What's so special about that Tiablo? Looks better but similar to C8
budget light, 3m is pretty far, did u look at the manafont t8?
its a hell of a thrower (i know i promised people pics, but havent gotten around to it)
nice tight beam, most light is thrown too
3 Q5's, draws 1amp, assuming true Q5s, well say each LED is 220 lumens, 660 total, maybe 4-500 OTF?
correct me if im wrong?
def more light than my single R5's driven at 1.5 amps
hey, that stanley HID spotlight is NOT worth the money.
better off with the Stanley 1300 lumen flashlight (this must be an OTF rating. the bulb is an H3 100 Watt, generally rated over 2000 lumens) $30 bux at lowes ;-)
Trust me, did a side by side comparison, returned BOTH HID stanleys, so not impressed. dials up HARD, then drops back when warmed up to MAYBE 1000 lumens.....
link for T8 btw
http://www.manafont.com/product_info.php/ultrafire-t8-cree-q5-3mode-3led-flashlight-p-1163
so you know ahead of time
Springs are designed for 1 18650, so two means shaking changes mode
SOS does not work properly. but strobe DOES!
High Med low works great
finish is a LITTLE cheap.
button is solid build
[quote=Budgeteer]
[/quote]
Build quality, output, and engineering. The A9 w/ aspheric configuration does exactly what it was intended to do, which is project a very tight spot out at a great distance. When I first got it I will say I was a little disappointed, but that was because I was playing around with it indoors during the day. That first night I went outside and allowed it to stretch its legs and wow....I was then impressed. To compare, it easily out throws the 5xR2 mag mod I just finished up, even though it's putting out 1/4 the lumens. For my intended use (rifle mounted, varmint hunting) it works perfectly. Lights up critters as far as I need to. For use in search and rescue however, one may find the beam too narrow. It really depends on what your specific needs are. Sounds like you have one in mind.
-Match
I believe that a XM-L with a decent host will do. How can i do something along the lines of a solarforce turbo head with a XM-L and L2 dual 18650 body.
Basically looking for a cheapish host with a great deep reflector and possibly a dual 18650 but even single would do althrough woudl prefer double.
What can i expect form this thing?:
http://www.kaidomain.com/ProductDetails.aspx?ProductId=10991
How much is better compared to a solarforce l2 with R5
The driver is going to be the issue - anything with a P7 or MC-E in it should be fine as it is already set up to dish out the necessary current. I have an MC-E Spear clone that is just crying out for an XM-L in it.
http://www.dealextreme.com/details.dx/sku.19466
I ordered the Q5 version, but DX sent me the MC-E version. It takes 3.2A at the tailcap so should drive an XM-L properly. Either that or it has the least efficient driver in the known universe.
Upon researching a bit i found out that the most common good throwers use a r2 led. Maybe i should rethink my build.
XR-E's do throw better, it is down to die size. The larger the die is, the larger the reflector you need.
The higher surface brightness also helps with throw. A dedomed SST-90 will throw like crazy and put out enough light that the size of the reflector is almost immaterial.
A laser will throw even better, bit is a bit lacking in spill...
Not sure i want to dedome a r2. Apparently dedomed emitters die quickly but not sure for what reason...
Essentially oxygen gets where it shouldn't. The SST LEDs are still sealed when dedomed. There are some reports of dedomed XM-Ls doing well, but time will tell on that. Like you say, dedoming an XR-E is a bad idea.
Too bad it is impossible to cut the dome a few hairs above the emitter. It should do the trick i guess, but no manufacturer purposely make such leds.
Btw, how much of an impact a R2 has compared to a Q5. I understand they are basicly identical and r2 is just putting out more lumens at same current?
Thre is also S2 but it is unavailable anywhere.
Basically 7%. A Q5 is putting out 107-114 lumens at 350mA, and R2 114-121
If you do that, try this http://www.manafont.com/product_info.php/lunapower-mrv-lg104-cree-q5-5mode-led-flashlight-p-1744
Got it in a givaway from Don (thanks again). Best thrower I ever seen. Very large reflector gives a very narrow beam. Reaching 200-300 meters at least.
Really? Looks like average joe random C8 with a Q5. Quite a bit better looking i admit, but still...
Much better than let say:?
Dont know as I dont have it, but looking at specs there will probably not be much difference, and its cheaper.
Somebody needs to do the math and figure out a reasonable price to lumen ratio..
it seems that there are lots of older lights that will sell cheap and will generally do 76.3% of what the newer more expensive lights will do . Some in very nicely built bodies that are easy to mod ..This is what I'm on the look out for . One reason i was sad to see edi-t lights go up at DX ..i thought they were right up my alley .After getting my hands on a 501b and some pathetic small suns I realiz what real garbage threads and el cheapo bodies there are out there ..I want budget ....Not bad **it...
I think the easiest thrower i know is a solorforce with an xpe r2
If you want big numbers than it's an xml
Just out of curiosity, the p60 dropins if i unscrew the reflector off the pill can it be inserted into a C2 or C8 body without modification or it is an entirely different pill? Wishfull thinking?
If i decide to get the manafont mrv... is it possible to mod it for better throw or it is best left as it is. Would a XM-L do that light justice. I understand the XM-L has a wider angle but is it enough to compensate with brute force output?
Another option would be changing the driver and the led for an R2 slightly overdriven at 1,1-1,2A...
I looked at 802 style flashlights:
http://www.kaidomain.com/ProductDetails.aspx?ProductId=5634
Apparently is glued.
Any idea which is the cheapest available body to mod to a dedicated thrower?
Hi Budgeteer!
I own two hs-802 from DX and they both are not glued. They are very easy to mod and with very deep smooth reflectow that gives pencil thin beam. If you could mod that with XLM it will throw like crazy. In stock form it throws superfine up to 200m or so... For 25$ it's a steal.
Link:
Wow, thanks for the info.
Now if i can get the body cheaper i snag one if not ill probably get the whole flashlight.
The mrv is tempting too and 18usd or so.
the 802 should have a deeper reflector.
I`ve got the SkyRay 1JC8 .Throws like crazy useful up to 200m . It has an xre q5 drawing 1,6 Amps at the Tail outperforms in throw everything i have . Lights up to a distance from 400m (Google Earth measured). I think a good xre overdriven and a perfect smooth reflector will do the trick.
