I already own the S2+ with SST20 4000K and find the hotspot too tight. I was preferring more flood. Fitting an OP reflector helped a little, but it was still tight. I found the OP reflector just smoothed out the edges of the hotspot and not really improved the flood. In any case it’s still a great light so I’ll happily keep it.
Yes I agree the SST20 does provide a very nice colour and tint, but I find this is only after putting 1.5A - 2.8A through it. On lower current/mode it looks a little green. I assume this is normal?
-The size of the led die is very important in determining flood/throw.
The SST20 is tiny compared to the XML2 that is why it produces more throw in the same reflector.
-A de-domed led increases the light angle, so more of the emitted light will hit the reflector and become throw.
Johm, I do understand what you mean now. I incorrectly assumed that the shape of the dome contributed to the flood but yes the SST20 die is tiny. Thanks for pointing this out!
On another note, I see in Convoy’s store Simon now sells a C8+ but with SST40. When I look at the SST40 from google images, it appears this die looks large like XML2 (not small like XPL-Hi or SST20)
Can we hope for a tight and far throw with C8+ SMO and SST40? I have C8 with XML2 and the throw was not so great, but my C8 with XPL-HI produces great throw.
And that’s the point, I am looking for indoor use light, more flood, in camping, 10m max distance, in tent, reading and so on.
I have one XML2 and it looks little rosy, 3D in ANSI. Would rather have 3C, don’t like this red colour. But I guess Nichia 4000K nad SST20 looks little rosy, right?
Hmm I can’t get quad, planning to put this LED in S2+ to have small, low power camping light. I am so close to get this Nichia 219C 5000K, but I’m afraid it is little bluish. Maybe I should buy both 4000K and 5000K and find this out myself. And SST20
Quad E21A has rougly the size of a “normal” led so it fit’s in the S2+ with a 45 o 60dg TIR.
5000K 219C is imo terrible for woodland, it’s coldish and does a bad job at rendering greens and browns, 4000K or even less does this better.
I have the 4000k 219c and the 4000k SST20. The 219c has a bigger and more yellow hotspot. The SST20 is tighter, throws farther and is a little greenish at lower levels. I put DC-Fix on the 219 and it is great now. Great for outdoors, a little more floody and a little less yellow in the center. Decent for short to medium long distance around a campsite and trail.
I plan on getting a filter for the sst20 to lessen the green at the lower levels. I know it will affect the throw some but I think it will be worth it. I hardly noticed the green when I first got it. But when I compared it to some of my other lights, it stood out to me. It’s fixable though. I basically use my lights at 300 lumens or less. Generally around a 100.
I like your last suggestion on getting several different ones and compare. Find what’s right for you. You can keep the others or sell or give away. It won’t break the bank and you will know what you like.
