Okay, freshly charged Windyfire. It ran on Turbo right at 3:30 then stepped down in brightness. It was quite hot. I went back to Turbo and it stepped down after 30 seconds. So thermal management is doing it’s job.
Battery showed to be at 3.81 volts. 4 minutes of Turbo really puts a whooping on this 14500! Lol. It’s probably best to use the Top of Ramp instead of Turbo if you want much longer run times and cooler temps.
I decided to film it since I don’t think there’s many videos of the Micro. Why not?
Now you guys got me think'n - did I break the seals on the 2 minis and clean them up? Maybe I should check my notes. Right now, the 2 minis are hand tightened and threads clean. One I bought from Neal - not sure bout the other one, so maybe that was a sample?
I received my GT Mini CW last week and the bezel is unglued, thankfully because the gasket around the LED was out of place giving a little off-center hot-spot…
For statistics…
I have two Mini, both NW.
The first, from Neal, bought on 16.07.2018.
The second, from BG, 14.09.2018.
None has the bezel glued (very tight but no glue).
Oddly I was able to open up my GT70 bezel with no problems either.
I did just get my GT Micro from the DHL truck this morning. I ordered it with the KeepPower 1000mAh cell from Neal’s; pretty quick shipping from confirmation to delivery. Have the cell charging now; can’t wait to try it out!
Ordered and payed feb23 from Neal, nothing happened since, no light sent out for a month
As one of the very first enthousiasts for this light it is a bit more difficult than normal to stick to my motto with chinese purchases “it comes when it comes”.
