Fireflies E07 received today and it has a defect :(
19 posts / 0 new
adept1
I’m guessing there’s supposed to be 12 AUX LEDs in the head!
It’s bright as hell, but I won’t be able to live with this!
Currently owned lights:
Jetbeam Jet-IIIM | Jetbeam Jet-Ti M R2 | Solarforce L2M/L2P/L2T/T1 | 4Sevens Quark 123 | 4Sevens Quark Mini CR2 Ti | Solarstorm X2 | Convoy S2+ | Skilhunt H03 | Jetbeam Mini-1 | Amutorch AT40 | Emisar D4S & D4SV2 | Fireflies E07 | Lumintop FW3A
Edited by: adept1 on 03/13/2019 - 07:22
mortuus
mortuus's picture
Last seen: 7 hours 26 min ago
I got mine today also from Neal, here is mine, looks ok to me ?
...where Frugal meets with Flashlight!
BlueSwordM
BlueSwordM's picture
Last seen: 2 days 8 hours ago
His lacks an LED, but yours is perfect.
freeme
freeme's picture
Last seen: 10 hours 11 min ago
Yup, the beside the green wire. embarassed
mortuus
mortuus's picture
oh so unfair Sad
adept1
I opened RMA on FF website and also sent Jacky an email. It’s been a few days and no reply. About to open a PayPal dispute to light a fire under his ass.
rennet
Last seen: 10 months 4 weeks ago
Don’t expect too much. My dispute took 3 weeks start to finish without any reply.
mortuus
mortuus's picture
yeah, shame they missed this, i hope they resolve it for u goodluck! such nice looking light this small details missed shouldnt go out to customers.
Inkidu
I’m curious if it is from the “New Second batch from 4th March” i.e. is there more room for the battery?
djozz
djozz's picture
Last seen: 5 hours 29 min ago
I made many lighted tails and had also many of those little leds work fine at first then fail over time. I learned to not just tack the leds quickly in place but really let a good amount of solder flow under them on both sides (too much solder is not an issue with these). Maybe firefly is a bit careless with the reflow of these little leds. The flashlights should at least be checked before they are sent out, this way they have far more work on them, and money spent, than if they did their checks well.
mortuus
mortuus's picture
funny there is a label on the side of the box, Qualified Certificate with date etc so its weird yeah. they shouldnt rush this light, its very unique and deserves a big audience with no issues etc.
G0OSE
G0OSE's picture
Last seen: 4 hours 55 min ago
You’re surprised it has a defect? surely that was a given Facepalm
Firelight2
Firelight2's picture
Last seen: 1 hour 55 min ago
Hopefully will get these issues fixed. They have a lot of things going for them:
  • Excellent features in their flashlight
  • Good UI
  • Good attention to detail with things like 1 cm thick shelf.
  • Excellent production quality on parts. The anodizing and build quality of individual parts is very good.
  • Clearly designed by flashlight enthusiasts.
The problems seem to be the following:
  • Inexperience – this is what got them with the thermal paste on the back of the star. They used thermal paste on every star, but the layer was so thin it wasn’t big enough to bridge the gap to the shelf. And there was a gap to the shelf because the star was manufactured with insufficient extra tolerance to clear the slightly inward-slanted angle at the edge of the shelf.
  • Assembly quality – Fireflies seems to have had numerous issues at the assembly house. Having great parts quality is nice, but it is also important to have them properly assembled into a fully functioning light.
  • QA – clearly more and better QA needs to be implemented at the assembly house.
Hopefully these issues will be corrected. I look forward to future products from Fireflies. I’m quite pleased with both my E07s. They are my brightest lights.
Firelight2
From the pictures it looks like the LED on the aux board is present, it’s just not lighting up. Probably it just wasn’t soldered correctly, but it could also be a broken LED.
Those little colored 0603 LEDs are a pain to try to solder. Swapped out the LEDs on a Lexel D4 board for a different color and it was a pretty painstaking process to do it all by hand.
Kona G
Last seen: 7 months 4 weeks ago
Please let us know how Jack plans to resolve the issues customers are having.
SKY69
Last seen: 13 hours 25 min ago
I’m a novice looking for help. I have had this fireflies e07 gen one for about a year with no problems. Today I turn it on stays on briefly I turn it off then try to turn it on again nothing happens. The only thing that happens is the button stays lit with two opposing purple lights. Checked the battery no issue there.Can’t figure out what it is any help is appreciated.
KawiBoy1428
KawiBoy1428's picture
Last seen: 4 hours 58 min ago
Sometimes these tactile plunger switches fail…like this one…un-soldered the 2 wires and touched them together to simulate a momentary switch activation, the light cycles fine….in this case… time for a new one….
KB1428 “Live Life WOT
SKY69
That makes sense because the button is awfully mushy has been from day one. Thanks KawiBoy1428 for the info and expertise. You wouldn’t happen to know the best source for the switch do I go back to fireflies?
KawiBoy1428
Try fireflies, or just replace the tactile switch itself, mouser/digi-key has them. If you want to replace the board and switch together, pop the old one out, to see if it is a 3 or 4 contact pcb?
A. Mountain Electronics has them… http://www.mtnelectronics.com/index.php?route=product/product&path=25_83...
B. I use the BLF Q8 lighted switch assembly alot. https://www.aliexpress.com/item/32879434650.html?spm=2114.12010611.0.0.2...
