lens?
Have you considered adding a 19th lens in the middle and moving electrical connections to the side?
BTW:
I’m very happy to learn about the price. I’d really like to get one as soon as my budget permits it. :slight_smile:
And one more question. Will the LED system be aligned with the switch? I had this problem with M43 and I had to correct the alignment myself.
Seems like XPL wouldn’t fit under this tiny optics.
Thank you Hank for another facinating light! I’m so thankful for your work and look forward to this in my hands! You are very creative!
Yes, please,
Beam angle?
Can the black mask on top be removed or does it help keep optics in place?
Will it be possible for advanced user to replace LEDs? No glue, etc?
Wow. Take my first born money.
I agree, I’m in! Hoping for blue, that went fast in the D4!
Thanks for the m43 comparison shot.
+1 to source LED options on or below BBL, especially for high cri.
Regarding length, seems similar to m43. Doesn’t the boost driver in the m43 occupy alot of space?
That is very good news Hank. Paypal ready :+1:
Mike
Hank I understand there is no AUX LED at first, and some people do not want, but is there any plan to add it because personally I love the D4S AUX LEDs.
Either way I want one soon :). Very nice work
Oh and it’s a screw down bezel without glue correct?
+1 :+1:
Can you please show us the complete teardown of the light? We want to see the components and fit and finish..
is the electronics made in China? Ramping UI?
The switch on the NOCTIGON looks better and the lanyard hole should be in the tailcap not on battery tube
The NOCTIGON is gorgeous light..
