read the info
leave your contact mail
wait for the answer - then say yes or skip (we contact you asap with the price)
(and i had to edit the form cause many send it epmpty???)
lol you forgot something, I think it should read:
“read the info
open a new line of credit
wait for the answer
accept the offer and cry over the debt
start to smirk and smile as it slowly dawns on you that you’ve just purchased a miniature hand-held sun”
i think so ;)
Martin, do you know which 21700 batteries will Imalent be using in this? If it’s not too late, I recommend the Molicel P42A, which Mooch says hits harder and runs longer than the 40T in his test. It is also cheaper than the Samsung 40T so should be a cost savings to Imalent for a superior product
Molicel INR21700-P42A 4200mAh (Gray) [image] Official specifications: Rated typical capacity: 4200mAh Rated minimum capacity: 4000mAh Nominal voltage: 3.6V Standard charge current: 4.2A Maximum charge current: 8.4A End of charge voltage: 4.20V +/-0.05V Continuous discharge current: 45A (Cycle life is reduced at high rates) End of discharge voltage: 2.5V Typical impedance: <15mOhm AC 1kHz Cycle life: 500 cycles at 4.2A charge and 10A discharge for 80% Operating te…
Vapcell INR21700 4200mAh (Green) 2019 [image] Official specifications: Model: INR21700 Size: 20.5*70.2mm Nominal voltage: 3.6V End-of-charge voltage: 4.20V End-of-discharge Voltage: 2.50V Typical Capacity: 4200mAh (0.2C discharge) Min capacity: 4000Ah (0.2C discharge) Weight: Max: 70g Internal resistance: Max: 11mOhm (AC 1kHz) Standard Charge: 1500mA,CCCV 100mA cut-off Charging Time: 4hours(standard charge) Quick Charge Current: 3000mA Max Continuous Discharg…
If Imalent plans to use highest capacity 21700 such as the Samsung 50E or LG M50, I suggest they look at the much cheaper Lishen LR2170SF that Mooch says beats the 40T and 50E and is also the same in my experience from my own testing.
They are probably using 30Ts in the Imalent MS18. Otherwise, other cells will be extremely underpowered for the 1200W+ needed for the light.
For the R90TS though, they might be using the same cells too.
Why I think? If they were using 4000mAh cells, they would be over the 100Wh limit.
I’m interested in the MS18. It’s dependent on the price though.
On my R90c one of the LEDs broke only after the second use.
Any updates on this? I ve been saving my money for the MS18
no news atm still wait to start production
I will definitely consider both lights, or maybe both heads with battery. All depends on the price we can get and your opinion verses the prototypes.
Thanks,
Craig
I’m surprised this thread isnt filled with happy members eager to get a good deal and buy these lights??. These lights are simply AMAZING. I fully understand how these arnt on the level of Acebeam or O-lights. But from the looks of their recent success I would guess imalent is closing the gap to the top tier companys.
How did it happen? Was it on Turbo mode and killed by heat?
Any news ?
the lights will be shipped by end of this week from the manufacturer to the dealers
Neal waits for the confirmation then opens the Ordering
Is it too late to sign up? I just signed up last night.
no
still time to sign up
closed until more units available...
this is part of the mail i sent to all people on the interest list:
Hello my dear friend!
The MS18, R90TS and the Kit will leave the factory next week towards Nealsgadgets.com
Unfortunately more people asked to be informed about the deal than lights are available in the first delivery.
thats why i will use this procedure:
If you want to buy one of the lights for the price listed below and will place your order before friday, May 17th 2019:
Answer THIS mail before wednesday, May 15th and tell me which one you want to purchase!If i get more "wants" than units are on stock i randomize the list and send the code as often as stock allows.
-> the people remaining on the list can place their preorder as soon as we get resupply confirmed to assure getting theirs from the second run!
I will be out on ordering one due to unexpected events in my life hopefully someone will be able to get their hand on one in my place.
sorry to hear that M8
you joined a interest list - no fixed spots here ;)
but supply is tight - i hope every enthusiast who wants to pull the trigger can get one!
(and i just opened a second source hopefully ;) )
