Need help identifying battery spacer...
Seems that “battery spacer” is about the usual term. Is there a commercial solution for dynamically converting flat tops to button tops?
The trouble with little magnets by themselves is that they can become dislodged and short circuit. So, having them in a fixed position is essential, such as nestled inside a Delrin slug.
Unno, I thought he meant “identify them” as in what their function, vs what they’re called. (18500 to 18650, FT to BT, etc.)
I’ve only seen those things that let you stack FTs, like Simon sells. Samesame like what’s pictured in the OP, but lots thinner.
Yeah, I don’t like using magnets either. I got some 14250 cells that I don’t mind using magnets on in the charger but in a light? Nope. They move too much. I’d rather solder blob and rotary tool them off if I ever had to.
If you have access to the proper tooling you could cut down the long spacers. You could make several out of a 65mm spacer. Just a thought.
Understand your concern how about pairing good magnets with nylon washers? You wouldn’t have to get a perfect fit. The washer would prevent the magnets from wandering around if the light gets bounced around.
Nice find. I could use two of the 34mm ones to replace 3xC cells with one 18650, but at $18, ouch!
Take one of those foam tubes you stick under doors to stop drafts, and run heavy-gauge wire coaxially through the center. Great and cheap dummy cells…
How about like a nylon bushing ? or a roller for a curtain rod ?
if this is to just gain height on an 18650 just do a solder blob and be done with it .
After finally doing my first solder blob I realized how stupid I'd been for waiting so long ..it solved like a million stupid problems all in a matter of 11 seconds...
how about wood or .maybe a black rubber plug or thick washer .
Go to the hardware store and ask .. They live for this stuff .
Not sure about the OP, but for me it would be to convert a 3xC light into a single 18650 light, so I’d need something around 80-85mm long.
I’ve seen people make such fillers out of wood and metal rods, but I currently don’t have access to any tools to make one of these myself.
Lightbringer’s idea might be easily doable though.
Over on CPF, one of their reps is active and they did follow-up about the 5mm being back in stock sometime in mid to late April. Their prices are OK for the small spacers, but yeah… for that multi “C” cell adapter, it’s quite pricey. However, if you drain full batteries fairly frequently, it will pay off in the long run (recharging 18650 vs. tossing “C” cells).
Thanks for the tip – I may just do that for a flat top 18350 in a Jetbeam RRT-01 that requires protected cells. The contact point is quite small, so a standard spacer would generally not work.
If it ain’t easy, I risk not ever getting it done. :confounded:
Is this what you’re referring to or something different?
I 3D print 18650 to 3C adapters:
If you want to make something from stuff at home depot, I would suggest using 3/4” PVC pipe for the tube and a 3” #10-24 round head brass screw for the contact. You will need to use something to cap off the PVC, PVC caps should work but you may need to sand them down to fit your light. Drill a hole in the center of the caps for the brass screw and cut the tube down so that the screw passes through the cap on one end by about 1/8”/3mm so that there is room for the nut and that it will by flush with the end of the screw when tightened - this will give you your spacer. Cut another piece of PVC a little shorter than your cell for a battery sleeve and it should work.
Thanks.
The only 3 inch screw I can find at HD is a 1/4in-20:
Also, will 3 inch be long enough? That’s only 76 mm.
Different. Literally, foam “tubes” to wedge under doors to stop drafts. “Solid” (as much as foam can be), no hole through the central axis or anything. Probably more likely to find something like that at a Target than a HD.
This stuff?
A bit skinny, but might be able to work.
The stuff I remember came as loose “sticks” about a yard long, 3-4 of ’em, just wrapped in a PE baggie. Kinda like pool-noodles, only scaled down.
Was over a year ago, don’t recall any brand name, don’t even recall where they were bought.
Goggled “foam stop draft under door”, almost instantly came up with
https://www.amazon.com/Evelots-Double-Window-Stopper-No-Inches-Adjustable/dp/B0100CRCUI/
which are the critters. Snip off an end from one of the white foam inserts…
Thanks, except they are 2” in diameter.
Yeh, I just squished mine in. Fits D/32650s fine, but squished it to fit a C tube and act as a dummy cell.
